Pre-Order via ArduCam’s website -
ArduCam 64MP Auto Focus Camera -
Raspberry Pi 4 running MainSail -
arducam_64mp_pi_camera_manual.pdf
How to use arducam_64mp - #2 by Edward -
When attempting to use any libcamera commands i receive the following:
libcamera-still -t 0
libcamera-still: error while loading shared libraries: libepoxy.so.0: cannot open shared object file: No such file or directory -
[email protected]:~ $ dmesg
[ 0.000000] Linux version 5.10.103-v7l+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x000000007fffffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[ 0.000000] On node 0 totalpages: 504832
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 308224 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 503104
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=DC:A6:32:B4:92:E6 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=tty1 root=PARTUUID=150941f9-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] software IO TLB: mapped [mem 0x0000000009a00000-0x000000000da00000] (64MB)
[ 0.000000] Memory: 1390388K/2019328K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 104652K reserved, 524288K cma-reserved, 1232896K highmem)
[ 0.000000] ftrace: allocating 34355 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 25)
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000095] bcm2835: system timer (irq = 26)
[ 0.000745] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000766] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000789] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000806] Switching to timer-based delay loop, resolution 18ns
[ 0.001066] Console: colour dummy device 80x30
[ 0.001811] printk: console [tty1] enabled
[ 0.001875] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[ 0.001931] pid_max: default: 32768 minimum: 301
[ 0.002107] LSM: Security Framework initializing
[ 0.002306] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002352] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003827] cgroup: Disabling memory control group subsystem
[ 0.004074] CPU: Testing write buffer coherency: ok
[ 0.004549] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005768] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005983] rcu: Hierarchical SRCU implementation.
[ 0.006921] smp: Bringing up secondary CPUs ...
[ 0.008134] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009484] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010800] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010957] smp: Brought up 1 node, 4 CPUs
[ 0.011004] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011034] CPU: All CPU(s) started in HYP mode.
[ 0.011061] CPU: Virtualization extensions available.
[ 0.011908] devtmpfs: initialized
[ 0.025900] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026150] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026204] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.039007] pinctrl core: initialized pinctrl subsystem
[ 0.040078] NET: Registered protocol family 16
[ 0.043971] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.044803] audit: initializing netlink subsys (disabled)
[ 0.045079] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.045641] thermal_sys: Registered thermal governor 'step_wise'
[ 0.046301] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.046355] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.046770] Serial: AMBA PL011 UART driver
[ 0.089779] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.110926] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:01:54, variant start
[ 0.120939] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.161018] Kprobes globally optimized
[ 0.166474] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.170834] vgaarb: loaded
[ 0.171464] SCSI subsystem initialized
[ 0.171705] usbcore: registered new interface driver usbfs
[ 0.171784] usbcore: registered new interface driver hub
[ 0.171885] usbcore: registered new device driver usb
[ 0.172315] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.174229] clocksource: Switched to clocksource arch_sys_counter
[ 1.120254] VFS: Disk quotas dquot_6.6.0
[ 1.120376] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.120557] FS-Cache: Loaded
[ 1.120772] CacheFiles: Loaded
[ 1.131786] NET: Registered protocol family 2
[ 1.132044] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.133363] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.133532] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.134022] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.134107] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.134323] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.134380] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.134637] NET: Registered protocol family 1
[ 1.135418] RPC: Registered named UNIX socket transport module.
[ 1.135451] RPC: Registered udp transport module.
[ 1.135480] RPC: Registered tcp transport module.
[ 1.135508] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.135545] PCI: CLS 0 bytes, default 64
[ 1.138764] Initialise system trusted keyrings
[ 1.139021] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[ 1.147367] zbud: loaded
[ 1.149117] FS-Cache: Netfs 'nfs' registered for caching
[ 1.149880] NFS: Registering the id_resolver key type
[ 1.149955] Key type id_resolver registered
[ 1.149984] Key type id_legacy registered
[ 1.150148] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.150181] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.151225] Key type asymmetric registered
[ 1.151257] Asymmetric key parser 'x509' registered
[ 1.151463] bounce: pool size: 64 pages
[ 1.151521] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.151776] io scheduler mq-deadline registered
[ 1.151807] io scheduler kyber registered
[ 1.156607] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.156661] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.156763] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.156872] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[ 1.216337] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.216744] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.216783] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.216818] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.216931] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.217189] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.220658] PCI: bus0: Fast back to back transfers disabled
[ 1.220699] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.221141] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.221285] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.221736] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.225214] PCI: bus1: Fast back to back transfers disabled
[ 1.225252] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.225344] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.225385] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.225487] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.225527] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.225967] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[ 1.226229] pcieport 0000:00:00.0: PME: Signaling with IRQ 81
[ 1.236155] iproc-rng200 fe104000.rng: hwrng registered
[ 1.236556] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.237490] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.249835] brd: module loaded
[ 1.262180] loop: module loaded
[ 1.264006] Loading iSCSI transport class v2.0-870.
[ 1.269131] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.364392] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.365561] usbcore: registered new interface driver r8152
[ 1.365660] usbcore: registered new interface driver lan78xx
[ 1.365738] usbcore: registered new interface driver smsc95xx
[ 1.367368] xhci_hcd 0000:01:00.0: enabling device (0140 -> 0142)
[ 1.367549] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.367600] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.370964] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.372310] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.372351] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.372388] usb usb1: Product: xHCI Host Controller
[ 1.372419] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.372450] usb usb1: SerialNumber: 0000:01:00.0
[ 1.373202] hub 1-0:1.0: USB hub found
[ 1.373316] hub 1-0:1.0: 1 port detected
[ 1.374004] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.374049] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.374095] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.374734] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.374775] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.374811] usb usb2: Product: xHCI Host Controller
[ 1.374841] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.374872] usb usb2: SerialNumber: 0000:01:00.0
[ 1.375598] hub 2-0:1.0: USB hub found
[ 1.375691] hub 2-0:1.0: 4 ports detected
[ 1.377492] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.377884] dwc_otg: FIQ enabled
[ 1.377898] dwc_otg: NAK holdoff enabled
[ 1.377913] dwc_otg: FIQ split-transaction FSM enabled
[ 1.377931] Module dwc_common_port init
[ 1.378407] usbcore: registered new interface driver uas
[ 1.378532] usbcore: registered new interface driver usb-storage
[ 1.378751] mousedev: PS/2 mouse device common for all mice
[ 1.380543] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.384012] sdhci: Secure Digital Host Controller Interface driver
[ 1.384047] sdhci: Copyright(c) Pierre Ossman
[ 1.384868] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.385520] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.389778] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.390144] hid: raw HID events driver (C) Jiri Kosina
[ 1.390368] usbcore: registered new interface driver usbhid
[ 1.390399] usbhid: USB HID core driver
[ 1.396545] Initializing XFRM netlink socket
[ 1.396607] NET: Registered protocol family 17
[ 1.396746] Key type dns_resolver registered
[ 1.397079] Registering SWP/SWPB emulation handler
[ 1.397260] registered taskstats version 1
[ 1.397300] Loading compiled-in X.509 certificates
[ 1.398155] Key type ._fscrypt registered
[ 1.398187] Key type .fscrypt registered
[ 1.398215] Key type fscrypt-provisioning registered
[ 1.410019] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.410348] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.410438] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 38, base_baud = 0) is a PL011 rev2
[ 1.417126] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.418216] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.418250] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.448582] of_cfs_init
[ 1.448865] of_cfs_init: OK
[ 1.470549] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.472273] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.474165] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.477202] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.478904] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.484317] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.484966] Waiting for root device PARTUUID=150941f9-02...
[ 1.562136] mmc1: new high speed SDIO card at address 0001
[ 1.594656] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.595559] mmcblk0: mmc0:aaaa SK32G 29.7 GiB
[ 1.597520] mmcblk0: p1 p2
[ 1.615093] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.615190] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.620217] devtmpfs: mounted
[ 1.630518] Freeing unused kernel memory: 2048K
[ 1.654277] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.664571] Run /sbin/init as init process
[ 1.664601] with arguments:
[ 1.664616] /sbin/init
[ 1.664631] with environment:
[ 1.664645] HOME=/
[ 1.664659] TERM=linux
[ 1.846923] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.846972] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.847006] usb 1-1: Product: USB2.0 Hub
[ 1.849374] hub 1-1:1.0: USB hub found
[ 1.849664] hub 1-1:1.0: 4 ports detected
[ 2.049400] systemd[1]: System time before build time, advancing clock.
[ 2.152405] NET: Registered protocol family 10
[ 2.153889] Segment Routing with IPv6
[ 2.211253] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.212959] systemd[1]: Detected architecture arm.
[ 2.274030] systemd[1]: Set hostname to <mainsail>.
[ 2.943102] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.953282] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.955957] systemd[1]: Created slice User and Session Slice.
[ 2.956585] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.957253] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.962948] systemd[1]: Listening on Syslog Socket.
[ 2.964091] systemd[1]: Listening on udev Control Socket.
[ 2.964582] systemd[1]: Reached target Swap.
[ 2.967140] systemd[1]: Created slice system-getty.slice.
[ 2.967878] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.090918] i2c /dev entries driver
[ 3.561085] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.686416] systemd-journald[125]: Received request to flush runtime journal from PID 1
[ 4.204572] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 4.205136] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 4.205682] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 4.206258] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 4.329869] mc: Linux media interface: v0.10
[ 4.373380] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.379411] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 4.379438] [vc_sm_connected_init]: start
[ 4.379970] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.390598] [vc_sm_connected_init]: installed successfully
[ 4.414689] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 4.427047] videodev: Linux video capture interface: v2.00
[ 4.449870] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.464404] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.496684] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.508218] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.508268] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.513980] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.514028] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.524529] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.524585] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.527644] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 4.527693] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 4.541420] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.558652] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 4.559399] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 4.624446] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.625091] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.625552] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.625873] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.625903] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.625936] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.625959] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.625982] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.626206] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.722738] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.783369] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 4.805927] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.906177] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 4.923263] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.940269] Registered IR keymap rc-cec
[ 4.940468] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 4.940723] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input0
[ 4.941733] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 4.943397] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.947935] usbcore: registered new interface driver brcmfmac
[ 5.044489] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.062011] Registered IR keymap rc-cec
[ 5.062199] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.062424] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input1
[ 5.063381] vc4_hdmi fef00700.hdmi: Could not register sound card: -517
[ 5.225319] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.225445] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 5.238471] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 5.397246] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 5.408136] Registered IR keymap rc-cec
[ 5.408343] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 5.408564] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 5.411573] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.420234] Registered IR keymap rc-cec
[ 5.420484] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 5.420700] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input3
[ 5.424075] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 5.428523] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 5.428909] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.429242] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.429554] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.429821] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.430121] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 5.457386] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 5.457569] vc4-drm gpu: [drm] Cannot find any crtc or sizes
[ 7.348512] 8021q: 802.1Q VLAN Support v1.8
[ 7.356684] random: crng init done
[ 7.356706] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.574467] Adding 262140k swap on /var/swap. Priority:-2 extents:1 across:262140k SSFS
[ 7.688447] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 8.006072] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 8.006570] bcmgenet fd580000.ethernet eth0: Link is Down
[ 12.154554] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 12.154610] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 13.174023] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.426609] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save disabled
Uninstalling and reinstalling all drivers and libcamera-dev and app -
I would like to be able to use the camera in general, and then see if its possible to use it inside of mailsail for my 3d printer
