Hi, I’m stuck getting the Arducam 64mp quad camera kit to work and I keep getting a black screen no matter what I try. I installed a fresh Bullseye OS and followed all the steps as per the manual. I previously tested with the 16mp camera and got good results (I was really happy with it), but the 64mp quad kit just gives me black images every time. This looks like exactly, 100% the same issue as this thread: Black image with Arducam 64MP quad-cam setup
Hi, sorry to hear you’re hitting that black screen. Let’s get some details so we can figure this out.
Can you confirm:
Exact kit: 64mp quad camera kit
OS: freshly installed Bullseye, correct?
Which library are you using - picamera2?
Also, can you paste the script you’re running and let us know if there’s any error output in the terminal when it runs? If there are no logs, that’s fine too - just let us know. Since you already had the 16mp working with picamera2, we can probably reuse a lot of that.
Yes, it’s the 64mp quad camera kit on a freshly installed Bullseye, and I’m using picamera2.
Here’s the script I was using successfully with the 16mp camera - will this work for the 64mp quad camera, or does it need changes?
#!/usr/bin/python3
from ast import main
from gpiozero import Button, LED
import time
button = Button(23)
led = LED(18)
start = time.time()
picam2 = Picamera2()
capture_config = picam2.create_still_configuration(main={"size": (4656, 3496)})
picam2.set_controls({"ExposureTime": 500})
picam2.configure(capture_config)
picam2.start()
picam2.set_controls({"AfMode": 0, "LensPosition": 200.0})
open_camera_time= time.time()
i= 1
while True:
button.wait_for_press()
led.on()
time.sleep(0.1)
led.off()
picam2.capture_file('/media/ton/TOP/pic'+str(i)+'.jpg')
button.wait_for_release()
time.sleep(0.2)
i= i+1
print(i)
What I’m actually trying to get to is a setup with 2 cameras where I take a picture with camera1, then camera2, then back to camera1, etc. But to start with, I want to just get 1 camera connected to the quad interface board working so I can check the speed and resolution. Are there any Python3 examples for operating the quad cameras? I couldn’t find anything that matches what I need.
Thanks, that script helps a lot as a starting point.
To be upfront: the multi-camera (alternating capture) case is a bit different from the single 16mp setup, and the quad kit has its own requirements. Writing a dedicated script for your exact use case (camera1 → camera2 → back to camera1) will take me some time. I’ll try to put it together over the weekend.
In the meantime, a couple of quick things worth checking so we can rule out the basics before the script lands:
Make sure the camera(s) are fully seated in the quad interface board connectors.
Double-check the ribbon cable orientation on both ends.
Confirm you’re only running one camera to start with on the interface board.
Check whether picam2.detect() or libcamera-hello --list-cameras actually detects the 64mp sensor - that will tell us if it’s a detection/connection problem vs. a capture/config problem.
If the sensor shows up but capture is still black, that points us in a different direction than if it isn’t detected at all.
Thanks for the quick reply. No objection at all to the delay - take the time you need, I’d rather have it working than rushed.
I’ll check the seating and cable orientation like you suggested while I wait. Just to restate the outstanding problem for the thread: I still get a black screen with the 64mp quad camera kit on a fresh Bullseye install, matching that forum thread I linked above. The 16mp camera worked fine with the same picamera2 approach.
Appreciate the patience. Quick update: I’m developing the Python script for the multi-camera operation for you now. I’ll be testing it this evening to make sure it actually works before handing it over - no point sending you something untested.
The plan is to first validate a single camera on the quad interface board (speed + resolution), then extend it to the alternating two-camera capture you described.
Thanks for the update, that sounds good. I’m happy to wait - just let me know when the script is ready and I’ll give it a go. I’ll report back with what I see (and any logs) once I can run it.
The symptom is a black image with the Arducam 64mp quad camera kit on a freshly installed Bullseye OS, which matches the known report in this thread: Black image with Arducam 64MP quad-cam setup
The same picamera2 workflow worked fine previously with the 16mp camera, so the environment itself is sound.
Root cause is not confirmed yet - it could be detection/cabling, or the single-camera config not being correct for the 64mp sensor on the quad interface board.
The end goal is alternating two-camera capture (camera1 → camera2 → back to camera1), starting with a single camera connected to the quad interface board to check speed and resolution.
Next step: I’m finishing and testing a dedicated Python script for the multi-camera capture use case, and I’ll deliver it once it’s verified. If you can, run libcamera-hello --list-cameras in the meantime and post the output here - that’ll help us tell a connection/detection issue apart from a capture issue before the script arrives.
