I am a backer of the quad camera Kickstarter https://www.kickstarter.com/projects/arducam/high-resolution-autofocus-camera-module-for-raspberry-pi/comments
I finally got around to trying out the camera but I am running into some issues.
The first issue is that although I see a feed of the four cameras, I can only use it once before I need to unplug it. For example, I can capture an image with the four cameras but if I try to repeat the same libcamera command, it will keep giving me a device timeout error. The only way I can avoid this issue is by unplugging the cameras and replugging it back in.
I recorded a video of what this looks like: https://www.youtube.com/watch?v=foo7pPA1b8A
And here’s what the logs look like:
(base) alan@raspberrypi:~ $ libcamera-still
[0:00:33.681144127] [1579] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+147-057299d0-dirty (2024-01-24T08:51:15+00:00)
[0:00:33.729480182] [1582] WARN RPiSdn sdn.cpp:39 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:00:33.731331182] [1582] INFO RPI vc4.cpp:452 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media0
[0:00:33.731412645] [1582] INFO RPI pipeline_base.cpp:1167 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Made X/EGL preview window
Mode selection for 2328:1748:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 5319.24
SRGGB10_CSI2P,1920x1080/0 - Score: 3319.24
SRGGB10_CSI2P,2328x1748/0 - Score: 1000
SRGGB10_CSI2P,3840x2160/0 - Score: 1648.24
SRGGB10_CSI2P,4656x3496/0 - Score: 2019
Stream configuration adjusted
[0:00:34.978537904] [1579] INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-SRGGB10_CSI2P
[0:00:34.978989978] [1582] INFO RPI vc4.cpp:616 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:00:35.452420293] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.519110978] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.585681681] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.652344292] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.719010070] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.785653496] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.852319255] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.919011403] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:35.985757126] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.053216681] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.119362496] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.186073033] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.252378811] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.319029107] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.385702051] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.452378736] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.519043644] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.585715236] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.652394125] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.719039440] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.785709144] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.852381940] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.919051162] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:36.985732532] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.052432162] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.119148217] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.185727273] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.252498014] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.319178125] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.385804347] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.452483643] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.519135236] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.585799588] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.652467995] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.719147773] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.786074476] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.852553439] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.919213124] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:37.986097643] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.052519513] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.119710050] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.185830421] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.253133680] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.319730698] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.386461846] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.452605494] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.519621920] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.586356272] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.653182976] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.719465550] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.785976309] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.852646513] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.919321105] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:38.985982198] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.052798494] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.119319624] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.185985605] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.252643642] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.319316642] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.385952420] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.452665031] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.519230586] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.585875401] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.652574957] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.719335179] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.786011086] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.852695142] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.919324882] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:39.985997142] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:40.052656771] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:40.119223216] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:40.185881512] [1609] ERROR IPARPI cam_helper.cpp:257 Embedded data buffer parsing failed
[0:00:42.420074900] [1631] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+147-057299d0-dirty (2024-01-24T08:51:15+00:00)
[0:00:42.470681066] [1634] WARN RPiSdn sdn.cpp:39 Using legacy SDN tuning - please consider moving SDN inside rpi.denoise
[0:00:42.472542122] [1634] INFO RPI vc4.cpp:452 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media0
[0:00:42.472614474] [1634] INFO RPI pipeline_base.cpp:1167 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
[0:00:42.959141825] [1631] INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-SRGGB10_CSI2P
[0:00:42.959575751] [1634] INFO RPI vc4.cpp:616 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:00:44.183610102] [1634] WARN V4L2 v4l2_videodevice.cpp:2007 /dev/video0[14:cap]: Dequeue timer of 1000000.00us has expired!
[0:00:44.183760417] [1634] ERROR RPI pipeline_base.cpp:1422 Camera frontend has timed out!
[0:00:44.183799232] [1634] ERROR RPI pipeline_base.cpp:1423 Please check that your camera sensor connector is attached securely.
[0:00:44.183838473] [1634] ERROR RPI pipeline_base.cpp:1424 Alternatively, try another cable and/or sensor.
The second issue is, as you can see from the logs, I get this repeating “Embedded data buffer parsing failed” error. I’m not sure what this mean and what the implications are.
Here’s some more information about my set up.
Kickstarter
Arducam 16MP Autofocus Quad-Camera Kit for Raspberry Pi
Raspberry Pi 4 Model B/4GB running Bookworm
(base) alan@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 12 (bookworm)"
NAME="Debian GNU/Linux"
VERSION_ID="12"
VERSION="12 (bookworm)"
VERSION_CODENAME=bookworm
ID=debian
https://docs.arducam.com/Raspberry-Pi-Camera/Multi-Camera-CamArray/quick-start/#imx519-multi-camera-kit
(base) alan@raspberrypi:~ $ dmesg | grep -E "imx477|imx219|arducam|imx519"
[ 8.728311] imx519 10-001a: Device found is imx519
[ 8.729070] imx519 10-001a: Consider updating driver imx519 to match on endpoints
- Unplugging and replugging in camarray HAT
- Reinstalling my operating system and reinstalling everything
- Purchasing and trying out new data cables
I also want to mention that on my journey to learn how to use my Raspberry Pi and quad cam, there was a time when I could reliably use the quad cam. It would still give me the data buffer errors but I could still use the quad cam. I could not get the quad cam to focus properly though. I still have this issue. In any case, this was before I had to reinstall the Pi operating system. After I did that, I could not get quad cam working consistently anymore.
Possible related topics:
(Regarding only usable once) 16 MP quad array only works once then needs to be powercycled - #3 by onilx
I tried using an additional power source for the Camarray HAT. It did not seem to do anything. -
(Regarding the data buffer) IMX519 output purple static on quad hat
I tried installing the low speed driver and I did not see a change. I do not know how to uninstall my original driver though. Perhaps it was using the same driver.
However, I’m not using the 15-meter cable extension kit that they mention. I see people mentioning that you need the low speed driver when you use the extension kit but I am not.
