Cont…
libcamera-still -t 1000 -n:
libcamera-still: error while loading shared libraries: libcamera.so.0.0.4: cannot open shared object file: No such file or directory
dmesg:
[ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028848
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_hdmi=0 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=D8:3A:DD:13:72:DA vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=59c1aa35-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 7471364K/8245248K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 249596K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000337] Console: colour dummy device 80x25
[ 0.000955] printk: console [tty1] enabled
[ 0.001032] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.001074] pid_max: default: 32768 minimum: 301
[ 0.001223] LSM: Security Framework initializing
[ 0.001534] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001690] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.003052] cgroup: Disabling memory control group subsystem
[ 0.005457] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.005495] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005698] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005892] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.006373] rcu: Hierarchical SRCU implementation.
[ 0.006400] rcu: Max phase no-delay instances is 1000.
[ 0.007807] EFI services will not be available.
[ 0.008490] smp: Bringing up secondary CPUs …
[ 0.009625] Detected PIPT I-cache on CPU1
[ 0.009794] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.010999] Detected PIPT I-cache on CPU2
[ 0.011126] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.012299] Detected PIPT I-cache on CPU3
[ 0.012429] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.012581] smp: Brought up 1 node, 4 CPUs
[ 0.012673] SMP: Total of 4 processors activated.
[ 0.012695] CPU features: detected: 32-bit EL0 Support
[ 0.012714] CPU features: detected: 32-bit EL1 Support
[ 0.012737] CPU features: detected: CRC32 instructions
[ 0.012890] CPU: All CPU(s) started at EL2
[ 0.012927] alternatives: applying system-wide alternatives
[ 0.015200] devtmpfs: initialized
[ 0.027920] Enabled cp15_barrier support
[ 0.028031] Enabled setend support
[ 0.028272] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.028325] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.044853] pinctrl core: initialized pinctrl subsystem
[ 0.045805] DMI not present or invalid.
[ 0.046556] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.050313] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.050642] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.051611] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.051731] audit: initializing netlink subsys (disabled)
[ 0.052027] audit: type=2000 audit(0.048:1): state=initialized audit_enabled=0 res=1
[ 0.052699] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.052796] cpuidle: using governor menu
[ 0.053232] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.053452] ASID allocator initialised with 32768 entries
[ 0.053640] Serial: AMBA PL011 UART driver
[ 0.067833] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.088355] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.092369] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.108480] KASLR enabled
[ 0.139463] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.145480] SCSI subsystem initialized
[ 0.145767] usbcore: registered new interface driver usbfs
[ 0.145845] usbcore: registered new interface driver hub
[ 0.145925] usbcore: registered new device driver usb
[ 0.146339] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.146604] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.146997] pps_core: LinuxPPS API ver. 1 registered
[ 0.147021] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.147064] PTP clock support registered
[ 0.148303] vgaarb: loaded
[ 0.149232] clocksource: Switched to clocksource arch_sys_counter
[ 0.149963] VFS: Disk quotas dquot_6.6.0
[ 0.150066] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.150272] FS-Cache: Loaded
[ 0.150466] CacheFiles: Loaded
[ 0.161989] NET: Registered PF_INET protocol family
[ 0.163420] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.172569] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.172719] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.172769] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.173378] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.176291] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.176621] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.176813] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.177385] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.178336] RPC: Registered named UNIX socket transport module.
[ 0.178366] RPC: Registered udp transport module.
[ 0.178385] RPC: Registered tcp transport module.
[ 0.178404] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.178439] PCI: CLS 0 bytes, default 64
[ 0.181336] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.181791] kvm [1]: IPA Size Limit: 44 bits
[ 0.183195] kvm [1]: vgic interrupt IRQ9
[ 0.183450] kvm [1]: Hyp mode initialized successfully
[ 1.317652] Initialise system trusted keyrings
[ 1.318200] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.326171] zbud: loaded
[ 1.329292] NFS: Registering the id_resolver key type
[ 1.329351] Key type id_resolver registered
[ 1.329373] Key type id_legacy registered
[ 1.329503] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.329533] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.331053] Key type asymmetric registered
[ 1.331089] Asymmetric key parser ‘x509’ registered
[ 1.331187] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.331516] io scheduler mq-deadline registered
[ 1.331548] io scheduler kyber registered
[ 1.333898] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.342940] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.343014] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.343119] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.343219] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.344282] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.344316] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.344345] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.344440] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.344718] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.348703] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.349003] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.349234] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.349365] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.415325] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.415513] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.415653] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.416146] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.416905] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.416966] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.417003] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.417061] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.417093] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.418501] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 1.418542] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.428024] Console: switching to colour frame buffer device 240x67
[ 1.436406] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 1.449581] iproc-rng200 fe104000.rng: hwrng registered
[ 1.450235] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.451899] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.465848] brd: module loaded
[ 1.475242] loop: module loaded
[ 1.476200] Loading iSCSI transport class v2.0-870.
[ 1.481924] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.541397] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.542709] usbcore: registered new interface driver r8152
[ 1.542859] usbcore: registered new interface driver lan78xx
[ 1.542975] usbcore: registered new interface driver smsc95xx
[ 1.592056] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.592311] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.592395] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.593317] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.594510] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.594582] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.594668] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.595128] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.595214] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.595286] usb usb1: Product: xHCI Host Controller
[ 1.595340] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.595398] usb usb1: SerialNumber: 0000:01:00.0
[ 1.596237] hub 1-0:1.0: USB hub found
[ 1.596346] hub 1-0:1.0: 1 port detected
[ 1.597407] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.597500] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.597576] usb usb2: Product: xHCI Host Controller
[ 1.597633] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.597695] usb usb2: SerialNumber: 0000:01:00.0
[ 1.598448] hub 2-0:1.0: USB hub found
[ 1.598583] hub 2-0:1.0: 4 ports detected
[ 1.600543] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.600941] dwc_otg: FIQ enabled
[ 1.600953] dwc_otg: NAK holdoff enabled
[ 1.600964] dwc_otg: FIQ split-transaction FSM enabled
[ 1.600984] Module dwc_common_port init
[ 1.601640] usbcore: registered new interface driver uas
[ 1.601850] usbcore: registered new interface driver usb-storage
[ 1.602152] mousedev: PS/2 mouse device common for all mice
[ 1.611480] sdhci: Secure Digital Host Controller Interface driver
[ 1.613864] sdhci: Copyright(c) Pierre Ossman
[ 1.616883] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.623155] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.625935] hid: raw HID events driver (C) Jiri Kosina
[ 1.628474] usbcore: registered new interface driver usbhid
[ 1.630792] usbhid: USB HID core driver
[ 1.642612] NET: Registered PF_PACKET protocol family
[ 1.645183] Key type dns_resolver registered
[ 1.649135] registered taskstats version 1
[ 1.651585] Loading compiled-in X.509 certificates
[ 1.654776] Key type .fscrypt registered
[ 1.657014] Key type fscrypt-provisioning registered
[ 1.675672] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.678784] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.681173] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.692974] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.695719] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.699436] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.701788] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.734891] of_cfs_init
[ 1.738354] of_cfs_init: OK
[ 1.768562] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.771499] Waiting for root device PARTUUID=59c1aa35-02…
[ 1.827475] mmc1: new high speed SDIO card at address 0001
[ 1.849277] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.885327] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.888620] mmcblk0: mmc0:0001 SD16G 7.38 GiB
[ 1.894668] mmcblk0: p1 p2
[ 1.897456] mmcblk0: mmc0:0001 SD16G 7.38 GiB
[ 1.910957] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.913313] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.922049] devtmpfs: mounted
[ 1.933755] Freeing unused kernel memory: 4160K
[ 1.936204] Run /sbin/init as init process
[ 1.938489] with arguments:
[ 1.938500] /sbin/init
[ 1.938510] with environment:
[ 1.938519] HOME=/
[ 1.938528] TERM=linux
[ 2.004136] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.006530] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.008842] usb 1-1: Product: USB2.0 Hub
[ 2.014495] hub 1-1:1.0: USB hub found
[ 2.017132] hub 1-1:1.0: 4 ports detected
[ 2.313312] usb 1-1.2: new low-speed USB device number 3 using xhci_hcd
[ 2.392653] systemd[1]: System time before build time, advancing clock.
[ 2.435714] usb 1-1.2: New USB device found, idVendor=045e, idProduct=00f9, bcdDevice= 0.02
[ 2.438222] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.440592] usb 1-1.2: Product: Microsoft Wireless Desktop Receiver 3.1
[ 2.442994] usb 1-1.2: Manufacturer: Microsft
[ 2.590618] NET: Registered PF_INET6 protocol family
[ 2.594963] Segment Routing with IPv6
[ 2.597199] In-situ OAM (IOAM) with IPv6
[ 2.678307] systemd[1]: systemd 247.3-7+deb11u2 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.684389] systemd[1]: Detected architecture arm64.
[ 2.707646] systemd[1]: Set hostname to .
[ 3.484238] systemd[1]: Queued start job for default target Multi-User System.
[ 3.511038] systemd[1]: Created slice system-getty.slice.
[ 3.518162] systemd[1]: Created slice system-modprobe.slice.
[ 3.524682] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.531045] systemd[1]: Created slice User and Session Slice.
[ 3.537073] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.543116] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.549823] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.555851] systemd[1]: Reached target Local Encrypted Volumes.
[ 3.561839] systemd[1]: Reached target Paths.
[ 3.567708] systemd[1]: Reached target Slices.
[ 3.573518] systemd[1]: Reached target Swap.
[ 3.583300] systemd[1]: Listening on Syslog Socket.
[ 3.590203] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.596353] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.603494] systemd[1]: Listening on Journal Audit Socket.
[ 3.610184] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.616961] systemd[1]: Listening on Journal Socket.
[ 3.628359] systemd[1]: Listening on udev Control Socket.
[ 3.635287] systemd[1]: Listening on udev Kernel Socket.
[ 3.642132] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.669828] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.681345] systemd[1]: Mounting RPC Pipe File System…
[ 3.694360] systemd[1]: Mounting Kernel Debug File System…
[ 3.707405] systemd[1]: Mounting Kernel Trace File System…
[ 3.714780] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.724503] systemd[1]: Starting Restore / save the current clock…
[ 3.736317] systemd[1]: Starting Set the console keyboard layout…
[ 3.749298] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.762623] systemd[1]: Starting Load Kernel Module configfs…
[ 3.775786] systemd[1]: Starting Load Kernel Module drm…
[ 3.788422] systemd[1]: Starting Load Kernel Module fuse…
[ 3.803393] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.812094] systemd[1]: Starting File System Check on Root Device…
[ 3.830032] systemd[1]: Starting Journal Service…
[ 3.845439] fuse: init (API version 7.37)
[ 3.849474] systemd[1]: Starting Load Kernel Modules…
[ 3.886747] systemd[1]: Starting Coldplug All udev Devices…
[ 3.933904] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.946367] systemd[1]: Mounted RPC Pipe File System.
[ 3.959609] systemd[1]: Mounted Kernel Debug File System.
[ 3.972736] systemd[1]: Mounted Kernel Trace File System.
[ 3.984619] systemd[1]: Finished Restore / save the current clock.
[ 4.005188] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 4.014482] systemd[1]: [email protected]: Succeeded.
[ 4.019700] systemd[1]: Finished Load Kernel Module configfs.
[ 4.028472] systemd[1]: [email protected]: Succeeded.
[ 4.033068] systemd[1]: Finished Load Kernel Module drm.
[ 4.042409] systemd[1]: [email protected]: Succeeded.
[ 4.047331] systemd[1]: Finished Load Kernel Module fuse.
[ 4.056400] systemd[1]: Finished Load Kernel Modules.
[ 4.076040] systemd[1]: Finished File System Check on Root Device.
[ 4.106017] systemd[1]: Mounting FUSE Control File System…
[ 4.127780] systemd[1]: Mounting Kernel Configuration File System…
[ 4.139541] systemd[1]: Started File System Check Daemon to report status.
[ 4.151911] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 4.163988] systemd[1]: Starting Apply Kernel Variables…
[ 4.191261] systemd[1]: Started Journal Service.
[ 4.340466] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.427847] systemd-journald[151]: Received client request to flush runtime journal.
[ 4.447682] systemd-journald[151]: File /var/log/journal/f6db934d244045fe917ad0382de3699c/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.615978] mc: Linux media interface: v0.10
[ 5.692176] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.713537] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.772217] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.772267] [vc_sm_connected_init]: start
[ 5.791415] [vc_sm_connected_init]: installed successfully
[ 5.816767] videodev: Linux video capture interface: v2.00
[ 5.820382] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 5.855111] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 5.905350] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.107313] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.122350] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.176119] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.189412] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.217932] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.222569] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.247751] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.247852] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.263073] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.263137] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.272445] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.272520] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.286732] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.293198] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.294336] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.294396] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.296781] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.310124] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.310186] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.310210] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.310249] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.310267] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.330535] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.368228] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 6.368622] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.368676] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.385528] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.442454] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.473355] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.473420] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.473447] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.473466] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.473485] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.577492] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.710277] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 6.762527] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 6.778869] Console: switching to colour dummy device 80x25
[ 6.782925] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 6.882889] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 6.924567] Registered IR keymap rc-cec
[ 6.961076] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 6.977549] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.067285] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.289614] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 7.318530] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 7.332098] usbcore: registered new interface driver brcmfmac
[ 7.374631] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.511050] Registered IR keymap rc-cec
[ 7.539582] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.640933] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input1
[ 7.766275] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.767043] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.767569] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.768483] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.769087] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.769899] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.770452] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.771967] input: Microsft Microsoft Wireless Desktop Receiver 3.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/0003:045E:00F9.0001/input/input2
[ 7.812580] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 7.830606] microsoft 0003:045E:00F9.0001: input,hidraw0: USB HID v1.11 Keyboard [Microsft Microsoft Wireless Desktop Receiver 3.1] on usb-0000:01:00.0-1.2/input0
[ 7.830840] microsoft 0003:045E:00F9.0002: fixing up Microsoft Wireless Receiver Model 1028 report descriptor
[ 7.842818] input: Microsft Microsoft Wireless Desktop Receiver 3.1 as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.1/0003:045E:00F9.0002/input/input3
[ 7.902133] microsoft 0003:045E:00F9.0002: input,hidraw1: USB HID v1.11 Mouse [Microsft Microsoft Wireless Desktop Receiver 3.1] on usb-0000:01:00.0-1.2/input1
[ 7.919919] Console: switching to colour frame buffer device 240x67
[ 7.946163] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 8.263359] uart-pl011 fe201000.serial: no DMA platform data
[ 8.284610] 8021q: 802.1Q VLAN Support v1.8
[ 8.366381] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 8.788987] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.088160] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 9.089811] bcmgenet fd580000.ethernet eth0: Link is Down
[ 14.821356] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.375971] Bluetooth: Core ver 2.22
[ 16.376062] NET: Registered PF_BLUETOOTH protocol family
[ 16.376067] Bluetooth: HCI device and connection manager initialized
[ 16.376083] Bluetooth: HCI socket layer initialized
[ 16.376092] Bluetooth: L2CAP socket layer initialized
[ 16.376110] Bluetooth: SCO socket layer initialized
[ 16.384692] Bluetooth: HCI UART driver ver 2.3
[ 16.384714] Bluetooth: HCI UART protocol H4 registered
[ 16.384789] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.384958] Bluetooth: HCI UART protocol Broadcom registered
[ 16.455220] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 16.771887] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 16.771907] Bluetooth: BNEP filters: protocol multicast
[ 16.771922] Bluetooth: BNEP socket layer initialized
[ 16.776371] Bluetooth: MGMT ver 1.22
[ 16.787162] NET: Registered PF_ALG protocol family
