dmesg Part 1
cat dmesg.log
[ 0.000000] Linux version 5.15.84-v7l+ ([email protected]) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 12:01:26 GMT 2023
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[ 0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 1011008
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:[email protected] smsc95xx.macaddr=DC:A6:32:A8:6D:93 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=35308fdc-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3601252K/4050944K available (10240K kernel code, 1386K rwdata, 3308K rodata, 2048K init, 591K bss, 122012K reserved, 327680K cma-reserved, 3264512K highmem)
[ 0.000000] ftrace: allocating 35518 entries in 105 pages
[ 0.000000] ftrace: allocated 105 pages with 4 groups
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/[email protected], parent irq: 25)
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000019] Switching to timer-based delay loop, resolution 18ns
[ 0.000393] Console: colour dummy device 80x30
[ 0.000460] printk: console [tty1] enabled
[ 0.000526] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.000556] pid_max: default: 32768 minimum: 301
[ 0.000699] LSM: Security Framework initializing
[ 0.000902] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000934] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002532] cgroup: Disabling memory control group subsystem
[ 0.002797] CPU: Testing write buffer coherency: ok
[ 0.002855] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[ 0.003321] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004812] Setting up static identity map for 0x200000 - 0x20003c
[ 0.005011] rcu: Hierarchical SRCU implementation.
[ 0.006018] smp: Bringing up secondary CPUs …
[ 0.007278] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008689] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010080] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.010242] smp: Brought up 1 node, 4 CPUs
[ 0.010266] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.010284] CPU: All CPU(s) started in HYP mode.
[ 0.010297] CPU: Virtualization extensions available.
[ 0.011108] devtmpfs: initialized
[ 0.032164] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.032401] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.032436] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.043084] pinctrl core: initialized pinctrl subsystem
[ 0.044361] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.048834] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.049675] audit: initializing netlink subsys (disabled)
[ 0.049972] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.050610] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.051443] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.051463] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.052014] Serial: AMBA PL011 UART driver
[ 0.068950] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.110071] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:46:54, variant start
[ 0.120087] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[ 0.180986] Kprobes globally optimized
[ 0.187117] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.192155] vgaarb: loaded
[ 0.192648] SCSI subsystem initialized
[ 0.192878] usbcore: registered new interface driver usbfs
[ 0.192941] usbcore: registered new interface driver hub
[ 0.193026] usbcore: registered new device driver usb
[ 0.193469] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.193658] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.193973] pps_core: LinuxPPS API ver. 1 registered
[ 0.193988] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.194015] PTP clock support registered
[ 0.195745] clocksource: Switched to clocksource arch_sys_counter
[ 0.276516] VFS: Disk quotas dquot_6.6.0
[ 0.276626] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.276810] FS-Cache: Loaded
[ 0.277031] CacheFiles: Loaded
[ 0.278229] simple-framebuffer 3e3cf000.framebuffer: framebuffer at 0x3e3cf000, 0x7f8000 bytes
[ 0.278253] simple-framebuffer 3e3cf000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.278789] Console: switching to colour frame buffer device 240x67
[ 0.289388] simple-framebuffer 3e3cf000.framebuffer: fb0: simplefb registered!
[ 0.299905] NET: Registered PF_INET protocol family
[ 0.300162] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.301807] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.301843] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.301867] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.301932] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.302005] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.302167] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.302205] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.302457] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.306704] RPC: Registered named UNIX socket transport module.
[ 0.306721] RPC: Registered udp transport module.
[ 0.306736] RPC: Registered tcp transport module.
[ 0.306750] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.306775] PCI: CLS 0 bytes, default 64
[ 1.352866] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.355542] Initialise system trusted keyrings
[ 1.355878] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.364957] zbud: loaded
[ 1.367084] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.367935] NFS: Registering the id_resolver key type
[ 1.367975] Key type id_resolver registered
[ 1.367990] Key type id_legacy registered
[ 1.368128] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.368145] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.369253] Key type asymmetric registered
[ 1.369269] Asymmetric key parser ‘x509’ registered
[ 1.369500] bounce: pool size: 64 pages
[ 1.369564] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.369809] io scheduler mq-deadline registered
[ 1.369825] io scheduler kyber registered
[ 1.379615] brcm-pcie fd500000.pcie: host bridge /scb/[email protected] ranges:
[ 1.379659] brcm-pcie fd500000.pcie: No bus range found for /scb/[email protected], using [bus 00-ff]
[ 1.379754] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.379848] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.437846] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.438242] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.438262] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.438284] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.438378] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.438626] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.443991] PCI: bus0: Fast back to back transfers disabled
[ 1.444330] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.444461] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.444893] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.450206] PCI: bus1: Fast back to back transfers disabled
[ 1.450270] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.450296] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.450382] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.450409] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.450851] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.451095] pcieport 0000:00:00.0: PME: Signaling with IRQ 79
[ 1.465751] iproc-rng200 fe104000.rng: hwrng registered
[ 1.466140] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.467820] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.481018] brd: module loaded
[ 1.491666] loop: module loaded
[ 1.492555] Loading iSCSI transport class v2.0-870.
[ 1.498023] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.595939] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.597267] usbcore: registered new interface driver r8152
[ 1.597339] usbcore: registered new interface driver lan78xx
[ 1.597411] usbcore: registered new interface driver smsc95xx
[ 1.599072] xhci_hcd 0000:01:00.0: enabling device (0140 → 0142)
[ 1.599266] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.599302] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.605021] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000e40000000890
[ 1.606181] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.606210] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.606238] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.606686] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.606710] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.606729] usb usb1: Product: xHCI Host Controller
[ 1.606747] usb usb1: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[ 1.606763] usb usb1: SerialNumber: 0000:01:00.0
[ 1.607528] hub 1-0:1.0: USB hub found
[ 1.607604] hub 1-0:1.0: 1 port detected
[ 1.608669] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.608692] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.608711] usb usb2: Product: xHCI Host Controller
[ 1.608728] usb usb2: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[ 1.608744] usb usb2: SerialNumber: 0000:01:00.0
[ 1.609466] hub 2-0:1.0: USB hub found
[ 1.609538] hub 2-0:1.0: 4 ports detected
[ 1.611433] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.611826] dwc_otg: FIQ enabled
[ 1.611841] dwc_otg: NAK holdoff enabled
[ 1.611857] dwc_otg: FIQ split-transaction FSM enabled
[ 1.611874] Module dwc_common_port init
[ 1.612328] usbcore: registered new interface driver uas
[ 1.612435] usbcore: registered new interface driver usb-storage
[ 1.612671] mousedev: PS/2 mouse device common for all mice
[ 1.618283] sdhci: Secure Digital Host Controller Interface driver
[ 1.618301] sdhci: Copyright(c) Pierre Ossman
[ 1.619094] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.623210] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.623505] hid: raw HID events driver (C) Jiri Kosina
[ 1.623666] usbcore: registered new interface driver usbhid
[ 1.623682] usbhid: USB HID core driver
[ 1.630499] Initializing XFRM netlink socket
[ 1.630544] NET: Registered PF_PACKET protocol family
[ 1.630662] Key type dns_resolver registered
[ 1.631156] Registering SWP/SWPB emulation handler
[ 1.632000] registered taskstats version 1
[ 1.632027] Loading compiled-in X.509 certificates
[ 1.632911] Key type .fscrypt registered
[ 1.632928] Key type fscrypt-provisioning registered
[ 1.646207] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.646539] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.646680] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[ 1.656210] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.656707] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.658070] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.658092] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.688223] of_cfs_init
[ 1.688491] of_cfs_init: OK
[ 1.723162] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.723769] Waiting for root device PARTUUID=35308fdc-02…
[ 1.822217] mmc0: new ultra high speed DDR50 SDHC card at address 0001
[ 1.824410] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 1.830065] mmcblk0: p1 p2
[ 1.830113] mmc1: new high speed SDIO card at address 0001
[ 1.831238] mmcblk0: mmc0:0001 EB1QT 29.8 GiB
[ 1.850317] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.850409] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.851338] devtmpfs: mounted
[ 1.862585] Freeing unused kernel image (initmem) memory: 2048K
[ 1.886070] Run /sbin/init as init process
[ 1.886087] with arguments:
[ 1.886099] /sbin/init
[ 1.886113] splash
[ 1.886125] with environment:
[ 1.886137] HOME=/
[ 1.886150] TERM=linux
[ 1.895799] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 2.089181] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 2.089215] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 2.089235] usb 1-1: Product: USB2.0 Hub
[ 2.091561] hub 1-1:1.0: USB hub found
[ 2.091945] hub 1-1:1.0: 4 ports detected
[ 2.225468] systemd[1]: System time before build time, advancing clock.
[ 2.236241] usb 2-1: new SuperSpeed USB device number 2 using xhci_hcd
[ 2.267948] usb 2-1: New USB device found, idVendor=090c, idProduct=1000, bcdDevice=11.00
[ 2.267981] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.268002] usb 2-1: Product: Flash Drive FIT
[ 2.268019] usb 2-1: Manufacturer: Samsung
[ 2.268035] usb 2-1: SerialNumber: 0307122110003205
[ 2.333496] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 2.334508] scsi host0: usb-storage 2-1:1.0
[ 2.425819] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[ 2.431787] NET: Registered PF_INET6 protocol family
[ 2.433629] Segment Routing with IPv6
[ 2.433672] In-situ OAM (IOAM) with IPv6
[ 2.512150] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.513049] systemd[1]: Detected architecture arm.
[ 2.523888] systemd[1]: Set hostname to .
[ 2.584163] usb 1-1.3: New USB device found, idVendor=0461, idProduct=4e22, bcdDevice= 1.00
[ 2.584203] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.584225] usb 1-1.3: Product: USB Optical Mouse
[ 2.584243] usb 1-1.3: Manufacturer: PixArt
[ 2.596060] input: PixArt USB Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:0461:4E22.0001/input/input0
[ 2.596722] hid-generic 0003:0461:4E22.0001: input,hidraw0: USB HID v1.11 Mouse [PixArt USB Optical Mouse] on usb-0000:01:00.0-1.3/input0
[ 2.695854] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 2.834525] usb 1-1.4: New USB device found, idVendor=413c, idProduct=2113, bcdDevice=33.08
[ 2.834557] usb 1-1.4: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 2.834578] usb 1-1.4: Product: Dell KB216 Wired Keyboard
[ 2.846986] input: Dell KB216 Wired Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:2113.0002/input/input1
[ 2.926775] hid-generic 0003:413C:2113.0002: input,hidraw1: USB HID v1.11 Keyboard [Dell KB216 Wired Keyboard] on usb-0000:01:00.0-1.4/input0
[ 2.935784] input: Dell KB216 Wired Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:413C:2113.0003/input/input2
[ 3.016350] input: Dell KB216 Wired Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.1/0003:413C:2113.0003/input/input3
[ 3.016931] hid-generic 0003:413C:2113.0003: input,hiddev96,hidraw2: USB HID v1.11 Device [Dell KB216 Wired Keyboard] on usb-0000:01:00.0-1.4/input1
[ 3.247399] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ‘mixed’ or ‘control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.440515] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.446313] systemd[1]: Created slice system-getty.slice.
[ 3.447730] systemd[1]: Created slice system-modprobe.slice.
[ 3.448695] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.449559] systemd[1]: Created slice User and Session Slice.
[ 3.450159] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.451349] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.452028] systemd[1]: Reached target Slices.
[ 3.452244] systemd[1]: Reached target Swap.
[ 3.455809] systemd[1]: Listening on Syslog Socket.
[ 3.456641] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.457054] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.458471] systemd[1]: Listening on Journal Audit Socket.
[ 3.459250] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.460235] systemd[1]: Listening on Journal Socket.
[ 3.465532] systemd[1]: Listening on udev Control Socket.
[ 3.466893] systemd[1]: Listening on udev Kernel Socket.
[ 3.467851] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.473610] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.480272] systemd[1]: Mounting RPC Pipe File System…
[ 3.487510] systemd[1]: Mounting Kernel Debug File System…
[ 3.495586] systemd[1]: Mounting Kernel Trace File System…
[ 3.496897] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.507690] systemd[1]: Starting Restore / save the current clock…
[ 3.516139] systemd[1]: Starting Set the console keyboard layout…
[ 3.524952] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.533984] systemd[1]: Starting Load Kernel Module configfs…
[ 3.541808] systemd[1]: Starting Load Kernel Module drm…
[ 3.551156] systemd[1]: Starting Load Kernel Module fuse…
[ 3.557943] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.566337] systemd[1]: Starting File System Check on Root Device…
[ 3.604936] systemd[1]: Starting Journal Service…
[ 3.624643] systemd[1]: Starting Load Kernel Modules…
[ 3.647186] systemd[1]: Starting Coldplug All udev Devices…
[ 3.650924] fuse: init (API version 7.34)
