pi 3b+ with pi OS bullseye
Instructions you have followed. (link/manual/etc.) Redirecting...
Problems you were having.
initially there were no cameras detected, then i got input/output error, and now with bullseye this is the closest i’ve gotten
Troubleshooting attempts you’ve made.
different OS, different hardware, check cables, different order of installing apps, restart, different power cables/PSUs
I want the hardware I bought to work.
I’m getting this error in the terminal
ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
There is a problem with the camera, or the camera is not a module in the Quad-HAT kit.
Can you provide a picture of the relevant hardware connection for this? Preferably with details on the back of the camera (the case needs to be removed for this)
Thank you so much for the help Wong! Installing the low speed drivers got an image output, but I’m still getting errors in the terminal while the preview is running
pi@raspberrypi:~ $ libcamera-still -t 5000 -o test.jpg --autofocus
[0:03:04.079345501] [1267] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[0:03:04.127396699] [1269] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for ‘imx519’
[0:03:04.127574460] [1269] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:03:04.621073314] [1269] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/video0
[0:03:04.627274095] [1267] INFO Camera camera.cpp:937 configuring streams: (0) 2048x1536-YUV420
[0:03:04.628300866] [1269] INFO RPI raspberrypi.cpp:122 Mode: 4656x3496 fmt RG10 Score: 2646.58 (best 2646.58)
[0:03:04.628458157] [1269] INFO RPI raspberrypi.cpp:122 Mode: 3840x2160 fmt RG10 Score: 2270.67 (best 2270.67)
[0:03:04.628531022] [1269] INFO RPI raspberrypi.cpp:122 Mode: 2328x1748 fmt RG10 Score: 1627.58 (best 1627.58)
[0:03:04.628602636] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1920x1080 fmt RG10 Score: 2834.67 (best 1627.58)
[0:03:04.628672793] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1280x720 fmt RG10 Score: 4834.67 (best 1627.58)
[0:03:04.628749564] [1269] INFO RPI raspberrypi.cpp:122 Mode: 4656x3496 fmt pRAA Score: 2146.58 (best 1627.58)
[0:03:04.628820605] [1269] INFO RPI raspberrypi.cpp:122 Mode: 3840x2160 fmt pRAA Score: 1770.67 (best 1627.58)
[0:03:04.628888939] [1269] INFO RPI raspberrypi.cpp:122 Mode: 2328x1748 fmt pRAA Score: 1127.58 (best 1127.58)
[0:03:04.628958991] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1920x1080 fmt pRAA Score: 2334.67 (best 1127.58)
[0:03:04.629026907] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1280x720 fmt pRAA Score: 4334.67 (best 1127.58)
[0:03:04.629465189] [1269] INFO RPI raspberrypi.cpp:624 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected mode: 2328x1748-pRAA
[0:03:04.705997897] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AfTrigger = 1
[0:03:04.706292116] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Saturation = 1.000000
[0:03:04.706472324] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Contrast = 1.000000
[0:03:04.706580918] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Brightness = 0.000000
[0:03:04.706685605] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AwbMode = 0
[0:03:04.706956334] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Sharpness = 1.000000
[0:03:04.707081907] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: ExposureValue = 0.000000
[0:03:04.707211334] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AeExposureMode = 0
[0:03:04.707363418] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
[0:03:04.707562584] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AeMeteringMode = 0
[0:03:04.707669772] [1273] INFO IPARPI raspberrypi.cpp:654 Request ctrl: NoiseReductionMode = 3
[0:03:04.711085970] [1269] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:03:04.711183886] [1269] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:03:04.711236595] [1269] INFO RPISTREAM rpi_stream.cpp:122 No buffers available for ISP Output0
[0:03:05.156927428] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.199519095] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (6 left)
[0:03:05.221745917] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.260390917] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (5 left)
[0:03:05.287983209] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.324641699] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (4 left)
[0:03:05.354204303] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.385408261] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (3 left)
[0:03:05.421184303] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.452364928] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (2 left)
[0:03:05.487840917] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.518723678] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (1 left)
[0:03:05.554406230] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.586156803] [1269] INFO RPI raspberrypi.cpp:1731 Dropping frame at the request of the IPA (0 left)
[0:03:05.620673521] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.687171594] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.754137428] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.821406386] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.889161021] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:05.956533157] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.023329042] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.088642167] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.155175813] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.220794407] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.287816386] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.354321230] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.420916490] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.487987427] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.555380344] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.621771854] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.687292792] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.753963209] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.820934198] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.887181646] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:06.954503156] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.021479511] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.087227896] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.155446802] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.221258417] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.287939406] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.354887062] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.423364042] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.487589094] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.554082479] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.620961489] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.687772167] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.753834562] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.821585239] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.887386125] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:07.953834927] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.021276854] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.087847218] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.154874354] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.221592218] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.287917427] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.355529354] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.421386697] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.487613364] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.554793468] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.622610812] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.688502531] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.756020552] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.821535343] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.887377687] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:08.955229614] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.023604406] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.087294249] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.156448885] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.222118416] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.287205968] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.356422895] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.420842635] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.487341958] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.553931645] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.620821593] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.687582374] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.753754666] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.820564978] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.888132999] [1273] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
[0:03:09.956713780] [1267] INFO Camera camera.cpp:937 configuring streams: (0) 4656x3496-YUV420
[0:03:09.957234874] [1269] INFO RPI raspberrypi.cpp:122 Mode: 4656x3496 fmt RG10 Score: 1500 (best 1500)
[0:03:09.957402947] [1269] INFO RPI raspberrypi.cpp:122 Mode: 3840x2160 fmt RG10 Score: 5971.24 (best 1500)
[0:03:09.957477270] [1269] INFO RPI raspberrypi.cpp:122 Mode: 2328x1748 fmt RG10 Score: 9652 (best 1500)
[0:03:09.957546072] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1920x1080 fmt RG10 Score: 11971.2 (best 1500)
[0:03:09.957614561] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1280x720 fmt RG10 Score: 13971.2 (best 1500)
[0:03:09.957691020] [1269] INFO RPI raspberrypi.cpp:122 Mode: 4656x3496 fmt pRAA Score: 1000 (best 1000)
[0:03:09.957759301] [1269] INFO RPI raspberrypi.cpp:122 Mode: 3840x2160 fmt pRAA Score: 5471.24 (best 1000)
[0:03:09.957827582] [1269] INFO RPI raspberrypi.cpp:122 Mode: 2328x1748 fmt pRAA Score: 9152 (best 1000)
[0:03:09.957896905] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1920x1080 fmt pRAA Score: 11471.2 (best 1000)
[0:03:09.957964145] [1269] INFO RPI raspberrypi.cpp:122 Mode: 1280x720 fmt pRAA Score: 13471.2 (best 1000)
[0:03:09.958376957] [1269] INFO RPI raspberrypi.cpp:624 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected mode: 4656x3496-pRAA
[0:03:10.060297634] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AfTrigger = 1
[0:03:10.060463832] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Saturation = 1.000000
[0:03:10.060577634] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Contrast = 1.000000
[0:03:10.060653884] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Brightness = 0.000000
[0:03:10.060726020] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AwbMode = 0
[0:03:10.060812166] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: Sharpness = 1.000000
[0:03:10.060886905] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: ExposureValue = 0.000000
[0:03:10.060962582] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AeExposureMode = 0
[0:03:10.061035759] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: FrameDurationLimits = [ 100, 1000000000 ]
[0:03:10.061138676] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: AeMeteringMode = 0
[0:03:10.061212686] [1275] INFO IPARPI raspberrypi.cpp:654 Request ctrl: NoiseReductionMode = 2
[0:03:11.071205446] [1275] ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed
Still capture image received
Switching to single channel mode also works, but still gives me the same errors in the terminal.
If you don’t want to flash the system again, maybe you can tell me your current system, I can update the old version of libcamera installation package.
I am having the same issue of purple static using a fresh Raspbian Bullseye installation and lib camera 0.0.10 with the quadhat. You can actually see a little bit of the real world image behind the purple static, so it’s partially functional (see pic).
I don’t get many error messages when running libcamera-still -t 0, so not sure how to resolve:
pi@campi:~ $ libcamera-still -t 0
Made X/EGL preview window
[1:08:56.857700814] [1807] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3897-c3c878a9
[1:08:56.877529019] [1809] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for ‘imx519’
[1:08:56.877637719] [1809] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[1:08:56.895834233] [1809] WARN RPI raspberrypi.cpp:1280 Mismatch between Unicam and CamHelper for embedded data usage!
[1:08:56.897117879] [1809] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[1:08:56.897407667] [1809] INFO RPI raspberrypi.cpp:1404 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media1
[1:08:56.898305287] [1807] INFO Camera camera.cpp:1035 configuring streams: (0) 2328x1748-YUV420
[1:08:56.898937508] [1809] INFO RPI raspberrypi.cpp:765 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[1:08:57.427283013] [1809] WARN V4L2 v4l2_videodevice.cpp:1803 /dev/video0[18:cap]: Zero sequence expected for first frame (got 2)
Where did you get the camera module(s)? Amazon.com Arducam store
Raspberry Pi 4B
“synchronized-quad-camera-kit-getting-started.pdf” on Arducam website (sorry new users can’t post too many links in a post)
Purple static on top of barely visible real images
The dmesg log from your hardware.
dmesg | grep -E “imx519” returns nothing
pi@campi:~ $ dmesg
[ 62.136320] platform fe801000.csi: Fixing up cyclic dependency with 10-001a
[ 62.286298] ak7375: loading out-of-tree module taints kernel.
[ 62.323930] imx519 10-001a: Device found is imx519
[ 62.326225] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 2692.849982] v3d fec00000.v3d: MMU error from client CLE (4) at 0x22c1000, pte invalid
(last five lines that seemed relevant)
As an update, I made a second attempt by flashing a clean SD card with latest Raspbian, switching to another quad camera system purchased from same supplier above, and following the instructions on this forum for Install_pivariety_pkgs.sh.
Now, I get only a black image.
During still image capture, I get:
[0:01:15.881601626] [1461] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3866-0c55e522
[0:01:15.912591231] [1462] WARN CameraSensorProperties camera_sensor_properties.cpp:174 No static properties available for ‘imx519’
[0:01:15.912681906] [1462] WARN CameraSensorProperties camera_sensor_properties.cpp:176 Please consider updating the camera sensor properties database
[0:01:15.949849312] [1462] INFO RPI raspberrypi.cpp:1374 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media1
[0:01:15.951131833] [1461] INFO Camera camera.cpp:1035 configuring streams: (0) 2328x1748-YUV420
[0:01:15.951898506] [1462] INFO RPI raspberrypi.cpp:761 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
dmesg shows:
[ 61.109294] imx519 10-001a: Device found is imx519
[ 61.111530] imx519 10-001a: Consider updating driver imx519 to match on endpoints
[ 89.005872] v3d fec00000.v3d: MMU error from client CLE (4) at 0x3421000, pte invalid
I am having the same issue with a Raspberry PI 3b.
However, I can only get output in single channel and dual channel mode, never in quad mode, and always with the purple static.
I have an ongoing e-mail thread where Arducam has offered remote help but it’s really hard to find a time that works for both of us timezone-wise so if there’s any lessons learned it would be great if they could be shared here!
Hi Eerikh,
We tested it yesterday, and now there is a solution to settle for second best. Please burn your Raspberry Pi OS to the version in the link below(Bullseye 2022-1-28 release). Then reinstall the camera driver and test the libcamera command. https://downloads.raspberrypi.org/raspios_armhf/images/raspios_armhf-2022-01-28/
I am using a raspberry pi 4B and also encountered a similar problem, a solution to this would be using an raspbian bullseye img specifically the Bullseye 2022-1-28 release and following the guide for the installation as mentioned by @Dion in the thread bellow
