Dmesg part 5
[ 1.728793] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 1.728806] tegradc 15210000.nvdisplay: blank - powerdown
[ 1.728819] extcon-disp-state external-connection:disp-state: cable 44 state 0 already set.
[ 1.728824] Extcon DP: HPD disabled
[ 1.728829] hpd: hpd_switch 0
[ 1.728834] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 1.728845] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 1.728853] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 1.849407] tegradc 15200000.nvdisplay: blank - powerdown
[ 1.877360] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 1.877917] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 38 55 61
[ 1.877942] Using phyrst_lpmode = 1 from DT
[ 1.878048] libphy: dwc_phy: probed
[ 1.880571] PPP generic driver version 2.4.2
[ 1.880715] PPP BSD Compression module registered
[ 1.880720] PPP Deflate Compression module registered
[ 1.880736] PPP MPPE Compression module registered
[ 1.880741] NET: Registered protocol family 24
[ 1.880810] usbcore: registered new interface driver r8152
[ 1.880854] usbcore: registered new interface driver asix
[ 1.880885] usbcore: registered new interface driver ax88179_178a
[ 1.880913] usbcore: registered new interface driver cdc_ether
[ 1.880939] usbcore: registered new interface driver net1080
[ 1.880990] usbcore: registered new interface driver cdc_subset
[ 1.881018] usbcore: registered new interface driver zaurus
[ 1.881056] usbcore: registered new interface driver cdc_ncm
[ 1.881200] VFIO - User Level meta-driver version: 0.3
[ 1.882765] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.882778] ehci-pci: EHCI PCI platform driver
[ 1.882810] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.882819] ohci-pci: OHCI PCI platform driver
[ 1.882853] ohci-platform: OHCI generic platform driver
[ 1.887814] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 1.889742] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4d08000 id
[ 1.889774] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 1.889778] Extcon AUX1(HDMI) disable
[ 1.890626] usbcore: registered new interface driver uas
[ 1.890743] usbcore: registered new interface driver usb-storage
[ 1.890982] usbcore: registered new interface driver usbserial
[ 1.892109] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 1.892139] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.892158] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 1.892869] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 1.892919] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 1.893110] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.893116] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.893121] usb usb1: Product: xHCI Host Controller
[ 1.893126] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.893130] usb usb1: SerialNumber: 3610000.xhci
[ 1.893719] hub 1-0:1.0: USB hub found
[ 1.893806] hub 1-0:1.0: 4 ports detected
[ 1.894521] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 1.894557] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 1.894566] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 1.894855] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.894861] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.894866] usb usb2: Product: xHCI Host Controller
[ 1.894871] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 1.894875] usb usb2: SerialNumber: 3610000.xhci
[ 1.895531] hub 2-0:1.0: USB hub found
[ 1.895677] hub 2-0:1.0: 4 ports detected
[ 1.896732] Wake76 for irq=199
[ 1.896735] Wake77 for irq=199
[ 1.896738] Wake78 for irq=199
[ 1.896740] Wake79 for irq=199
[ 1.896742] Wake80 for irq=199
[ 1.896745] Wake81 for irq=199
[ 1.896747] Wake82 for irq=199
[ 1.896788] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 1.896794] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 1.897448] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 1.897517] tegra-xudc-new 3550000.xudc: device count: 1
[ 1.898427] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 1.898435] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 1.898460] tegra-xudc-new 3550000.xudc: entering ELPG
[ 1.898747] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 1.899293] mousedev: PS/2 mouse device common for all mice
[ 1.899413] usbcore: registered new interface driver xpad
[ 1.915204] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 1.916308] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 1.936548] tegradc 15200000.nvdisplay: unblank
[ 1.938190] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 1.938564] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 1.949418] Parent Clock set for DC plld2
[ 1.953788] tegradc 15200000.nvdisplay: hdmi: tmds rate:148500K prod-setting:prod_c_hdmi_111m_223m
[ 1.955129] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 1.989725] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 1.989729] Extcon AUX1(HDMI) enable
[ 1.998668] usb usb2: usb_suspend_both: status 0
[ 2.005330] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 2.032017] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 2.033648] Wake73 for irq=42
[ 2.034989] rtc rtc1: alarm rtc device
[ 2.035007] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 2.035036] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.035223] i2c /dev entries driver
[ 2.037659] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.037748] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 2.037754] Extcon HDMI: HPD enabled
[ 2.037784] tegradc 15200000.nvdisplay: hdmi: plugged
[ 2.038236] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.038248] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.038867] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.062473] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.062547] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.062893] imx219 9-0010: board setup failed
[ 2.063108] imx219: probe of 9-0010 failed with error -121
[ 2.063501] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 2.086744] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 2.086809] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 2.087103] imx219 10-0010: board setup failed
[ 2.087296] imx219: probe of 10-0010 failed with error -121
[ 2.088753] max77620-power max20024-power: Event recorder REG_NVERC : 0x40
[ 2.095449] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 2.095854] FAN dev name: pwm-fan
[ 2.095898] FAN:gpio request success.
[ 2.095907] FAN: can’t find tach_gpio
[ 2.095918] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 2.095944] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 2.096197] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 2.096205] pwm_fan_driver pwm-fan: tach period: 1000
[ 2.096780] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 2.096789] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 2.096795] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 2.096801] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 2.096807] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 2.096813] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 2.096820] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 2.096826] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 2.096833] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 2.096840] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 2.097647] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 2.098836] device-mapper: uevent: version 1.0.3
[ 2.099317] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 2.103258] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 2.104487] cpuidle: Initializing cpuidle driver
[ 2.105609] sdhci: Secure Digital Host Controller Interface driver
[ 2.105614] sdhci: Copyright(c) Pierre Ossman
[ 2.105617] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.106712] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 2.108539] CMDQ: cmdq_platfm_init successful
[ 2.112570] tegra-se-nvhost 15810000.se: initialized
[ 2.113539] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 2.114488] tegra-se-nvhost 15820000.se: initialized
[ 2.115644] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 2.116194] tegra-se-nvhost 15830000.se: initialized
[ 2.116907] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 2.117699] tegra-se-nvhost 15840000.se: initialized
[ 2.118609] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 2.119533] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 2.119757] hidraw: raw HID events driver (C) Jiri Kosina
[ 2.121070] usbcore: registered new interface driver usbhid
[ 2.121074] usbhid: USB HID core driver
[ 2.125120] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 2.126101] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 2.126607] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 2.127266] denver_knobs_init:MTS_VERSION:53250041
[ 2.127551] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 2.128290] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 2.128696] t19x_cache tegra-cache: probed
[ 2.131029] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 2.131056] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 2.131557] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 2.131971] PLL_AON clock registered
[ 2.134378] Clocks initialized successfully
[ 2.135992] nvpmodel: initialized successfully
[ 2.137069] trusty-virtio trusty:virtio: initializing
[ 2.137271] trusty_ipc virtio0: vring0: va¶ ffffffc1e26dc000(0) qsz 32 notifyid 1
[ 2.137282] trusty_ipc virtio0: vring1: va¶ ffffffc1e26de000(0) qsz 32 notifyid 2
[ 2.137436] trusty-virtio trusty:virtio: initializing done
[ 2.137704] trusty_ipc virtio0: is online
[ 2.137958] tegra-hda 3510000.hda: Override SDO lines to 4
[ 2.138417] usbcore: registered new interface driver snd-usb-audio
[ 2.150412] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 2.158587] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 2.158790] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 2.159104] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 2.159303] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 2.196962] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 2.210506] mmc0: periodic cache flush enabled
[ 2.210524] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 2.215082] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 2.219361] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 2.219617] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 2.219867] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 2.223548] OPE platform probe
[ 2.223678] OPE platform probe successful
[ 2.225262] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 2.226643] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 2.261374] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 2.261382] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.261387] usb 1-2: Product: 4-Port USB 2.0 Hub
[ 2.261391] usb 1-2: Manufacturer: Generic
[ 2.262318] hub 1-2:1.0: USB hub found
[ 2.262967] hub 1-2:1.0: 4 ports detected
[ 2.300209] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 2.300339] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 2.300458] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 2.300584] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 2.300733] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 2.300885] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 2.301026] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 2.301153] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 2.301295] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 2.301425] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 2.301557] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 2.301666] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 2.301780] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 2.301902] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 2.302015] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 2.302116] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 2.302212] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 2.302311] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 2.302442] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 2.302544] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 2.331537] u32 classifier
[ 2.331542] Actions configured
[ 2.331619] Initializing XFRM netlink socket
[ 2.332207] NET: Registered protocol family 10
[ 2.332975] NET: Registered protocol family 17
[ 2.332990] NET: Registered protocol family 15
[ 2.333047] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.333118] Bluetooth: RFCOMM socket layer initialized
[ 2.333139] Bluetooth: RFCOMM ver 1.11
[ 2.333146] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 2.333153] Bluetooth: HIDP socket layer initialized
[ 2.333170] 9pnet: Installing 9P2000 support
[ 2.333217] Key type dns_resolver registered
[ 2.333467] Registered cp15_barrier emulation handler
[ 2.333486] Registered setend emulation handler
[ 2.335224] registered taskstats version 1
[ 2.335507] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 2.336672] OF: PCI: host bridge /pcie@14160000 ranges:
[ 2.336706] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 2.336737] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 2.336744] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 2.374696] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 2.404595] usb 2-3: New USB device found, idVendor=0bda, idProduct=0411
[ 2.404601] usb 2-3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.404606] usb 2-3: Product: 4-Port USB 3.0 Hub
[ 2.404610] usb 2-3: Manufacturer: Generic
[ 2.410035] hub 2-3:1.0: USB hub found
[ 2.411079] hub 2-3:1.0: 4 ports detected
[ 2.446410] tegra-pcie-dw 14160000.pcie: link is up
[ 2.446662] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 2.446671] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 2.446680] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 2.446710] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 2.446716] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 2.446745] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 2.446927] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.447176] iommu: Adding device 0004:00:00.0 to group 58
[ 2.447607] pci 0004:01:00.0: [10ec:c822] type 00 class 0x028000
[ 2.447740] pci 0004:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.447903] pci 0004:01:00.0: reg 0x18: [mem 0x36200000-0x3620ffff 64bit]
[ 2.448625] pci 0004:01:00.0: supports D1 D2
[ 2.448629] pci 0004:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.449003] iommu: Adding device 0004:01:00.0 to group 59
[ 2.459668] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 2.459676] pci 0004:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.459683] pci 0004:01:00.0: BAR 2: assigned [mem 0x1740000000-0x174000ffff 64bit]
[ 2.459770] pci 0004:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.459797] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 2.459802] pci 0004:00:00.0: bridge window [io 0x1000-0x1fff]
[ 2.459811] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 2.459831] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.459907] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.460259] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.460265] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.460274] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.460432] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 2.460943] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 2.461174] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 2.461187] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 2.518377] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 2.539545] usb 1-3: New USB device found, idVendor=0bda, idProduct=c123
[ 2.539552] usb 1-3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.539557] usb 1-3: Product: Bluetooth Radio
[ 2.539561] usb 1-3: Manufacturer: Realtek
[ 2.539565] usb 1-3: SerialNumber: 00e04c000001
[ 2.566834] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 2.566856] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 2.566868] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 2.566891] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 2.570390] usb 2-3: usb_suspend_both: status 0
[ 2.570625] usb usb2: usb_suspend_both: status 0
[ 2.582389] tegra_cec 3960000.tegra_cec: physical address: 10:00.
[ 2.618358] usb 1-2.4: new full-speed USB device number 4 using tegra-xusb
[ 2.641260] usb 1-2.4: New USB device found, idVendor=1ea7, idProduct=0066
[ 2.641284] usb 1-2.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.641289] usb 1-2.4: Product: 2.4G Mouse
[ 2.644097] input: 2.4G Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.0/0003:1EA7:0066.0001/input/input4
[ 2.646915] tegra_cec 3960000.tegra_cec: Sent res: -113.
[ 2.646920] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[ 2.678387] tegra-pcie-dw 141a0000.pcie: link is up
[ 2.678594] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 2.678601] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 2.678609] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 2.678615] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 2.678620] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 2.678645] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 2.678784] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 2.678979] iommu: Adding device 0005:00:00.0 to group 60
[ 2.679374] pci 0005:01:00.0: [126f:2263] type 00 class 0x010802
[ 2.679506] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 2.680403] iommu: Adding device 0005:01:00.0 to group 61
[ 2.691183] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 2.691192] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 2.691252] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 2.691260] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 2.691280] pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 2.691323] pci 0005:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 2.691528] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 2.691533] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.691539] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 2.691617] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 2.691955] nvme nvme0: pci function 0005:01:00.0
[ 2.692028] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 2.701712] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 2.703228] hid-generic 0003:1EA7:0066.0001: input,hidraw0: USB HID v1.10 Keyboard [2.4G Mouse] on usb-3610000.xhci-2.4/input0
[ 2.706517] tegra194-isp5 14800000.isp: initialized
[ 2.707326] input: 2.4G Mouse as /devices/3610000.xhci/usb1/1-2/1-2.4/1-2.4:1.1/0003:1EA7:0066.0002/input/input5
[ 2.714529] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
