How to use arducam_64mp & arducam_64mp FQA
This post describes how to use arducam_64mp on raspberrypi.
This post is a technical finishing post, if you have any questions, please open a new topic :exclamation:
If you have a problem according to this post, please attach the information of the command below and photo of hardware connection (This is important.).
cat /proc/cpuinfo
cat /proc/meminfo
cat /etc/os-release
ls /dev/video*
dpkg -l | grep libcamera
cat /boot/config.txt
libcamera-still -t 1000 -n
dmesg
Install dependencies
Install the Driver
# Agree to restart after installation
libcamera-dev and libcamera-apps Installation
Configuration
if you are under pi4:
Open /boot/config.txt, under [pi4], add the following line:
dtoverlay=vc4-kms-v3d,cma-512
Example:
[pi4]
arm_boost=1
if you are under pi0-3 and other pi models:
Open /boot/config.txt, under [all], add the following line:
Example:
arm_boost=1
under pi0-3,you also need to open some configuration:
  1. Open a terminal
  2. Run sudo raspi-config
  3. Navigate to Advanced Options
  4. Enable Glamor graphic acceleration
  5. Go back to Advanced Options
  6. Navigate to GL Driver
  7. Select GL (Full KMS)
  8. Reboot your Pi
Test
Check video device:
Run the libcamera example to see if the image can be capture normally.
Pi4:
libcamera-still -t 5000 --viewfinder-width 2312 --viewfinder-height 1736 -o 64mp.jpg
Other Pi models:
If you are using 64MP camera with older Pi models, pls set the resolution to 16MP (superpixel mode):
–width 4624 --height 3472
libcamera-still -t 5000 --viewfinder-width 2312 --viewfinder-height 1736 --width 4624--height 3472 -o 64mp.jpg
AutoFocus
Pi 4:
libcamera-still -t 5000 --viewfinder-width 2312 --viewfinder-height 1736 -o pi_hawk_eye.jpg --autofocus
Other Pi models:
libcamera-still -t 5000 --viewfinder-width 2312 --viewfinder-height 1736 --width 4624--height 3472 -o 64mp.jpg --autofocus
Manual focus
Download the source code
git clone https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver.git
Focus Control/Adjustment
# Press the Up/Down Arrow for focus adjustment, press “ctrl + c” to save, or “r” to reset
cd Arducam-Pivariety-V4L2-Driver/focus
python3 FocuserExample.py -d /dev/v4l-subdev1
Step Adjustments
While you are trying manual focus control, you can use --focus-step [number] to configure how many
steps the motor in the lens should move when the Up/Down key is pressed.
By default, it’s set to 50, and you can change it to any value between 1 ~ 1023
python3 FocuserExample.py -d /dev/v4l-subdev1 --focus-step 10
Question 1 Can 64MP QuadCamera save 256MP pictures?
No, you can only save a 64MP image composed of 4 cameras.
The first reason is that due to the limitation of platform interface reception, it cannot support super-high-resolution images. If the image is 256MP, the width and height of the image will be very large. Although the platform cannot accept such a large resolution, we processed the image and scaled the image to 64mp without compromising the 256MP viewing angle.
The other reason is that, It is also to improve driver compatibility, so that the same set of drivers can be used regardless of whether a single camera or multiple cameras.
Question 2 How to switch cameras with a 64MP QuadCamera?
aa82b8ce15d49117b3d46d0b3c8a57cfa047d8de_2_690x380
Example:
# Set to single channel 0
i2cset -y 10 0x24 0x24 0x02
# Set to single channel 1
i2cset -y 10 0x24 0x24 0x12
# Set to single channel 2
i2cset -y 10 0x24 0x24 0x22
# Set to single channel 3
i2cset -y 10 0x24 0x24 0x32
# Set to double channel (single channel 0 and single channel 1)
i2cset -y 10 0x24 0x24 0x01
# Set to double channel (single channel 2 and single channel 3)
i2cset -y 10 0x24 0x24 0x11
# Set to four in one mode (Default)
i2cset -y 10 0x24 0x24 0x00
Question 3 How to check camera supported resolutions?
First method
libcamera-still --list-camera
Second method
Modify the config.txt file
sudo vi /boot/config.txt
Add ,media-controller=0 at the end as shown
1655257007463
After restarting, use the following command to view the resolution
v4l2-ctl --list-formats-ext
1655257114497
Question 4 64mp camera on octoprint?
We provide image files
Question 5 Can the buster use a 64MP camera?
We have no plans to support 64MP cameras on buster for now.
Question 6 How to implement autofocus with libcamera_python on 64MP?(already fixed)
Ourl ibcamera_python library is not yet compatible with libcamera_dev 0.0.7,we will expedite the process of compatibility,you can try to install an stablize version of libcamera_dev.
bulleye-armhf:
cd ~
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-v0.0.5/libcamera-dev-0.0.6-bullseye-armhf.deb
sudo apt install -y ./libcamera-dev-0.0.6-bullseye-armhf.deb
bulleye-arm64:
cd ~
wget https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-v0.0.5/libcamera-apps-0.0.6-bullseye-arm64.deb
sudo apt install -y ./libcamera-apps-0.0.6-bullseye-arm64.deb
To use libcamera_python in detail, you should follow the link below:
