[ 0.000000] Linux version 6.1.21-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] Zone ranges:
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0, zone DMA32: 19456 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 29 pages/cpu s78504 r8192 d32088 u118784
[ 0.000000] pcpu-alloc: s78504 r8192 d32088 u118784 alloc=29*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028848
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_headphones=0 snd_bcm2835.enable_headphones=1 snd_bcm2835.enable_hdmi=1 snd_bcm2835.enable_hdmi=0 snd_bcm2835.enable_hdmi=0 smsc95xx.macaddr=DC:A6:32:DB:1E:45 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=5954e472-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] software IO TLB: area num 4.
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 7471348K/8245248K available (11776K kernel code, 2106K rwdata, 3688K rodata, 4160K init, 1077K bss, 249612K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 39744 entries in 156 pages
[ 0.000000] ftrace: allocated 156 pages with 4 groups
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000320] Console: colour dummy device 80x25
[ 0.000388] printk: console [tty1] enabled
[ 0.000458] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000484] pid_max: default: 32768 minimum: 301
[ 0.000607] LSM: Security Framework initializing
[ 0.000889] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001022] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002315] cgroup: Disabling memory control group subsystem
[ 0.004611] cblist_init_generic: Setting adjustable number of callback queues.
[ 0.004632] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004815] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.004993] cblist_init_generic: Setting shift to 2 and lim to 1.
[ 0.005462] rcu: Hierarchical SRCU implementation.
[ 0.005475] rcu: Max phase no-delay instances is 1000.
[ 0.006819] EFI services will not be available.
[ 0.007362] smp: Bringing up secondary CPUs …
[ 0.008533] Detected PIPT I-cache on CPU1
[ 0.008698] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009876] Detected PIPT I-cache on CPU2
[ 0.010005] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011113] Detected PIPT I-cache on CPU3
[ 0.011240] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011387] smp: Brought up 1 node, 4 CPUs
[ 0.011409] SMP: Total of 4 processors activated.
[ 0.011421] CPU features: detected: 32-bit EL0 Support
[ 0.011431] CPU features: detected: 32-bit EL1 Support
[ 0.011444] CPU features: detected: CRC32 instructions
[ 0.011579] CPU: All CPU(s) started at EL2
[ 0.011604] alternatives: applying system-wide alternatives
[ 0.013722] devtmpfs: initialized
[ 0.026367] Enabled cp15_barrier support
[ 0.026408] Enabled setend support
[ 0.026627] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.026664] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.040772] pinctrl core: initialized pinctrl subsystem
[ 0.041648] DMI not present or invalid.
[ 0.042343] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.045983] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.046287] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.047234] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.047329] audit: initializing netlink subsys (disabled)
[ 0.047615] audit: type=2000 audit(0.044:1): state=initialized audit_enabled=0 res=1
[ 0.048228] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.048318] cpuidle: using governor menu
[ 0.048789] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.048989] ASID allocator initialised with 32768 entries
[ 0.049156] Serial: AMBA PL011 UART driver
[ 0.064810] platform fe101000.cprman: Fixed dependency cycle(s) with /soc/dsi@7e700000
[ 0.065938] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.081652] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/arducam_64mp@1a
[ 0.088740] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-03-17T10:50:39, variant start
[ 0.092755] raspberrypi-firmware soc:firmware: Firmware hash is 82f3750a65fadae9a38077e3c2e217ad158c8d54
[ 0.109219] KASLR enabled
[ 0.143604] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.149510] SCSI subsystem initialized
[ 0.149786] usbcore: registered new interface driver usbfs
[ 0.149846] usbcore: registered new interface driver hub
[ 0.149912] usbcore: registered new device driver usb
[ 0.150334] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.150561] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.150916] pps_core: LinuxPPS API ver. 1 registered
[ 0.150928] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.150955] PTP clock support registered
[ 0.152082] vgaarb: loaded
[ 0.152882] clocksource: Switched to clocksource arch_sys_counter
[ 1.314730] VFS: Disk quotas dquot_6.6.0
[ 1.314830] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.315021] FS-Cache: Loaded
[ 1.315294] CacheFiles: Loaded
[ 1.324659] NET: Registered PF_INET protocol family
[ 1.325793] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.334737] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.334844] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 1.334878] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.335354] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 1.338156] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.338432] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.338574] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.338950] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 1.339827] RPC: Registered named UNIX socket transport module.
[ 1.339844] RPC: Registered udp transport module.
[ 1.339854] RPC: Registered tcp transport module.
[ 1.339864] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.339889] PCI: CLS 0 bytes, default 64
[ 1.342627] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.343010] kvm [1]: IPA Size Limit: 44 bits
[ 1.344353] kvm [1]: vgic interrupt IRQ9
[ 1.344589] kvm [1]: Hyp mode initialized successfully
[ 1.346856] Initialise system trusted keyrings
[ 1.347251] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.354759] zbud: loaded
[ 1.357744] NFS: Registering the id_resolver key type
[ 1.357787] Key type id_resolver registered
[ 1.357798] Key type id_legacy registered
[ 1.357915] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.357932] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.359298] Key type asymmetric registered
[ 1.359316] Asymmetric key parser ‘x509’ registered
[ 1.359411] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.359712] io scheduler mq-deadline registered
[ 1.359729] io scheduler kyber registered
[ 1.361934] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 27)
[ 1.371565] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.371612] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.371703] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.371788] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.372803] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.372824] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.372842] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.372958] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.373218] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.377482] pci_bus 0000:01: supply vpcie3v3 not found, using dummy regulator
[ 1.377675] pci_bus 0000:01: supply vpcie3v3aux not found, using dummy regulator
[ 1.377786] pci_bus 0000:01: supply vpcie12v not found, using dummy regulator
[ 1.446987] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.447154] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.447283] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.447767] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.448510] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.448536] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.448580] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.448602] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.449713] simple-framebuffer 3ea83000.framebuffer: framebuffer at 0x3ea83000, 0x177000 bytes
[ 1.449733] simple-framebuffer 3ea83000.framebuffer: format=a8r8g8b8, mode=800x480x32, linelength=3200
[ 1.450250] Console: switching to colour frame buffer device 100x30
[ 1.451901] simple-framebuffer 3ea83000.framebuffer: fb0: simplefb registered!
[ 1.465244] iproc-rng200 fe104000.rng: hwrng registered
[ 1.465855] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.467409] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.480491] brd: module loaded
[ 1.489218] loop: module loaded
[ 1.490064] Loading iSCSI transport class v2.0-870.
[ 1.495524] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.553220] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.554436] usbcore: registered new interface driver r8152
[ 1.554513] usbcore: registered new interface driver lan78xx
[ 1.554581] usbcore: registered new interface driver smsc95xx
[ 1.602261] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.602444] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.602476] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.603274] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.604342] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.604365] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.604387] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.604776] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.01
[ 1.604797] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.604813] usb usb1: Product: xHCI Host Controller
[ 1.604827] usb usb1: Manufacturer: Linux 6.1.21-v8+ xhci-hcd
