This is the result I found from Google, but this is not a native SSD boot.
This is the native boot:
https://www.jetsonhacks.com/2021/08/25/native-boot-for-jetson-xaviers/
With the official dev kit comes a usb that contains a doc file detailing the steps to set SSD boot on the jetson xavier NX. I will send the file via email if email.
Yes it is the right one.
Ok, but this is not a native SSD boot, you need to switch back to SD Card to install the driver.
Do you mean usb boot? Which SSD boot is supported.
Yes, if you are using USB to connect SSD, then it is USB boot.
At present, only SSD with M.2 interface (connected to the bottom of Jetson Xaivier NX) supports native SSD boot.
For the usage you can refer to:
My SSD is already connected throughM.2 interface (connected to the bottom of Jetson Xaivier NX).
Then you can refer to this document to set it up:
