Followed the guides, checked the cabling.
ls /dev/video shows
ls /dev/video*
/dev/video10 /dev/video12 /dev/video14 /dev/video16
/dev/video11 /dev/video13 /dev/video15 /dev/video18
Need to get the camera working
No cameras available
# http://rpf.io/configtxt
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
dtparam=audio=on
start_x=1
gpu_mem=128
dtoverlay=vc4-kms-v3d,cma-512
I also tried with
dtoverlay=arducam-64mp
instead of the dtoverlay line written above
dmesg | grep libcamera and
dmesg | grep arducam come up empty
I did all of that already. Drivers are instelld, both applications as well. Been playing around with the config.txt. I had both in there → just reinserted both lines, still no camera being detected.
I just ran the commands again, the driver install added the
dtoverlay=arducam-64mp again. No luck.
So i switched out the cable, had a working camera for about 5 minutes while I was trying to get a higher resolution than 1920x1080
Now “no cameras available” again…
I got no idea what is going on here.
[ 0.098604] platform 3f801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/[email protected]/[email protected]
[ 14.306458] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 14.315629] arducam_64mp: probe of 10-001a failed with error -5
