I have a setup with a RPI 4B, 4 Hawks eye cameras 64MP + hat, the devices are detected, but the image is just a black screen. When I run the manual focus python script, I can see the lenses move, but still no image. See details below.
arducam distributors
4x(64MP Hawks Eye) + 1x(hat)
Raspberry Pi 4B
5. Problems you were having?
- hat/cameras detected
- able to see lens movement on all cameras when trying to focus
- using libcamera as mentioned in the guide, the image is black
- with a black preview, I am also not able to grab images whatsoever
pi@raspberrypi:~ $ libcamera-still --list-cameras
[0:28:50.848708967] [1690] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:28:50.857376263] [1691] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:28:50.857428022] [1691] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:28:50.857823004] [1691] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:28:50.899134115] [1691] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:28:50.900113892] [1691] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:28:50.900573318] [1691] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media2 and ISP device /dev/media3
Available cameras
0 : arducam_64mp [9248x6944] (/base/soc/i2c0mux/i2c@1/arducam_64mp@1a)
Modes: 'SRGGB10_CSI2P' : 1280x720 1920x1080 2312x1736 3840x2160 4624x3472 9152x6944
pi@raspberrypi:~ $ libcamera-still -t 0 --camera 0
Made X/EGL preview window
[0:30:19.176352192] [1702] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:30:19.183279155] [1704] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:30:19.183377062] [1704] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:30:19.183821081] [1704] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:30:19.217084247] [1704] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:30:19.217898284] [1704] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:30:19.218244581] [1704] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media2 and ISP device /dev/media3
[0:30:19.219236562] [1702] INFO Camera camera.cpp:1029 configuring streams: (0) 4096x3074-YUV420
[0:30:19.219955858] [1704] INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
- you can see in the screenshot, the image is just a black screen.
- reinstalled raspbian to latest version,
pi@raspberrypi:~ $ cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.32-v7l+ #1538 SMP Thu Mar 31 19:39:41 BST 2022 armv7l GNU/Linux
pi@raspberrypi:~ $ cat /proc/cpuinfo
processor : 0
model name : ARMv7 Processor rev 3 (v7l)
BogoMIPS : 270.00
Features : half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 270.00
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2711
Revision : c03112
Serial : 10000000ce2b392b
Model : Raspberry Pi 4 Model B Rev 1.2
8. What help do you need?
Did anyone else experience this? Do you have some pointers on how to display images from the cameras?
