I am testing these 2 cameras in parallel to determine cameras suitable for a larger project.
I am using CM4 2RAM / 8EMMC.
In general I am very happy with the camera picture quality. Especially the 64MP is incredible. Well done ArduCam!
Manual and autofocus works nicely and is very controllable via software.
The following questions are to iron out some kinks I have encountered. I read the docs, the forum post here and here.
RAW in 64MP
It is possible to capture a DNG file with this command in full resolution:
libcamera-still --camera 0 -t 2000 --verbose 2 --rawfull --encoding png -o 64mp.png --raw --shutter 100000 --autofocus-on-capture
My goal would be to be able to do this as RAW, but at full resolution. There seems to be a known problem, but none of the linked pages lead to a success:
This command works, with a little warning:
libcamera-raw -t 1100 --camera 0 --segment 1 -o test%05d.raw --width 4656 --height 3496
WARNING
[0:22:50.348974573] [7727] INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4225-74d023d8
[0:22:50.372090248] [7728] WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for ‘arducam_64mp’
[0:22:50.372193284] [7728] WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:22:50.477673572] [7728] WARN RPI raspberrypi.cpp:1357 Mismatch between Unicam and CamHelper for embedded data usage!
[0:22:50.478737206] [7728] INFO RPI raspberrypi.cpp:1476 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media4 and ISP device /dev/media1
writes a raw file, but this one fails:
libcamera-raw -t 1100 --camera 0 --segment 1 -o test%05d.raw --width 9152 --height 6944
INFO Camera camera.cpp:1028 configuring streams: (0) 9152x6944-YUV420 (1) 9152x6944-SRGGB10_CSI2P
INFO RPI raspberrypi.cpp:851 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 9152x6944-SRGGB10_1X10 - Selected unicam format: 9152x6944-pRAA
ERROR V4L2 v4l2_videodevice.cpp:1248 /dev/video14[15:cap]: Not enough buffers provided by V4L2VideoDevice
ERROR: *** failed to allocate capture buffers ***
My config.txt settings should be ok - I tried to pull all info from the linked posts.
DUAL CAMERA OPERATION
When I connect 16MP/16MP there are no issues. Both can be controlled as advertised.
When I connect 64MP/16MP there are no issues. Both can be controlled as advertised.
I had on of the 5 16MP experience a hardware issue that has been since replaced.
Please advise.
