No cameras available!
I have run into the no camera issue and implementing the solution in the one relevant thread did not help
  1. Where did you get the camera module
    I ordered it from amazon
  2. Model Number of the product
    B0399
  3. Hardware / platform:
    Fresh install of 32 bit bullseye of latest update released 2023, did not chose to update after fresh install
  4. Instructions I have followed :
    How to use arducam_64mp & arducam_64mp FAQ
  5. Problems I am having :
[email protected]:~ $ libcamera-still --list-cameras
6 ) Demesg posted below
  1. Troubleshooting attempts :
    I have clean installed and followed the FAQ and then this thread
    64MP QuadCamera - No cameras available!
  2. What help do I need :
    To get the camera recognized and working
Other details :
cpuinfo
processor	: 0
model name	: ARMv7 Processor rev 3 (v7l)
BogoMIPS	: 126.00
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 1
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 2
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 3
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
Hardware	: BCM2711
Revision	: b03115
Serial		: 1000000083fc83d2
Model		: Raspberry Pi 4 Model B Rev 1.5
meminfo
MemTotal:        1916908 kB
MemFree:          754976 kB
MemAvailable:     909316 kB
Buffers:            8492 kB
Cached:           437476 kB
SwapCached:            0 kB
Active:           169352 kB
Inactive:         691044 kB
Active(anon):       2376 kB
Inactive(anon):   640568 kB
Active(file):     166976 kB
Inactive(file):    50476 kB
Unevictable:      177620 kB
Mlocked:              16 kB
HighTotal:       1232896 kB
HighFree:         184112 kB
LowTotal:         684012 kB
LowFree:          570864 kB
SwapTotal:        102396 kB
SwapFree:         101372 kB
Dirty:                72 kB
Writeback:             0 kB
AnonPages:        591936 kB
Mapped:           215224 kB
Shmem:            228516 kB
KReclaimable:      20104 kB
Slab:              45588 kB
SReclaimable:      20104 kB
SUnreclaim:        25484 kB
KernelStack:        3016 kB
PageTables:        16348 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     1060848 kB
Committed_AS:    3442580 kB
VmallocTotal:     245760 kB
VmallocUsed:        6256 kB
VmallocChunk:          0 kB
Percpu:              448 kB
CmaTotal:         524288 kB
CmaFree:          474972 kB
OS
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
ls /dev/video
[email protected]:~ $ ls /dev/video*
/dev/video10  /dev/video13  /dev/video16  /dev/video20  /dev/video23
/dev/video11  /dev/video14  /dev/video18  /dev/video21  /dev/video31
/dev/video12  /dev/video15  /dev/video19  /dev/video22
dpkg -l | grep libcamera
[email protected]:~ $ dpkg -l | grep libcamera
ii  libcamera-apps                       0~git20230309+4def288-1          armhf        libcamera-apps
ii  libcamera-dev:armhf                  0~git20230321+74d023d8-1         armhf        complex camera support library (development files)
ii  libcamera-tools                      0~git20230124+9b860a66-1         armhf        complex camera support library (tools)
ii  libcamera0:armhf                     0~git20230321+74d023d8-1         armhf        complex camera support library
ii  python3-libcamera                    0~git20230302+923f5d70-1         armhf        complex camera support library (Python 3 bindings)
cat /boot/config.txt
[email protected]:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
libcamera-still -t 1000 -n
[email protected]:~ $ libcamera-still -t 1000 -n
[0:30:04.264838067] [1880]  INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4225-74d023d8
I will post dmesg on the next post as I have hit the word limit.
Thanks !
dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.15.84-v7l+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 12:01:26 GMT 2023
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
[    0.000000] random: crng init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x000000000ec00000, size 512 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[    0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 503104
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:[email protected] smsc95xx.macaddr=E4:5F:01:BE:FC:F5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a3ae6617-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000009a00000-0x000000000da00000] (64MB)
[    0.000000] Memory: 1390572K/2019328K available (10240K kernel code, 1386K rwdata, 3308K rodata, 2048K init, 591K bss, 104468K reserved, 524288K cma-reserved, 1232896K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 35518 entries in 105 pages
[    0.000000] ftrace: allocated 105 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 25)
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000018] Switching to timer-based delay loop, resolution 18ns
[    0.000395] Console: colour dummy device 80x30
[    0.000460] printk: console [tty1] enabled
[    0.000527] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000557] pid_max: default: 32768 minimum: 301
[    0.000702] LSM: Security Framework initializing
[    0.000911] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000942] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002538] cgroup: Disabling memory control group subsystem
[    0.002790] CPU: Testing write buffer coherency: ok
[    0.002849] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.003318] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004841] Setting up static identity map for 0x200000 - 0x20003c
[    0.005041] rcu: Hierarchical SRCU implementation.
[    0.006058] smp: Bringing up secondary CPUs ...
[    0.007270] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008624] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.009938] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010100] smp: Brought up 1 node, 4 CPUs
[    0.010123] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.010143] CPU: All CPU(s) started in HYP mode.
[    0.010156] CPU: Virtualization extensions available.
[    0.010964] devtmpfs: initialized
[    0.026904] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.027131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027167] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.044071] pinctrl core: initialized pinctrl subsystem
[    0.045388] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.050104] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.050943] audit: initializing netlink subsys (disabled)
[    0.051208] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[    0.051878] thermal_sys: Registered thermal governor 'step_wise'
[    0.052711] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.052731] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.053165] Serial: AMBA PL011 UART driver
[    0.068711] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.110104] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:46:54, variant start
[    0.120119] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[    0.181427] Kprobes globally optimized
[    0.187574] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.192310] vgaarb: loaded
[    0.192798] SCSI subsystem initialized
[    0.193048] usbcore: registered new interface driver usbfs
[    0.193122] usbcore: registered new interface driver hub
[    0.193196] usbcore: registered new device driver usb
[    0.193625] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.193813] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.194151] pps_core: LinuxPPS API ver. 1 registered
[    0.194167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.194195] PTP clock support registered
[    0.195958] clocksource: Switched to clocksource arch_sys_counter
[    0.276727] VFS: Disk quotas dquot_6.6.0
[    0.276840] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.277033] FS-Cache: Loaded
[    0.277249] CacheFiles: Loaded
[    0.278433] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[    0.278458] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    0.278996] Console: switching to colour frame buffer device 240x67
[    0.289756] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[    0.299569] NET: Registered PF_INET protocol family
[    0.299834] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.301480] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.301516] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.301541] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.301606] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.301680] TCP: Hash tables configured (established 8192 bind 8192)
[    0.301850] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.301889] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.302157] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.306888] RPC: Registered named UNIX socket transport module.
[    0.306905] RPC: Registered udp transport module.
[    0.306919] RPC: Registered tcp transport module.
[    0.306933] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.306956] PCI: CLS 0 bytes, default 64
[    1.327644] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.351164] Initialise system trusted keyrings
[    1.351478] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.360435] zbud: loaded
[    1.362466] FS-Cache: Netfs 'nfs' registered for caching
[    1.363363] NFS: Registering the id_resolver key type
[    1.363408] Key type id_resolver registered
[    1.363423] Key type id_legacy registered
[    1.363558] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.363575] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.364692] Key type asymmetric registered
[    1.364709] Asymmetric key parser 'x509' registered
[    1.364945] bounce: pool size: 64 pages
[    1.365009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.365239] io scheduler mq-deadline registered
[    1.365256] io scheduler kyber registered
[    1.374559] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[    1.374602] brcm-pcie fd500000.pcie:   No bus range found for /scb/[email protected], using [bus 00-ff]
[    1.374699] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.374793] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[    1.458059] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.458462] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.458485] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.458507] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.458602] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.458855] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.462682] PCI: bus0: Fast back to back transfers disabled
[    1.462707] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.463083] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.463213] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.463647] pci 0000:01:00.0: PME# supported from D0 D3hot
[    1.467452] PCI: bus1: Fast back to back transfers disabled
[    1.467473] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.467517] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.467543] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.467630] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.467656] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.468087] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.468328] pcieport 0000:00:00.0: PME: Signaling with IRQ 79
[    1.482846] iproc-rng200 fe104000.rng: hwrng registered
[    1.483238] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.484910] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.498193] brd: module loaded
[    1.508932] loop: module loaded
[    1.509830] Loading iSCSI transport class v2.0-870.
[    1.515272] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.616123] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.617378] usbcore: registered new interface driver r8152
[    1.617469] usbcore: registered new interface driver lan78xx
[    1.617533] usbcore: registered new interface driver smsc95xx
[    1.669406] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.669447] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.675054] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[    1.676161] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.676188] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.676214] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.676606] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.676630] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.676649] usb usb1: Product: xHCI Host Controller
[    1.676666] usb usb1: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[    1.676682] usb usb1: SerialNumber: 0000:01:00.0
[    1.677453] hub 1-0:1.0: USB hub found
[    1.677526] hub 1-0:1.0: 1 port detected
[    1.678567] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.678590] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.678608] usb usb2: Product: xHCI Host Controller
[    1.678625] usb usb2: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[    1.678642] usb usb2: SerialNumber: 0000:01:00.0
[    1.679370] hub 2-0:1.0: USB hub found
[    1.679468] hub 2-0:1.0: 4 ports detected
[    1.681455] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.681838] dwc_otg: FIQ enabled
[    1.681852] dwc_otg: NAK holdoff enabled
[    1.681865] dwc_otg: FIQ split-transaction FSM enabled
[    1.681882] Module dwc_common_port init
[    1.682380] usbcore: registered new interface driver uas
[    1.682488] usbcore: registered new interface driver usb-storage
[    1.682723] mousedev: PS/2 mouse device common for all mice
[    1.688790] sdhci: Secure Digital Host Controller Interface driver
[    1.688809] sdhci: Copyright(c) Pierre Ossman
[    1.689580] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.693519] ledtrig-cpu: registered to indicate activity on CPUs
[    1.693865] hid: raw HID events driver (C) Jiri Kosina
[    1.694060] usbcore: registered new interface driver usbhid
[    1.694076] usbhid: USB HID core driver
[    1.700751] Initializing XFRM netlink socket
[    1.700797] NET: Registered PF_PACKET protocol family
[    1.700916] Key type dns_resolver registered
[    1.701413] Registering SWP/SWPB emulation handler
[    1.702265] registered taskstats version 1
[    1.702297] Loading compiled-in X.509 certificates
[    1.703132] Key type .fscrypt registered
[    1.703149] Key type fscrypt-provisioning registered
[    1.715849] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.716215] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.716351] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    1.725794] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.726373] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.727692] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.727714] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.756948] of_cfs_init
[    1.757209] of_cfs_init: OK
[    1.792706] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.793122] Waiting for root device PARTUUID=a3ae6617-02...
[    1.844494] mmc1: new high speed SDIO card at address 0001
[    1.892638] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[    1.893649] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[    1.897437]  mmcblk0: p1 p2
[    1.898014] mmcblk0: mmc0:5048 SD32G 29.7 GiB (quirks 0x00004000)
[    1.919975] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    1.920067] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.921004] devtmpfs: mounted
[    1.933139] Freeing unused kernel image (initmem) memory: 2048K
[    1.946298] Run /sbin/init as init process
[    1.946316]   with arguments:
[    1.946329]     /sbin/init
[    1.946342]     splash
[    1.946355]   with environment:
[    1.946367]     HOME=/
[    1.946380]     TERM=linux
[    1.966000] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    2.148770] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.148805] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.148826] usb 1-1: Product: USB2.0 Hub
[    2.151657] hub 1-1:1.0: USB hub found
[    2.151944] hub 1-1:1.0: 4 ports detected
[    2.256620] systemd[1]: System time before build time, advancing clock.
[    2.460153] NET: Registered PF_INET6 protocol family
[    2.462004] Segment Routing with IPv6
[    2.462050] In-situ OAM (IOAM) with IPv6
[    2.485999] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[    2.542824] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    2.543718] systemd[1]: Detected architecture arm.
[    2.549497] systemd[1]: Set hostname to <raspberrypi>.
[    2.626642] usb 1-1.1: New USB device found, idVendor=1a2c, idProduct=2124, bcdDevice= 1.10
[    2.626683] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.626716] usb 1-1.1: Product: USB Keyboard
[    2.626734] usb 1-1.1: Manufacturer: SEM
[    2.639313] input: SEM USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:1A2C:2124.0001/input/input0
[    2.706993] hid-generic 0003:1A2C:2124.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:01:00.0-1.1/input0
[    2.714913] input: SEM USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1A2C:2124.0002/input/input1
[    2.786937] input: SEM USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1A2C:2124.0002/input/input2
[    2.787325] hid-generic 0003:1A2C:2124.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:01:00.0-1.1/input1
[    2.896015] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
[    3.044549] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.07
[    3.044584] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.044605] usb 1-1.3: Product: USB Receiver
[    3.044622] usb 1-1.3: Manufacturer: Logitech
[    3.057054] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C52B.0003/input/input3
[    3.127108] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input0
[    3.135866] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input4
[    3.136491] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input5
[    3.206364] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input6
[    3.206862] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input1
[    3.214301] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[    3.264603] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    3.454616] systemd[1]: Queued start job for default target Graphical Interface.
[    3.460470] systemd[1]: Created slice system-getty.slice.
[    3.461829] systemd[1]: Created slice system-modprobe.slice.
[    3.462847] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.463713] systemd[1]: Created slice User and Session Slice.
[    3.464236] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.465419] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.466619] systemd[1]: Reached target Slices.
[    3.466837] systemd[1]: Reached target Swap.
[    3.470474] systemd[1]: Listening on Syslog Socket.
[    3.471292] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.471711] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.472976] systemd[1]: Listening on Journal Audit Socket.
[    3.473792] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.474787] systemd[1]: Listening on Journal Socket.
[    3.479975] systemd[1]: Listening on udev Control Socket.
[    3.480891] systemd[1]: Listening on udev Kernel Socket.
[    3.481860] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    3.487493] systemd[1]: Mounting POSIX Message Queue File System...
[    3.493705] systemd[1]: Mounting RPC Pipe File System...
[    3.501042] systemd[1]: Mounting Kernel Debug File System...
[    3.508568] systemd[1]: Mounting Kernel Trace File System...
[    3.509321] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    3.520438] systemd[1]: Starting Restore / save the current clock...
[    3.527965] systemd[1]: Starting Set the console keyboard layout...
[    3.537469] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.546557] systemd[1]: Starting Load Kernel Module configfs...
[    3.555099] systemd[1]: Starting Load Kernel Module drm...
[    3.567198] systemd[1]: Starting Load Kernel Module fuse...
[    3.570922] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.578178] systemd[1]: Starting File System Check on Root Device...
[    3.606181] systemd[1]: Starting Journal Service...
[    3.637786] systemd[1]: Starting Load Kernel Modules...
[    3.651847] systemd[1]: Starting Coldplug All udev Devices...
[    3.671877] fuse: init (API version 7.34)
[    3.682235] systemd[1]: Mounted POSIX Message Queue File System.
[    3.683244] systemd[1]: Mounted RPC Pipe File System.
[    3.684159] systemd[1]: Mounted Kernel Debug File System.
[    3.685056] systemd[1]: Mounted Kernel Trace File System.
[    3.690365] systemd[1]: Finished Restore / save the current clock.
[    3.693608] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.695884] systemd[1]: [email protected]: Succeeded.
[    3.699417] systemd[1]: Finished Load Kernel Module configfs.
[    3.703166] systemd[1]: [email protected]: Succeeded.
[    3.704636] systemd[1]: Finished Load Kernel Module fuse.
[    3.713324] systemd[1]: Mounting FUSE Control File System...
[    3.720720] systemd[1]: Mounting Kernel Configuration File System...
[    3.739471] systemd[1]: Started File System Check Daemon to report status.
[    3.767210] i2c_dev: i2c /dev entries driver
[    3.771289] systemd[1]: Mounted FUSE Control File System.
[    3.772083] systemd[1]: Mounted Kernel Configuration File System.
[    3.774589] systemd[1]: Finished Load Kernel Modules.
[    3.791984] systemd[1]: Starting Apply Kernel Variables...
[    3.851937] systemd[1]: [email protected]: Succeeded.
[    3.854869] systemd[1]: Finished Load Kernel Module drm.
[    3.886886] systemd[1]: Finished Apply Kernel Variables.
[    3.891366] systemd[1]: Finished File System Check on Root Device.
[    3.907208] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.050150] systemd[1]: Started Journal Service.
[    4.110711] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[    4.185609] systemd-journald[142]: Received client request to flush runtime journal.
[    4.195585] systemd-journald[142]: File /var/log/journal/b0200ab30387418f9d911ba3d44c153b/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.428056] mc: Linux media interface: v0.10
[    5.630350] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.736609] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.738980] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.739016] [vc_sm_connected_init]: start
[    5.766455] bcm2835_audio bcm2835_audio: card created with 8 channels
[    5.826195] [vc_sm_connected_init]: installed successfully
[    5.965139] videodev: Linux video capture interface: v2.00
[    6.225706] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.253195] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.263007] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    6.264823] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    6.299768] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    6.302307] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    6.337549] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    6.376446] rpivid feb10000.codec: Device registered as /dev/video19
[    6.380885] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    6.380946] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    6.420859] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    6.420919] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    6.443508] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    6.443566] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.455198] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    6.455265] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    6.463825] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    6.463891] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    6.475670] i2c i2c-22: Added multiplexed i2c bus 0
[    6.479571] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[    6.479979] i2c i2c-22: Added multiplexed i2c bus 10
[    6.527091] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    6.626131] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    6.626946] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    6.627476] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    6.627829] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    6.627862] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.627887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.627910] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.627932] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.698946] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.719658] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    6.722560] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    6.746083] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    6.746661] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    6.746695] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.746729] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.746753] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.746775] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.747233] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.758241] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.780583] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    7.122884] brcmfmac: F1 signature read @0x18000000=0x15264345
[    7.138165] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.197431] usbcore: registered new interface driver brcmfmac
[    7.459881] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.466271] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    7.663286] uart-pl011 fe201000.serial: no DMA platform data
[    7.728204] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[    7.728238] fb0: switching to vc4 from simple
[    7.745514] Console: switching to colour dummy device 80x30
[    7.745890] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    7.790948] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    7.811524] Registered IR keymap rc-cec
[    7.814571] 8021q: 802.1Q VLAN Support v1.8
[    7.834939] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    7.835681] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input8
[    7.921311] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[    7.984071] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    7.985570] bcmgenet fd580000.ethernet eth0: Link is Down
[    8.026521] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    8.081818] input: Logitech Wireless Device PID:4055 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0005/0003:046D:4055.0006/input/input10
[    8.082430] hid-generic 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:4055] on usb-0000:01:00.0-1.3/input2:1
[    8.119318] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    8.150545] Registered IR keymap rc-cec
[    8.150758] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    8.151027] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input9
[    8.726618] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
continued
[    8.727184] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    8.728586] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.730424] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.731347] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.731969] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.732452] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.982763] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    9.261784] Console: switching to colour frame buffer device 240x67
[    9.261888] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[   10.093208] arducam_64mp: loading out-of-tree module taints kernel.
[   10.106398] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[   10.114932] arducam_64mp: probe of 10-001a failed with error -5
[   10.213550] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   10.257976] input: Logitech Wireless Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0005/0003:046D:4055.0006/input/input14
[   10.258275] logitech-hidpp-device 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:01:00.0-1.3/input2:1
[   15.375134] Bluetooth: Core ver 2.22
[   15.375213] NET: Registered PF_BLUETOOTH protocol family
[   15.375220] Bluetooth: HCI device and connection manager initialized
[   15.375237] Bluetooth: HCI socket layer initialized
[   15.375248] Bluetooth: L2CAP socket layer initialized
[   15.375264] Bluetooth: SCO socket layer initialized
[   15.422127] Bluetooth: HCI UART driver ver 2.3
[   15.422142] Bluetooth: HCI UART protocol H4 registered
[   15.422205] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.422357] Bluetooth: HCI UART protocol Broadcom registered
[   15.625264] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   15.775728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.775743] Bluetooth: BNEP filters: protocol multicast
[   15.775756] Bluetooth: BNEP socket layer initialized
[   15.796318] NET: Registered PF_ALG protocol family
[   15.832549] cryptd: max_cpu_qlen set to 1000
[   15.954818] Bluetooth: RFCOMM TTY layer initialized
[   15.954851] Bluetooth: RFCOMM socket layer initialized
[   15.954883] Bluetooth: RFCOMM ver 1.11
[   17.201567] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[   25.276246] logitech-hidpp-device 0003:046D:4055.0006: HID++ 4.5 device connected.
[   31.836026] cam-dummy-reg: disabling
[  737.948310] ieee80211 phy0: brcmf_run_escan: error (-52)
[  737.948331] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[  917.951027] ieee80211 phy0: brcmf_run_escan: error (-52)
[  917.951040] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[ 1097.954295] ieee80211 phy0: brcmf_run_escan: error (-52)
[ 1097.954308] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[ 1739.199034] v3d fec00000.v3d: MMU error from client CLE (4) at 0xcb61000, pte invalid
[email protected]:~ $ sudo i2cdetect -y 10
00:                         -- -- -- -- UU -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
I think this indicates there isn’t a wiring problem, not sure
I just want to know right now whether the camera hardware is alright or should I ask for a replacement from amazon. This would go very far.
