[ 4.401729] console [ttyTCU0] enabled
[ 4.401803] tegradc 15200000.nvdisplay: blank - powerdown
[ 4.402079] [drm] Initialized
[ 4.435073] brd: module loaded
[ 4.440378] extcon-disp-state external-connection:disp-state: cable 47 state 0
[ 4.440382] Extcon AUX1(HDMI) disable
[ 4.441055] loop: module loaded
[ 4.441152] tegra_profiler: version: 1.145, samples/io: 49/28
[ 4.441285] tegra_profiler: auth: init
[ 4.441820] THERMAL EST: found 3 subdevs
[ 4.441824] THERMAL EST num_resources: 0
[ 4.441829] [THERMAL EST subdev 0]
[ 4.441833] [THERMAL EST subdev 1]
[ 4.441837] [THERMAL EST subdev 2]
[ 4.441847] THERMAL EST: Found 2 profiles, default profile is quiet
[ 4.442230] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 4.442232] THERMAL EST: thz register success.
[ 4.442374] THERMAL EST: end of probe, return err: 0
[ 4.443052] sd: No Scsi addr parsed to reserve index
[ 4.443084] hisi_sas: driver version v1.6
[ 4.454271] qspi_mtd spi6.0: s25fs256s SSG 8 0 1000 2000000
[ 4.454278] qspi_mtd spi6.0: s25fs256s (32768 Kbytes)
[ 4.454286] qspi_mtd spi6.0: mtd .name = spi6.0, .size = 0x2000000 (32MiB) .erasesize = 0x00010000 (64KiB) .numeraseregions = 0
[ 4.454521] 1 ofpart partitions found on MTD device spi6.0
[ 4.454526] Creating 1 MTD partitions on “spi6.0”:
[ 4.454541] 0x000000000000-0x000002000000 : “Whole_flash0”
[ 4.457194] libphy: Fixed MDIO Bus: probed
[ 4.457860] tun: Universal TUN/TAP device driver, 1.6
[ 4.457863] tun: (C) 1999-2004 Max Krasnyansky [email protected]
[ 4.459619] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 4.459623] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 4.459665] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 4.459667] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 4.459710] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 4.459712] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 4.459752] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[ 4.459754] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[ 4.467259] tegra_nvdisp_handle_pd_disable: Powergated Head1 pd
[ 4.468665] tegra_nvdisp_handle_pd_disable: Powergated Head0 pd
[ 4.527511] tegradc 15200000.nvdisplay: unblank
[ 4.529600] tegra_nvdisp_handle_pd_enable: Unpowergated Head0 pd
[ 4.529930] tegra_nvdisp_handle_pd_enable: Unpowergated Head1 pd
[ 4.540830] Parent Clock set for DC plld2
[ 4.545946] tegradc 15200000.nvdisplay: hdmi: tmds rate:241500K prod-setting:prod_c_hdmi_223m_300m
[ 4.547382] tegradc 15200000.nvdisplay: hdmi: get YCC quant from EDID.
[ 4.582236] extcon-disp-state external-connection:disp-state: cable 47 state 1
[ 4.582240] Extcon AUX1(HDMI) enable
[ 4.597612] tegradc 15200000.nvdisplay: sync windows ret = 246
[ 4.708053] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[ 4.708593] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 5f e0 9b
[ 4.708609] Using phyrst_lpmode = 1 from DT
[ 4.708742] libphy: dwc_phy: probed
[ 4.711230] PPP generic driver version 2.4.2
[ 4.711671] PPP BSD Compression module registered
[ 4.711675] PPP Deflate Compression module registered
[ 4.711691] PPP MPPE Compression module registered
[ 4.711696] NET: Registered protocol family 24
[ 4.711754] usbcore: registered new interface driver r8152
[ 4.711841] usbcore: registered new interface driver asix
[ 4.711914] usbcore: registered new interface driver ax88179_178a
[ 4.711971] usbcore: registered new interface driver cdc_ether
[ 4.712069] usbcore: registered new interface driver net1080
[ 4.712110] usbcore: registered new interface driver cdc_subset
[ 4.712192] usbcore: registered new interface driver zaurus
[ 4.712245] usbcore: registered new interface driver cdc_ncm
[ 4.712443] VFIO - User Level meta-driver version: 0.3
[ 4.713901] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 4.713924] ehci-pci: EHCI PCI platform driver
[ 4.713974] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 4.713985] ohci-pci: OHCI PCI platform driver
[ 4.714025] ohci-platform: OHCI generic platform driver
[ 4.718906] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[ 4.720798] tegra-xusb 3610000.xhci: extcon 0: ffffffc1f4c6c000 id
[ 4.721717] usbcore: registered new interface driver uas
[ 4.721766] usbcore: registered new interface driver usb-storage
[ 4.721855] usbcore: registered new interface driver usbserial
[ 4.723282] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[ 4.723320] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.723347] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[ 4.724070] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[ 4.724113] tegra-xusb 3610000.xhci: irq 464, io mem 0x03610000
[ 4.724339] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.724344] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.724349] usb usb1: Product: xHCI Host Controller
[ 4.724353] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.724358] usb usb1: SerialNumber: 3610000.xhci
[ 4.724758] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[ 4.724849] tegra-xudc-new 3550000.xudc: device count: 1
[ 4.724985] hub 1-0:1.0: USB hub found
[ 4.725046] hub 1-0:1.0: 4 ports detected
[ 4.725630] tegra-xusb 3610000.xhci: xHCI Host Controller
[ 4.725641] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[ 4.725649] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[ 4.725819] tegra-xudc-new 3550000.xudc: vbus state: 0
[ 4.725828] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[ 4.725852] tegra-xudc-new 3550000.xudc: entering ELPG
[ 4.725962] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 4.725968] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.725972] usb usb2: Product: xHCI Host Controller
[ 4.725976] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[ 4.725980] usb usb2: SerialNumber: 3610000.xhci
[ 4.726083] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 4.726560] hub 2-0:1.0: USB hub found
[ 4.726600] hub 2-0:1.0: 4 ports detected
[ 4.727010] mousedev: PS/2 mouse device common for all mice
[ 4.727158] usbcore: registered new interface driver xpad
[ 4.727611] Wake76 for irq=199
[ 4.727614] Wake77 for irq=199
[ 4.727617] Wake78 for irq=199
[ 4.727619] Wake79 for irq=199
[ 4.727621] Wake80 for irq=199
[ 4.727623] Wake81 for irq=199
[ 4.727626] Wake82 for irq=199
[ 4.727672] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[ 4.727677] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[ 4.825806] usb usb2: usb_suspend_both: status 0
[ 4.860427] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 4.862109] Wake73 for irq=42
[ 4.863456] rtc rtc1: alarm rtc device
[ 4.863503] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[ 4.863544] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 4.863708] i2c /dev entries driver
[ 4.866723] i2c i2c-2: Added multiplexed i2c bus 9
[ 4.867263] i2c i2c-2: Added multiplexed i2c bus 10
[ 4.867268] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 4.868067] imx219 9-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.891624] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.891697] imx219 9-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.891820] imx219 9-0010: board setup failed
[ 4.891904] imx219: probe of 9-0010 failed with error -121
[ 4.892381] imx219 10-0010: tegracam sensor driver:imx219_v2.0.6
[ 4.915625] tegra-i2c 3180000.i2c: no acknowledge from address 0x10
[ 4.915686] imx219 10-0010: imx219_board_setup: error during i2c read probe (-121)
[ 4.915800] imx219 10-0010: board setup failed
[ 4.915898] imx219: probe of 10-0010 failed with error -121
[ 4.917490] max77620-power max20024-power: Event recorder REG_NVERC : 0x0
[ 4.924511] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[ 4.924880] FAN dev name: pwm-fan
[ 4.924923] FAN:gpio request success.
[ 4.924932] FAN: can’t find tach_gpio
[ 4.924942] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[ 4.924971] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[ 4.925315] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 4.925320] pwm_fan_driver pwm-fan: tach period: 1000
[ 4.925898] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 4.925905] pwm_fan_driver pwm-fan: index 1: pwm=130, rpm=1000, rru=2, rrd=2, state:2
[ 4.925910] pwm_fan_driver pwm-fan: index 2: pwm=160, rpm=2000, rru=1, rrd=1, state:2
[ 4.925914] pwm_fan_driver pwm-fan: index 3: pwm=200, rpm=3000, rru=1, rrd=1, state:2
[ 4.925918] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 4.925923] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 4.925927] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 4.925931] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 4.925936] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 4.925941] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 4.926852] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[ 4.927836] device-mapper: uevent: version 1.0.3
[ 4.928311] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: [email protected]
[ 4.952940] tegra194_cpufreq_probe: platform driver Initialization: pass
[ 4.962153] cpuidle: Initializing cpuidle driver
[ 4.975418] sdhci: Secure Digital Host Controller Interface driver
[ 4.975420] sdhci: Copyright(c) Pierre Ossman
[ 4.975422] sdhci-pltfm: SDHCI platform and OF driver helper
[ 4.976621] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[ 4.978493] CMDQ: cmdq_platfm_init successful
[ 4.982945] tegra-se-nvhost 15810000.se: initialized
[ 4.984125] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[ 4.985095] tegra-se-nvhost 15820000.se: initialized
[ 4.986117] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[ 4.986929] tegra-se-nvhost 15830000.se: initialized
[ 4.987627] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[ 4.988501] tegra-se-nvhost 15840000.se: initialized
[ 4.989355] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 4.990492] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[ 4.990639] hidraw: raw HID events driver (C) Jiri Kosina
[ 4.992082] usbcore: registered new interface driver usbhid
[ 4.992084] usbhid: USB HID core driver
[ 4.995739] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[ 4.996771] tegra_aon c1a0000.aon: tegra aon driver probe OK
[ 4.997259] tegra186-aondbg aondbg: aondbg driver probe() OK
[ 4.997866] denver_knobs_init:MTS_VERSION:54811859
[ 4.998154] tegra19x_actmon d230000.actmon: in actmon_register()…
[ 4.998701] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[ 4.999056] t19x_cache tegra-cache: probed
[ 5.001194] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[ 5.001200] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[ 5.001837] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[ 5.002287] PLL_AON clock registered
[ 5.003393] Clocks initialized successfully
[ 5.004823] nvpmodel: initialized successfully
[ 5.009056] trusty-virtio trusty:virtio: initializing
[ 5.009362] trusty_ipc virtio0: vring0: va¶ ffffffc1e24e6000(0) qsz 32 notifyid 1
[ 5.009373] trusty_ipc virtio0: vring1: va¶ ffffffc1e2774000(0) qsz 32 notifyid 2
[ 5.009522] trusty-virtio trusty:virtio: initializing done
[ 5.009788] trusty_ipc virtio0: is online
[ 5.010230] tegra-hda 3510000.hda: Override SDO lines to 4
[ 5.010752] usbcore: registered new interface driver snd-usb-audio
[ 5.017149] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[ 5.036759] input: tegra-hda-xnx HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[ 5.037021] input: tegra-hda-xnx HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[ 5.037400] input: tegra-hda-xnx HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[ 5.037609] input: tegra-hda-xnx HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[ 5.053133] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 5.059876] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[ 5.073992] mmc0: periodic cache flush enabled
[ 5.074002] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[ 5.078289] usb 1-2: New USB device found, idVendor=0424, idProduct=2744
[ 5.078293] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.078298] usb 1-2: Product: USB2744
[ 5.078301] usb 1-2: Manufacturer: Microchip Tech
[ 5.078528] mmcblk0: mmc0:0001 DG4016 14.7 GiB
[ 5.078730] mmcblk0boot0: mmc0:0001 DG4016 partition 1 4.00 MiB
[ 5.078940] mmcblk0boot1: mmc0:0001 DG4016 partition 2 4.00 MiB
[ 5.079140] hub 1-2:1.0: USB hub found
[ 5.079185] mmcblk0rpmb: mmc0:0001 DG4016 partition 3 4.00 MiB
[ 5.079218] hub 1-2:1.0: 5 ports detected
[ 5.082940] OPE platform probe
[ 5.083115] OPE platform probe successful
[ 5.084352] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 5.155035] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 5.155174] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 5.155303] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 5.155432] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 5.155580] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 5.155726] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 5.155867] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 5.156002] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 5.156136] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 5.156262] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 5.156378] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[ 5.156517] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[ 5.156645] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[ 5.156767] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[ 5.156869] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[ 5.156969] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[ 5.157078] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[ 5.157214] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[ 5.157315] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[ 5.157413] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[ 5.187810] u32 classifier
[ 5.187812] Actions configured
[ 5.187881] Initializing XFRM netlink socket
[ 5.188530] NET: Registered protocol family 10
[ 5.189376] NET: Registered protocol family 17
[ 5.189388] NET: Registered protocol family 15
[ 5.189455] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 5.189551] Bluetooth: RFCOMM socket layer initialized
[ 5.189572] Bluetooth: RFCOMM ver 1.11
[ 5.189580] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.189585] Bluetooth: HIDP socket layer initialized
[ 5.189601] 9pnet: Installing 9P2000 support
[ 5.189646] Key type dns_resolver registered
[ 5.195487] Registered cp15_barrier emulation handler
[ 5.195509] Registered setend emulation handler
[ 5.197386] usb 2-3: new SuperSpeed USB device number 2 using tegra-xusb
[ 5.197425] registered taskstats version 1
[ 5.197865] tegra-pcie-dw 14160000.pcie: Setting init speed to max speed
[ 5.198960] OF: PCI: host bridge /pcie@14160000 ranges:
[ 5.198994] OF: PCI: IO 0x36100000…0x361fffff → 0x36100000
[ 5.199012] OF: PCI: MEM 0x1740000000…0x17ffffffff → 0x40000000
[ 5.199026] OF: PCI: MEM 0x1400000000…0x173fffffff → 0x1400000000
[ 5.221703] usb 2-3: New USB device found, idVendor=0424, idProduct=5744
[ 5.221708] usb 2-3: New USB device strings: Mfr=2, Product=3, SerialNumber=0
[ 5.221711] usb 2-3: Product: USB5744
[ 5.221714] usb 2-3: Manufacturer: Microchip Tech
[ 5.223630] hub 2-3:1.0: USB hub found
[ 5.224040] hub 2-3:1.0: 4 ports detected
[ 5.305124] tegra-pcie-dw 14160000.pcie: link is up
[ 5.305342] tegra-pcie-dw 14160000.pcie: PCI host bridge to bus 0004:00
[ 5.305349] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 5.305363] pci_bus 0004:00: root bus resource [io 0x0000-0xfffff] (bus address [0x36100000-0x361fffff])
[ 5.305371] pci_bus 0004:00: root bus resource [mem 0x1740000000-0x17ffffffff] (bus address [0x40000000-0xffffffff])
[ 5.305377] pci_bus 0004:00: root bus resource [mem 0x1400000000-0x173fffffff pref]
[ 5.305405] pci 0004:00:00.0: [10de:1ad1] type 01 class 0x060400
[ 5.305561] pci 0004:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.305758] iommu: Adding device 0004:00:00.0 to group 58
[ 5.306189] pci 0004:01:00.0: [8086:24fd] type 00 class 0x028000
[ 5.306359] pci 0004:01:00.0: reg 0x10: [mem 0x00000000-0x00001fff 64bit]
[ 5.307233] pci 0004:01:00.0: PME# supported from D0 D3hot D3cold
[ 5.307573] iommu: Adding device 0004:01:00.0 to group 59
[ 5.318073] pci 0004:00:00.0: BAR 14: assigned [mem 0x1740000000-0x17400fffff]
[ 5.318082] pci 0004:01:00.0: BAR 0: assigned [mem 0x1740000000-0x1740001fff 64bit]
[ 5.318171] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 5.318178] pci 0004:00:00.0: bridge window [mem 0x1740000000-0x17400fffff]
[ 5.318195] pci 0004:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 5.318254] pci 0004:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 128
[ 5.318531] pcieport 0004:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.318535] pci 0004:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.318540] pcie_pme 0004:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.318626] aer 0004:00:00.0:pcie002: service driver aer loaded
[ 5.319263] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[ 5.319522] tegra-pcie-dw 141a0000.pcie: Failed to get 3V slot regulator: -19
[ 5.319531] tegra-pcie-dw 141a0000.pcie: Failed to get 12V slot regulator: -19
[ 5.341130] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 5.363061] usb 1-3: New USB device found, idVendor=8087, idProduct=0a2b
[ 5.363065] usb 1-3: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 5.377128] usb 2-3: usb_suspend_both: status 0
[ 5.377318] usb usb2: usb_suspend_both: status 0
[ 5.429395] OF: PCI: host bridge /pcie@141a0000 ranges:
[ 5.429435] OF: PCI: IO 0x3a100000…0x3a1fffff → 0x3a100000
[ 5.429454] OF: PCI: MEM 0x1f40000000…0x1fffffffff → 0x40000000
[ 5.429470] OF: PCI: MEM 0x1c00000000…0x1f3fffffff → 0x1c00000000
[ 5.445134] usb 1-2.1: new full-speed USB device number 4 using tegra-xusb
[ 5.468125] usb 1-2.1: New USB device found, idVendor=046d, idProduct=c534
[ 5.468129] usb 1-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.468150] usb 1-2.1: Product: USB Receiver
[ 5.468152] usb 1-2.1: Manufacturer: Logitech
[ 5.470771] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.0/0003:046D:C534.0001/input/input4
[ 5.530013] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2.1/input0
[ 5.532729] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.1/1-2.1:1.1/0003:046D:C534.0002/input/input5
[ 5.545124] tegra-pcie-dw 141a0000.pcie: link is up
[ 5.545320] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[ 5.545325] pci_bus 0005:00: root bus resource [bus 00-ff]
[ 5.545342] pci_bus 0005:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x3a100000-0x3a1fffff])
[ 5.545353] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[ 5.545357] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[ 5.545381] pci 0005:00:00.0: [10de:1ad0] type 01 class 0x060400
[ 5.545518] pci 0005:00:00.0: PME# supported from D0 D3hot D3cold
[ 5.545730] iommu: Adding device 0005:00:00.0 to group 60
[ 5.545992] pci 0005:01:00.0: [126f:2263] type 00 class 0x010802
[ 5.546104] pci 0005:01:00.0: reg 0x10: [mem 0x00000000-0x00003fff 64bit]
[ 5.546991] iommu: Adding device 0005:01:00.0 to group 61
[ 5.561894] pci 0005:00:00.0: BAR 14: assigned [mem 0x1f40000000-0x1f400fffff]
[ 5.561901] pci 0005:01:00.0: BAR 0: assigned [mem 0x1f40000000-0x1f40003fff 64bit]
[ 5.561960] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[ 5.561966] pci 0005:00:00.0: bridge window [mem 0x1f40000000-0x1f400fffff]
[ 5.561981] pci 0005:00:00.0: Max Payload Size set to 128/ 256 (was 256), Max Read Rq 512
[ 5.562022] pci 0005:01:00.0: Max Payload Size set to 128/ 128 (was 128), Max Read Rq 512
[ 5.562281] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[ 5.562285] pci 0005:01:00.0: Signaling PME through PCIe PME interrupt
[ 5.562289] pcie_pme 0005:00:00.0:pcie001: service driver pcie_pme loaded
[ 5.562368] aer 0005:00:00.0:pcie002: service driver aer loaded
[ 5.562930] nvme nvme0: pci function 0005:01:00.0
[ 5.563035] nvme 0005:01:00.0: enabling device (0000 → 0002)
[ 5.573495] tegra-cbb 14040000.cv-noc: noc_secure_irq = 90, noc_nonsecure_irq = 89>
[ 5.577974] tegra194-isp5 14800000.isp: initialized
[ 5.584364] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[ 5.587544] tegra194-vi5 15c10000.vi: initialized
[ 5.591299] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–2 bound
[ 5.591412] tegra194-vi5 15c10000.vi: subdev 15a00000.nvcsi–1 bound
[ 5.591651] tegra-thermal-throttle bthrot_cdev: clk:cpu max:1907200000, min:115200000 steps:24
[ 5.593513] hid-generic 0003:046D:C534.0002: input,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.1/input1
[ 5.595901] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1109250000, min:114750000 steps:10
[ 5.595920] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[ 5.595923] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[ 5.595994] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:48 cutoff:0
[ 5.596038] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[ 5.596041] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[ 5.629511] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:40 cutoff:1
[ 5.629570] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[ 5.629574] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[ 5.629899] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:48 cutoff:0
[ 5.629941] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[ 5.629944] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[ 5.630283] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[ 5.630347] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[ 5.630350] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[ 5.630549] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:40 cutoff:1
[ 5.631319] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[ 5.673137] usb 1-2.2: new full-speed USB device number 5 using tegra-xusb
[ 5.687558] nvme0n1: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11
[ 5.701290] usb 1-2.2: New USB device found, idVendor=046d, idProduct=c539
[ 5.701294] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.701297] usb 1-2.2: Product: USB Receiver
[ 5.701301] usb 1-2.2: Manufacturer: Logitech
[ 5.704850] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.0/0003:046D:C539.0003/input/input6
[ 5.707780] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[ 5.708105] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[ 5.708292] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[ 5.708467] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[ 5.708895] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[ 5.708969] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[ 5.709205] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (65)
[ 5.709209] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[ 5.710101] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=4c29076f2400b1aca1797dafeba3d8643d889753
[ 5.710535] Wake83 for irq=211
[ 5.710601] gpio tegra-gpio wake67 for gpio=48(G:0)
[ 5.710670] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[ 5.710808] input: gpio-keys as /devices/gpio-keys/input/input7
[ 5.761772] hid-generic 0003:046D:C539.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3610000.xhci-2.2/input0
[ 5.764985] input: Logitech USB Receiver as /devices/3610000.xhci/usb1/1-2/1-2.2/1-2.2:1.1/0003:046D:C539.0004/input/input8
[ 5.795314] tegra_rtc c2a0000.rtc: setting system clock to 2000-01-01 01:36:14 UTC (946690574)
[ 5.796187] mmcblk mmc0:0001: Card claimed for testing.
[ 5.825511] hid-generic 0003:046D:C539.0004: input,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3610000.xhci-2.2/input1
[ 5.829842] hid-generic 0003:046D:C539.0005: hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-3610000.xhci-2.2/input2
[ 5.842280] bpmp: mounted debugfs mirror
[ 5.848141] ALSA device list:
[ 5.848146] #0: tegra-hda-xnx at 0x3518000 irq 64
[ 5.848148] #1: jetson-xaviernx-ape
[ 5.913136] usb 1-2.5: new high-speed USB device number 6 using tegra-xusb
[ 5.934127] usb 1-2.5: New USB device found, idVendor=0424, idProduct=2740
[ 5.934132] usb 1-2.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 5.934135] usb 1-2.5: Product: Hub Controller
[ 5.934138] usb 1-2.5: Manufacturer: Microchip Tech
[ 6.886866] extcon-disp-state external-connection:disp-state: cable 51 state 1
[ 6.889160] Freeing unused kernel memory: 8640K
[ 6.898445] Extcon HDMI: HPD enabled
[ 6.898479] tegradc 15200000.nvdisplay: hdmi: plugged
[ 6.943304] Root device found: PARTUUID=3378569a-4680-46b9-9814-89a6fef66dbd
[ 7.515999] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[ 7.528258] Rootfs mounted over PARTUUID=3378569a-4680-46b9-9814-89a6fef66dbd
[ 7.551848] Switching from initrd to actual rootfs
[ 7.624711] systemd[1]: System time before build time, advancing clock.
[ 7.645615] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 7.651529] cgroup: cgroup2: unknown option “nsdelegate”
[ 7.661762] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 7.665292] systemd[1]: Detected architecture arm64.
[ 7.682263] systemd[1]: Set hostname to .
[ 7.768188] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 7.771168] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 7.880138] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.887131] systemd[1]: Created slice System Slice.
[ 7.893226] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.896320] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 7.902447] random: systemd: uninitialized urandom read (16 bytes read)
[ 7.905384] systemd[1]: Listening on Journal Audit Socket.
[ 7.911804] systemd[1]: Listening on Syslog Socket.
[ 7.918224] systemd[1]: Reached target Swap.
[ 8.015003] EXT4-fs (nvme0n1p1): re-mounted. Opts: (null)
[ 8.030139] nvgpu: 17000000.gv11b nvgpu_nvhost_syncpt_init:291 [INFO] syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[ 8.502228] systemd-journald[2479]: Received request to flush runtime journal from PID 1
[ 8.596859] random: crng init done
[ 8.600723] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.933422] FAN rising trip_level:1 cur_temp:46700 trip_temps[2]:60000
[ 9.152399] using random self ethernet address
[ 9.152404] using random host ethernet address
[ 9.849032] Intel(R) Wireless WiFi driver for Linux
[ 9.849041] Copyright(c) 2003- 2015 Intel Corporation
[ 9.859921] iwlwifi 0004:01:00.0: enabling device (0000 → 0002)
[ 9.867681] iwlwifi 0004:01:00.0: Direct firmware load for iwlwifi-8265-26.ucode failed with error -2
[ 9.867686] iwlwifi 0004:01:00.0: Falling back to user helper
[ 9.895283] Mass Storage Function, version: 2009/09/11
[ 9.895290] LUN: removable file: (no medium)
[ 9.900665] using random self ethernet address
[ 9.906553] using random host ethernet address
[ 9.936445] rndis0: HOST MAC d2:a6:c4:4c:7f:9c
[ 9.938380] rndis0: MAC d2:a6:c4:4c:7f:9d
[ 9.940848] usb0: HOST MAC d2:a6:c4:4c:7f:9e
[ 9.941071] usb0: MAC d2:a6:c4:4c:7f:9f
[ 9.944098] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 9.951609] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 9.951627] tegra-xudc-new 3550000.xudc: ep 0 (type: 0, dir: out) enabled
[ 9.951670] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.951877] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.951890] tegra-xudc-new 3550000.xudc: exiting ELPG
[ 9.952409] tegra-xudc-new 3550000.xudc: exiting ELPG done
[ 9.952421] tegra-xudc-new 3550000.xudc: entering ELPG
[ 9.952603] tegra-xudc-new 3550000.xudc: entering ELPG done
[ 9.958034] l4tbr0: port 1(rndis0) entered blocking state
[ 9.958038] l4tbr0: port 1(rndis0) entered disabled state
[ 9.958417] device rndis0 entered promiscuous mode
[ 9.970327] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.975214] l4tbr0: port 2(usb0) entered blocking state
[ 9.975222] l4tbr0: port 2(usb0) entered disabled state
[ 9.982242] device usb0 entered promiscuous mode
[ 9.989085] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
