Hi, I’m stuck with a black screen on the Arducam 64MP quad camera kit no matter what I try. I just installed Bullseye fresh (Raspberry Pi OS Bullseye), connected the camera through the quad interface board, and followed every step in the manual. Still black every single time. The weird part is I was using a 16MP camera before this and it worked fine.
Here’s the Python script I was using with the 16MP camera (picamera2). My question is will this same script work with the 64MP quad camera?
#!/usr/bin/python3
from ast import main
from gpiozero import Button, LED
import time
button = Button(23)
led = LED(18)
start = time.time()
picam2 = Picamera2()
capture_config = picam2.create_still_configuration(main={"size": (4656, 3496)})
picam2.set_controls({"ExposureTime": 500})
picam2.configure(capture_config)
picam2.start()
picam2.set_controls({"AfMode": 0, "LensPosition": 200.0})
open_camera_time= time.time()
i= 1
while True:
button.wait_for_press()
led.on()
time.sleep(0.1)
led.off()
picam2.capture_file('/media/ton/TOP/pic'+str(i)+'.jpg')
button.wait_for_release()
time.sleep(0.2)
i= i+1
print(i)
For now I only want to start with 1 camera connected to the quad interface board to check speed and resolution. No logs really, since I just get a black image no matter what. Any help would be appreciated.
Hi, thanks for the detailed post. Before anything else, it would help to go through our Picamera2 guide for the Arducam V1/V2/HQ 16MP AF / 64MP AF / Pivariety cameras — it covers the setup and library specifics that differ from a normal Picamera2 workflow:
There’s a good chance your black screen comes from a config/init step that this guide addresses for the 64MP sensor, even though your 16MP script was working.
To answer your direct question: your existing script likely won’t work as-is for the 64MP quad camera — the resolution you’re setting (4656x3496) is sized for the 16MP sensor, not the 64MP one, and the quad setup needs the guide’s setup steps first.
If you follow the guide and still get a black image, let us know and we’ll dig in further.
Thanks, I’ll go through the guide. In the meantime, are there any Python3 examples for operating the quad cameras? I’d like to get to a point where I attach 2 cameras and take a picture with camera1, then camera2, then back to camera1, etc. Is there sample code for switching between the cameras on the quad board like that?
Sorry for the wait on this one. Writing a script for the quad setup like that can take some time, and we’re pretty swamped with support requests during the weekdays. Give me a bit of time — I’ll try to get the script written up for you over the weekend. Thanks for your patience!
