dmesg
[ 1.367117] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.367159] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.367251] brcm-pcie fd500000.pcie: MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[ 1.367338] brcm-pcie fd500000.pcie: IB MEM 0x0000000000..0x00bfffffff -> 0x0400000000
[ 1.368406] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.368427] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.368446] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.368529] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.368798] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.373120] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.373310] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.373440] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.419813] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.419987] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.420116] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.420630] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.421421] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.421450] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.421495] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.421519] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.422949] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes
[ 1.422973] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.423592] Console: switching to colour frame buffer device 240x67
[ 1.432349] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 1.446019] iproc-rng200 fe104000.rng: hwrng registered
[ 1.446664] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.448359] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.462170] brd: module loaded
[ 1.471354] loop: module loaded
[ 1.472340] Loading iSCSI transport class v2.0-870.
[ 1.478167] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.537886] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.539122] usbcore: registered new interface driver r8152
[ 1.539208] usbcore: registered new interface driver lan78xx
[ 1.539270] usbcore: registered new interface driver smsc95xx
[ 1.540914] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.540960] xhci_hcd 0000:01:00.0: enabling device (0000 -> 0002)
[ 1.541087] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.541123] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.541950] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.542677] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.542700] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.542725] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.543143] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.543165] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.543181] usb usb1: Product: xHCI Host Controller
[ 1.543194] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.543207] usb usb1: SerialNumber: 0000:01:00.0
[ 1.543992] hub 1-0:1.0: USB hub found
[ 1.544091] hub 1-0:1.0: 1 port detected
[ 1.545113] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.01
[ 1.545134] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.545150] usb usb2: Product: xHCI Host Controller
[ 1.545163] usb usb2: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
[ 1.545176] usb usb2: SerialNumber: 0000:01:00.0
[ 1.545973] hub 2-0:1.0: USB hub found
[ 1.546063] hub 2-0:1.0: 4 ports detected
[ 1.547971] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.548349] dwc_otg: FIQ enabled
[ 1.548362] dwc_otg: NAK holdoff enabled
[ 1.548372] dwc_otg: FIQ split-transaction FSM enabled
[ 1.548391] Module dwc_common_port init
[ 1.548997] usbcore: registered new interface driver uas
[ 1.549107] usbcore: registered new interface driver usb-storage
[ 1.549351] mousedev: PS/2 mouse device common for all mice
[ 1.555971] sdhci: Secure Digital Host Controller Interface driver
[ 1.555995] sdhci: Copyright(c) Pierre Ossman
[ 1.556750] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.560615] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.561076] hid: raw HID events driver (C) Jiri Kosina
[ 1.561257] usbcore: registered new interface driver usbhid
[ 1.561270] usbhid: USB HID core driver
[ 1.570920] NET: Registered PF_PACKET protocol family
[ 1.571061] Key type dns_resolver registered
[ 1.572585] registered taskstats version 1
[ 1.572669] Loading compiled-in X.509 certificates
[ 1.573642] Key type .fscrypt registered
[ 1.573657] Key type fscrypt-provisioning registered
[ 1.590334] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.591101] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.591293] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.600720] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.601200] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.602613] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.602635] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.631371] of_cfs_init
[ 1.631605] of_cfs_init: OK
[ 1.666866] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.667268] Waiting for root device PARTUUID=88033f92-02...
[ 1.717575] mmc1: new high speed SDIO card at address 0001
[ 1.777813] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.778964] mmcblk0: mmc0:0001 SPCC 29.8 GiB
[ 1.782516] mmcblk0: p1 p2
[ 1.783154] mmcblk0: mmc0:0001 SPCC 29.8 GiB
[ 1.797836] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.805160] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Quota mode: none.
[ 1.805267] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.806184] devtmpfs: mounted
[ 1.815242] Freeing unused kernel memory: 4160K
[ 1.815465] Run /sbin/init as init process
[ 1.815476] with arguments:
[ 1.815486] /sbin/init
[ 1.815496] splash
[ 1.815505] with environment:
[ 1.815514] HOME=/
[ 1.815524] TERM=linux
[ 1.948418] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.948461] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.948478] usb 1-1: Product: USB2.0 Hub
[ 1.950791] hub 1-1:1.0: USB hub found
[ 1.951064] hub 1-1:1.0: 4 ports detected
[ 2.172189] systemd[1]: System time before build time, advancing clock.
[ 2.245761] usb 1-1.1: new full-speed USB device number 3 using xhci_hcd
[ 2.354229] usb 1-1.1: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.11
[ 2.354269] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.354287] usb 1-1.1: Product: USB Receiver
[ 2.354301] usb 1-1.1: Manufacturer: Logitech
[ 2.366023] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:046D:C52B.0001/input/input0
[ 2.385998] NET: Registered PF_INET6 protocol family
[ 2.388082] Segment Routing with IPv6
[ 2.388132] In-situ OAM (IOAM) with IPv6
[ 2.426977] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input0
[ 2.436817] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52B.0002/input/input1
[ 2.437468] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52B.0002/input/input2
[ 2.461776] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.462883] systemd[1]: Detected architecture arm64.
[ 2.465168] systemd[1]: Set hostname to <raspberrypi>.
[ 2.494200] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:046D:C52B.0002/input/input3
[ 2.494793] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input1
[ 2.503151] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input2
[ 3.202402] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.400955] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.425490] systemd[1]: Created slice system-getty.slice.
[ 3.427166] systemd[1]: Created slice system-modprobe.slice.
[ 3.428316] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.429231] systemd[1]: Created slice User and Session Slice.
[ 3.429954] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.431420] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.432193] systemd[1]: Reached target Slices.
[ 3.432457] systemd[1]: Reached target Swap.
[ 3.433683] systemd[1]: Listening on Syslog Socket.
[ 3.434566] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.435092] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.436552] systemd[1]: Listening on Journal Audit Socket.
[ 3.437481] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.438767] systemd[1]: Listening on Journal Socket.
[ 3.443576] systemd[1]: Listening on udev Control Socket.
[ 3.444649] systemd[1]: Listening on udev Kernel Socket.
[ 3.445916] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.474283] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.479562] systemd[1]: Mounting RPC Pipe File System...
[ 3.485528] systemd[1]: Mounting Kernel Debug File System...
[ 3.491727] systemd[1]: Mounting Kernel Trace File System...
[ 3.492302] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.500712] systemd[1]: Starting Restore / save the current clock...
[ 3.507260] systemd[1]: Starting Set the console keyboard layout...
[ 3.513804] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 3.520724] systemd[1]: Starting Load Kernel Module configfs...
[ 3.527154] systemd[1]: Starting Load Kernel Module drm...
[ 3.540387] systemd[1]: Starting Load Kernel Module fuse...
[ 3.544850] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.550685] systemd[1]: Starting File System Check on Root Device...
[ 3.563046] systemd[1]: Starting Journal Service...
[ 3.623022] systemd[1]: Starting Load Kernel Modules...
[ 3.629790] systemd[1]: Starting Coldplug All udev Devices...
[ 3.637361] fuse: init (API version 7.37)
[ 3.664860] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.666028] systemd[1]: Mounted RPC Pipe File System.
[ 3.667758] systemd[1]: Mounted Kernel Debug File System.
[ 3.668758] systemd[1]: Mounted Kernel Trace File System.
[ 3.671526] systemd[1]: Finished Restore / save the current clock.
[ 3.678481] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.681347] systemd[1]: [email protected]: Succeeded.
[ 3.683069] systemd[1]: Finished Load Kernel Module configfs.
[ 3.686570] systemd[1]: [email protected]: Succeeded.
[ 3.688347] systemd[1]: Finished Load Kernel Module fuse.
[ 3.726705] systemd[1]: Mounting FUSE Control File System...
[ 3.745166] systemd[1]: Mounting Kernel Configuration File System...
[ 3.750789] systemd[1]: Started File System Check Daemon to report status.
[ 3.761166] systemd[1]: Mounted FUSE Control File System.
[ 3.762962] systemd[1]: Mounted Kernel Configuration File System.
[ 3.772365] i2c_dev: i2c /dev entries driver
[ 3.789784] systemd[1]: Finished Load Kernel Modules.
[ 3.799284] systemd[1]: [email protected]: Succeeded.
[ 3.800842] systemd[1]: Finished Load Kernel Module drm.
[ 3.835106] systemd[1]: Starting Apply Kernel Variables...
[ 3.864748] systemd[1]: Finished File System Check on Root Device.
[ 3.870954] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.891819] systemd[1]: Finished Apply Kernel Variables.
[ 4.003734] systemd[1]: Started Journal Service.
[ 4.044691] EXT4-fs (mmcblk0p2): re-mounted. Quota mode: none.
[ 4.116394] systemd-journald[142]: Received client request to flush runtime journal.
[ 4.127703] systemd-journald[142]: File /var/log/journal/0eb54956fefa4f7480d0ce661475daaa/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.994746] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.004836] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 6.004882] [vc_sm_connected_init]: start
[ 6.012502] [vc_sm_connected_init]: installed successfully
[ 6.054232] mc: Linux media interface: v0.10
[ 6.239588] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.240777] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.243026] videodev: Linux video capture interface: v2.00
[ 6.260753] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.284419] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.486086] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.544248] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.561511] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.598974] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.657109] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.668558] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.696023] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.707475] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.717142] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.733413] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.735703] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.736536] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.737275] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.738560] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.738625] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.738651] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.738671] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.738689] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.748179] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.748995] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.752727] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.778304] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.778363] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.778387] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.778408] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.778426] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.781248] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 6.856587] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.856660] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.878444] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.878548] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.936061] Console: switching to colour dummy device 80x25
[ 6.968457] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.968525] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.994078] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.009125] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.009214] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.021137] Registered IR keymap rc-cec
[ 7.026369] rc rc0: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.026634] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.026952] input: vc4-hdmi-0 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input5
[ 7.081283] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 7.081348] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 7.091963] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 7.104941] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.301272] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.404424] Registered IR keymap rc-cec
[ 7.405452] rc rc1: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.406133] input: vc4-hdmi-1 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input6
[ 7.433661] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.491349] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.506066] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.520343] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 1
[ 7.533042] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.549422] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.550771] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.551515] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.554542] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.560429] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.579324] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 0
[ 7.655078] usbcore: registered new interface driver brcmfmac
[ 7.696838] Console: switching to colour frame buffer device 240x67
[ 7.696920] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 7.815125] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 9.080089] uart-pl011 fe201000.serial: no DMA platform data
[ 9.163458] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 9.164700] arducam_64mp: loading out-of-tree module taints kernel.
[ 9.176879] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.1/input2
[ 9.559532] input: Logitech Wireless Device PID:404d Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input7
[ 9.890178] arducam_64mp 10-001a: Device found Arducam 64MP.
[ 9.944122] input: Logitech Wireless Device PID:404d Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input8
[ 9.954831] arducam_64mp 10-001a: Consider updating driver arducam_64mp to match on endpoints
[ 10.122531] hid-generic 0003:046D:404D.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech Wireless Device PID:404d] on usb-0000:01:00.0-1.1/input2:1
[ 10.892170] 8021q: 802.1Q VLAN Support v1.8
[ 11.031937] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 11.149292] input: Logitech K400 Plus as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.2/0003:046D:C52B.0003/0003:046D:404D.0004/input/input12
[ 11.150604] logitech-hidpp-device 0003:046D:404D.0004: input,hidraw1: USB HID v1.11 Keyboard [Logitech K400 Plus] on usb-0000:01:00.0-1.1/input2:1
[ 11.201344] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 11.203385] bcmgenet fd580000.ethernet eth0: Link is Down
[ 16.462171] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 16.879831] Bluetooth: Core ver 2.22
[ 16.879947] NET: Registered PF_BLUETOOTH protocol family
[ 16.879953] Bluetooth: HCI device and connection manager initialized
[ 16.879980] Bluetooth: HCI socket layer initialized
[ 16.879990] Bluetooth: L2CAP socket layer initialized
[ 16.880006] Bluetooth: SCO socket layer initialized
[ 16.911831] Bluetooth: HCI UART driver ver 2.3
[ 16.911854] Bluetooth: HCI UART protocol H4 registered
[ 16.911937] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 16.912140] Bluetooth: HCI UART protocol Broadcom registered
[ 17.259423] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 17.259446] Bluetooth: BNEP filters: protocol multicast
[ 17.259464] Bluetooth: BNEP socket layer initialized
[ 17.266515] Bluetooth: MGMT ver 1.22
[ 17.292214] NET: Registered PF_ALG protocol family
[ 17.413206] Bluetooth: RFCOMM TTY layer initialized
[ 17.413240] Bluetooth: RFCOMM socket layer initialized
[ 17.413260] Bluetooth: RFCOMM ver 1.11
[ 29.969577] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 29.969599] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 29.969631] unicam fe801000.csi: stream on failed in subdev
[ 29.971704] unicam fe801000.csi: Runtime PM usage count underflow!
[ 57.014697] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 57.014719] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 57.014751] unicam fe801000.csi: stream on failed in subdev
[ 57.016726] unicam fe801000.csi: Runtime PM usage count underflow!
[ 60.746960] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 60.746982] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 60.747013] unicam fe801000.csi: stream on failed in subdev
[ 60.748923] unicam fe801000.csi: Runtime PM usage count underflow!
[ 74.397452] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 74.397473] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 74.397549] unicam fe801000.csi: stream on failed in subdev
[ 74.399449] unicam fe801000.csi: Runtime PM usage count underflow!
[ 76.859945] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 76.859967] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 76.859999] unicam fe801000.csi: stream on failed in subdev
[ 76.862066] unicam fe801000.csi: Runtime PM usage count underflow!
[ 302.438352] logitech-hidpp-device 0003:046D:404D.0004: HID++ 4.1 device connected.
[ 309.620015] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 309.620051] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 309.620119] unicam fe801000.csi: stream on failed in subdev
[ 309.620905] unicam fe801000.csi: Runtime PM usage count underflow!
[ 351.519460] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 378.309517] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 378.309538] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 378.309570] unicam fe801000.csi: stream on failed in subdev
[ 378.311473] unicam fe801000.csi: Runtime PM usage count underflow!
[ 413.442146] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 413.442169] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 413.442202] unicam fe801000.csi: stream on failed in subdev
[ 413.444148] unicam fe801000.csi: Runtime PM usage count underflow!
[ 1002.506011] arducam_64mp 10-001a: Failed to write reg 0x0100. error = -5
[ 1002.506032] arducam_64mp 10-001a: arducam_64mp_start_streaming failed to set common settings
[ 1002.506062] unicam fe801000.csi: stream on failed in subdev
[ 1002.508219] unicam fe801000.csi: Runtime PM usage count underflow!
