I didnt post the dmesg output as I was limited as a new user in the amount of characters. But I just read through it and there seems to be a driver problem so here the dmesg output cut to size becouse of again the limit.
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:[email protected] smsc95xx.macaddr=DC:A6:32:AB:55:6F vc_mem.mem_base=0x3eb00000 vc_mem.mem_size=0x3ff00000 console=ttyS0,115200 console=tty1 root=PARTUUID=1fba1cdc-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.000000] software IO TLB: mapped [mem 0x0000000033f00000-0x0000000037f00000] (64MB)
[ 0.000000] Memory: 3501972K/3996672K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 167020K reserved, 327680K cma-reserved)
[ 0.000000] ftrace: allocating 37889 entries in 149 pages
[ 0.000000] ftrace: allocated 149 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 10)
[ 0.000000] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000261] Console: colour dummy device 80x25
[ 0.000818] printk: console [tty1] enabled
[ 0.000889] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000929] pid_max: default: 32768 minimum: 301
[ 0.001067] LSM: Security Framework initializing
[ 0.001254] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.001338] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.002603] cgroup: Disabling memory control group subsystem
[ 0.005116] rcu: Hierarchical SRCU implementation.
[ 0.006246] EFI services will not be available.
[ 0.006805] smp: Bringing up secondary CPUs …
[ 0.007887] Detected PIPT I-cache on CPU1
[ 0.007973] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009133] Detected PIPT I-cache on CPU2
[ 0.009185] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.010316] Detected PIPT I-cache on CPU3
[ 0.010366] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010516] smp: Brought up 1 node, 4 CPUs
[ 0.010608] SMP: Total of 4 processors activated.
[ 0.010629] CPU features: detected: 32-bit EL0 Support
[ 0.010648] CPU features: detected: 32-bit EL1 Support
[ 0.010670] CPU features: detected: CRC32 instructions
[ 0.041942] CPU: All CPU(s) started at EL2
[ 0.042037] alternatives: patching kernel code
[ 0.043760] devtmpfs: initialized
[ 0.055108] Enabled cp15_barrier support
[ 0.055178] Enabled setend support
[ 0.055384] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.055433] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.066305] pinctrl core: initialized pinctrl subsystem
[ 0.067160] DMI not present or invalid.
[ 0.067634] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.071348] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.071669] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.072613] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.072731] audit: initializing netlink subsys (disabled)
[ 0.073032] audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
[ 0.073531] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.073773] cpuidle: using governor menu
[ 0.074096] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.074299] ASID allocator initialised with 65536 entries
[ 0.074467] Serial: AMBA PL011 UART driver
[ 0.088345] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.116374] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:19:26, variant start
[ 0.120393] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.171786] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.176233] vgaarb: loaded
[ 0.176785] SCSI subsystem initialized
[ 0.177004] usbcore: registered new interface driver usbfs
[ 0.177070] usbcore: registered new interface driver hub
[ 0.177147] usbcore: registered new device driver usb
[ 0.177536] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.178031] pps_core: LinuxPPS API ver. 1 registered
[ 0.178057] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.178096] PTP clock support registered
[ 0.179531] clocksource: Switched to clocksource arch_sys_counter
[ 0.260021] VFS: Disk quotas dquot_6.6.0
[ 0.260155] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.260335] FS-Cache: Loaded
[ 0.260588] CacheFiles: Loaded
[ 0.261745] simple-framebuffer 3e73f000.framebuffer: framebuffer at 0x3e73f000, 0x384000 bytes
[ 0.261783] simple-framebuffer 3e73f000.framebuffer: format=a8r8g8b8, mode=1280x720x32, linelength=5120
[ 0.267235] Console: switching to colour frame buffer device 160x45
[ 0.271988] simple-framebuffer 3e73f000.framebuffer: fb0: simplefb registered!
[ 0.282585] NET: Registered PF_INET protocol family
[ 0.283192] IP idents hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.286809] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
[ 0.286965] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
[ 0.287276] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
[ 0.287912] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.288253] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.288404] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
[ 0.288791] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.289863] RPC: Registered named UNIX socket transport module.
[ 0.289946] RPC: Registered udp transport module.
[ 0.290005] RPC: Registered tcp transport module.
[ 0.290064] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.290148] PCI: CLS 0 bytes, default 64
[ 0.294370] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.296652] kvm [1]: IPA Size Limit: 44 bits
[ 0.299709] kvm [1]: vgic interrupt IRQ9
[ 0.301788] kvm [1]: Hyp mode initialized successfully
[ 1.193941] Initialise system trusted keyrings
[ 1.196162] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 1.204836] zbud: loaded
[ 1.208531] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.211084] NFS: Registering the id_resolver key type
[ 1.213008] Key type id_resolver registered
[ 1.214837] Key type id_legacy registered
[ 1.216744] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.218562] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.221602] Key type asymmetric registered
[ 1.223427] Asymmetric key parser ‘x509’ registered
[ 1.225340] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.227451] io scheduler mq-deadline registered
[ 1.229310] io scheduler kyber registered
[ 1.239929] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.241853] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.243815] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.245738] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.297632] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.299810] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.301565] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.303310] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.305198] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.307198] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.312831] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.314969] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.316816] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.318920] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.324689] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.326409] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.328121] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.329823] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.331492] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.342700] iproc-rng200 fe104000.rng: hwrng registered
[ 1.345064] vc-mem: phys_addr:0x00000000 mem_base=0x3eb00000 mem_size:0x3ff00000(1023 MiB)
[ 1.348323] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.350495] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.363595] brd: module loaded
[ 1.375068] loop: module loaded
[ 1.377688] Loading iSCSI transport class v2.0-870.
[ 1.384554] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.443690] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.446565] usbcore: registered new interface driver r8152
[ 1.448415] usbcore: registered new interface driver lan78xx
[ 1.450187] usbcore: registered new interface driver smsc95xx
[ 1.453485] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.455230] xhci_hcd 0000:01:00.0: enabling device (0000 → 0002)
[ 1.457057] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.458779] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.461254] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x00003c0000000890
[ 1.464347] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.466083] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.467800] usb usb1: Product: xHCI Host Controller
[ 1.469507] usb usb1: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[ 1.471202] usb usb1: SerialNumber: 0000:01:00.0
[ 1.473632] hub 1-0:1.0: USB hub found
[ 1.475367] hub 1-0:1.0: 1 port detected
[ 1.477693] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.479352] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.481061] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.483148] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.484893] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.486540] usb usb2: Product: xHCI Host Controller
[ 1.488190] usb usb2: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[ 1.489827] usb usb2: SerialNumber: 0000:01:00.0
[ 1.492109] hub 2-0:1.0: USB hub found
[ 1.493796] hub 2-0:1.0: 4 ports detected
[ 1.497145] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.499080] dwc_otg: FIQ enabled
[ 1.499093] dwc_otg: NAK holdoff enabled
[ 1.499103] dwc_otg: FIQ split-transaction FSM enabled
[ 1.499121] Module dwc_common_port init
[ 1.499910] usbcore: registered new interface driver uas
[ 1.501588] usbcore: registered new interface driver usb-storage
[ 1.503412] mousedev: PS/2 mouse device common for all mice
[ 1.511311] sdhci: Secure Digital Host Controller Interface driver
[ 1.512986] sdhci: Copyright(c) Pierre Ossman
[ 1.515256] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.520475] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.522650] hid: raw HID events driver (C) Jiri Kosina
[ 1.524360] usbcore: registered new interface driver usbhid
[ 1.525888] usbhid: USB HID core driver
[ 1.527751] ashmem: initialized
[ 1.537898] Initializing XFRM netlink socket
[ 1.539503] NET: Registered PF_PACKET protocol family
[ 1.541185] Key type dns_resolver registered
[ 1.543986] registered taskstats version 1
[ 1.545541] Loading compiled-in X.509 certificates
[ 1.547741] Key type ._fscrypt registered
[ 1.549280] Key type .fscrypt registered
[ 1.550770] Key type fscrypt-provisioning registered
[ 1.564462] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.566421] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.568120] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 1.578619] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.580692] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.583419] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.585007] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.622412] mmc1: Controller never released inhibit bit(s).
[ 1.627739] of_cfs_init
[ 1.629479] of_cfs_init: OK
[ 1.663086] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.665124] Waiting for root device PARTUUID=1fba1cdc-02…
[ 1.714406] mmc1: new high speed SDIO card at address 0001
[ 1.731566] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.882313] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.883936] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.885522] usb 1-1: Product: USB2.0 Hub
[ 1.889069] hub 1-1:1.0: USB hub found
[ 1.890898] hub 1-1:1.0: 4 ports detected
[ 2.007907] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.029616] usb 2-1: New USB device found, idVendor=0781, idProduct=5583, bcdDevice= 1.00
[ 2.031254] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.032935] usb 2-1: Product: SanDisk 3.2Gen1
[ 2.034554] usb 2-1: Manufacturer: USB
[ 2.036181] usb 2-1: SerialNumber: 01010dc10d83e0a931bb9e727bedd1d0a620381172a62c8908e53d64ddef2dc455630000000000000000000000645ce7ff845b0083558107732826e8
[ 2.040271] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 2.042807] scsi host0: usb-storage 2-1:1.0
[ 2.187559] usb 1-1.2: new high-speed USB device number 3 using xhci_hcd
[ 2.288314] usb 1-1.2: New USB device found, idVendor=0bda, idProduct=c811, bcdDevice= 2.00
[ 2.290104] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.291896] usb 1-1.2: Product: 802.11ac NIC
[ 2.293663] usb 1-1.2: Manufacturer: Realtek
[ 2.295422] usb 1-1.2: SerialNumber: 123456
[ 3.073084] scsi 0:0:0:0: Direct-Access USB SanDisk 3.2Gen1 1.00 PQ: 0 ANSI: 6
[ 3.076087] sd 0:0:0:0: [sda] 240353280 512-byte logical blocks: (123 GB/115 GiB)
[ 3.079966] sd 0:0:0:0: [sda] Write Protect is off
[ 3.081791] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 3.082647] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn’t support DPO or FUA
[ 3.092105] sda: sda1 sda2
[ 3.096717] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 3.127971] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.130034] VFS: Mounted root (ext4 filesystem) readonly on device 8:2.
[ 3.139640] devtmpfs: mounted
[ 3.149430] Freeing unused kernel memory: 3776K
[ 3.151554] Run /sbin/init as init process
[ 3.153431] with arguments:
[ 3.153440] /sbin/init
[ 3.153450] with environment:
[ 3.153459] HOME=/
[ 3.153468] TERM=linux
[ 3.458391] systemd[1]: System time before build time, advancing clock.
[ 3.527987] NET: Registered PF_INET6 protocol family
[ 3.531815] Segment Routing with IPv6
[ 3.533737] In-situ OAM (IOAM) with IPv6
[ 3.584198] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 3.589289] systemd[1]: Detected architecture arm64.
[ 3.610588] systemd[1]: Set hostname to .
[ 4.312252] systemd[1]: Queued start job for default target Multi-User System.
[ 4.316636] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.321125] systemd[1]: Created slice system-getty.slice.
[ 4.326143] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.329399] systemd[1]: Created slice system-modprobe.slice.
[ 4.333974] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.337126] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 4.342466] systemd[1]: Created slice User and Session Slice.
[ 4.347416] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 4.352339] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.358041] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 4.363098] systemd[1]: Reached target Local Encrypted Volumes.
[ 4.368093] systemd[1]: Reached target Paths.
[ 4.372861] systemd[1]: Reached target Slices.
[ 4.377577] systemd[1]: Reached target Swap.
[ 4.382998] systemd[1]: Listening on Syslog Socket.
[ 4.388359] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 4.393356] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 4.399190] systemd[1]: Listening on Journal Audit Socket.
[ 4.404553] systemd[1]: Listening on Journal Socket (/dev/log).
[ 4.409952] systemd[1]: Listening on Journal Socket.
[ 4.416630] systemd[1]: Listening on udev Control Socket.
[ 4.421922] systemd[1]: Listening on udev Kernel Socket.
[ 4.427296] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.433476] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.442467] systemd[1]: Mounting RPC Pipe File System…
[ 4.452047] systemd[1]: Mounting Kernel Debug File System…
[ 4.461749] systemd[1]: Mounting Kernel Trace File System…
[ 4.466775] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 4.476706] systemd[1]: Starting Restore / save the current clock…
[ 4.487339] systemd[1]: Starting Set the console keyboard layout…
[ 4.496963] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 4.507177] systemd[1]: Starting Load Kernel Module configfs…
[ 4.517086] systemd[1]: Starting Load Kernel Module drm…
[ 4.526937] systemd[1]: Starting Load Kernel Module fuse…
[ 4.537388] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 4.543949] systemd[1]: Starting File System Check on Root Device…
[ 4.561033] systemd[1]: Starting Journal Service…
[ 4.573602] fuse: init (API version 7.34)
[ 4.577665] systemd[1]: Starting Load Kernel Modules…
[ 4.593617] systemd[1]: Starting Coldplug All udev Devices…
[ 4.627219] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.634279] systemd[1]: Mounted RPC Pipe File System.
[ 4.641415] systemd[1]: Mounted Kernel Debug File System.
[ 4.648919] systemd[1]: Mounted Kernel Trace File System.
[ 4.657452] systemd[1]: Finished Restore / save the current clock.
[ 4.666690] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.674428] systemd[1]: [email protected]: Succeeded.
[ 4.678751] systemd[1]: Finished Load Kernel Module configfs.
[ 4.687209] systemd[1]: [email protected]: Succeeded.
[ 4.693066] systemd[1]: Finished Load Kernel Module drm.
[ 4.702187] systemd[1]: [email protected]: Succeeded.
[ 4.708058] systemd[1]: Finished Load Kernel Module fuse.
[ 4.715461] systemd[1]: Finished Load Kernel Modules.
[ 4.729584] systemd[1]: Mounting FUSE Control File System…
[ 4.745192] systemd[1]: Mounting Kernel Configuration File System…
[ 4.758889] systemd[1]: Started File System Check Daemon to report status.
[ 4.772443] systemd[1]: Starting Apply Kernel Variables…
[ 4.789165] systemd[1]: Mounted FUSE Control File System.
[ 4.809083] systemd[1]: Mounted Kernel Configuration File System.
[ 4.870799] systemd[1]: Finished Apply Kernel Variables.
[ 4.981161] systemd[1]: Finished File System Check on Root Device.
[ 4.988525] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.992792] systemd[1]: Started Journal Service.
[ 5.139862] EXT4-fs (sda2): re-mounted. Opts: (null). Quota mode: none.
[ 5.201439] systemd-journald[133]: Received client request to flush runtime journal.
[ 5.218627] systemd-journald[133]: File /var/log/journal/ecf738dd5a8a4f33b1886570aae12a8b/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 6.334743] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 6.351466] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 6.374440] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 6.401580] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.404519] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.404556] [vc_sm_connected_init]: start
[ 6.414270] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 6.426601] [vc_sm_connected_init]: installed successfully
[ 6.439633] random: crng init done
[ 6.439659] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.464869] mc: Linux media interface: v0.10
[ 6.558501] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.559280] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.688082] videodev: Linux video capture interface: v2.00
[ 6.709142] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.721734] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.732642] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 6.733433] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.770261] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.781272] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.926494] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.932293] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.954450] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.958349] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.971439] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.002985] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.035566] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.037615] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.042109] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.045134] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.054747] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.057175] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-model-b.bin failed with error -2
[ 7.057759] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.062742] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.062791] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.062838] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.062857] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.062875] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.065600] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.065684] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.073362] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 7.077634] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 7.077723] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.077984] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.079376] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 7.082286] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 7.082331] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.082353] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.082372] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.082406] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.082767] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.083921] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.083997] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.092526] usbcore: registered new interface driver brcmfmac
[ 7.141966] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.142912] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.169083] checking generic (3e73f000 384000) vs hw (0 ffffffffffffffff)
[ 7.169121] fb0: switching to vc4 from simple
[ 7.213282] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 7.213343] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 7.228718] Console: switching to colour dummy device 80x25
[ 7.265403] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.298363] Registered IR keymap rc-cec
[ 7.304480] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.305772] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.312612] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.324328] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.407865] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 7.812694] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.819058] Registered IR keymap rc-cec
[ 7.827013] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.830083] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 7.834265] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.851679] Registered IR keymap rc-cec
[ 7.860284] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.865910] dw9807_vcm: loading out-of-tree module taints kernel.
[ 7.868898] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input2
[ 7.965261] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.965723] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.966045] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.966344] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.966628] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.966865] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.967155] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.987614] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.987874] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 7.999307] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 8.019567] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 8.024534] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 9.289582] uart-pl011 fe201000.serial: no DMA platform data
[ 9.353268] 8021q: 802.1Q VLAN Support v1.8
[ 9.531148] Adding 102396k swap on /var/swap. Priority:-2 extents:3 across:135168k FS
[ 9.810160] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 10.028054] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.028515] bcmgenet fd580000.ethernet eth0: Link is Down
[ 15.157264] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.203035] Bluetooth: Core ver 2.22
[ 16.203130] NET: Registered PF_BLUETOOTH protocol family
[ 16.203136] Bluetooth: HCI device and connection manager initialized
[ 16.203153] Bluetooth: HCI socket layer initialized
[ 16.203160] Bluetooth: L2CAP socket layer initialized
[ 16.203175] Bluetooth: SCO socket layer initialized
[ 16.210019] Bluetooth: HCI UART driver ver 2.3
[ 16.210041] Bluetooth: HCI UART protocol H4 registered
[ 16.210105] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.210279] Bluetooth: HCI UART protocol Broadcom registered
[ 16.443853] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.443872] Bluetooth: BNEP filters: protocol multicast
[ 16.443886] Bluetooth: BNEP socket layer initialized
[ 16.454644] NET: Registered PF_ALG protocol family
[ 31.711547] cam-dummy-reg: disabling
