IMX519 PDAF Release
This thread is used to publish the description of the latest PDAF focusing algorithm of IMX519.
What is PDAF?
Why release Dual Mode(PDAF + CDAF)?
Because many users reported that the focusing time of imx519 is too long, so we changed the focusing algorithm from the original CDAF to the current Dual Mode(PDAF + CDAF).
Now the focus time is shorter and the effect is better.
if you want to use imx519 PDAF, you need to install the corresponding driver and Libcamera.
Note: The new pdaf algorithm is written by Raspberry Pi.
How to install the latest Dual Mode(PDAF + CDAF)?
(Even if you installed it before, it needs to be reinstalled)
prerequisites required
First of all, you need to make sure that your version is above 5.15.84
uname -r
Install the Camera Driver
./install_pivariety_pkgs.sh -p imx519_kernel_driver_low_speed
libcamera-dev and libcamera-apps Installation
./install_pivariety_pkgs.sh -p libcamera
I updated the kernel version to 6.1.19 (I tried also 5.15.87 and 5.15.88) and and I got this error :frowning:
Could you please help me?
I’m working on a Raspberry Pi 3b+ and Quad Camera IMX-519 array
@cicintrip
Please be patient, this will be completed and published in the next two days.
Thank you :slight_smile:
Please notify me when it will be completed: I’m working on a Thesis and I need my 16MP IMX-519 Autofocus Quad cameras ready (now I’m having a lot of troubles)
@cicintrip
It’s published now, you can try again
Still not working…
I updated and upgraded the system :frowning:
Please find here arducam bugs - Google Drive “arducam-bug-report.txt” (with respect to the previous screen I reinstalled kernel 5.15.87-v7+ in order to install the old drivers)
@cicintrip
Please do not use rpi-update to upgrade, we currently only support stable kernel releases.
https://forums.raspberrypi.com/viewtopic.php?p=2048995#p2048995
6.1.19 is currently available.
You can now downgrade the kernel or re-flash the system with
sudo apt-get update
sudo apt-get upgrade
Hello! I’m having this issue as well, exactly the same as pics however as of today 6.1.19-v8+ is the version provided by
sudo apt-get update
on my rasp pi 4.
Is support for this version (v8+) planned or do I need to look into rolling back my version?
@mdblocker
We have already supported it, and all the modified imx519 after 6.1.21 have been merged into the linux repository of the Raspberry Pi.
I am also facing the same issue as the other users.
kernel version - 6.1.19-v8+
Hardware Revision: c03115
Kernel Version: 6.1.19-v8+
OS Codename: bullseye
ARCH: aarch64
kernel:6.1.19-v8+
Unsupported package.
Supported packages:
imx708_kernel_driver
libcamera
64mp_pi_hawk_eye_kernel_driver
libcamera_apps
libcamera_dev
kernel_driver
Please can you provide urgent help
@Edward the question is
looking here
Quick Start - Arducam Wiki
as the QuickStart seems to install everything is the PDAF install needed at all as it calls drivers that don’t exist
@jinnn_1989
What command did you execute?
I just found out that the docs I wrote seem to be somewhat wrong, maybe misleading you. i want to say sorry to you
Hi @Edward , how is the pdaf integration in libcamera going on? Any estimated time of arrival or roadmap avail?
@mgrl
We have committed everything to the rapsberrypi branch. There are still some problems in libcamera that need to be solved, and the current progress is not fast.
I will post a sticky post to remind everyone when there is news about libcamera.
OK so i did install the right bits and it was a typo, didn’t help though as AF still doesn’t seem to work
@flipside
okay.
Pls give me some more information:
uname -a
dpkg -l | grep libcamera
Will there be a Jetson support?
What kernel versions are currently running?
I am trying with the latest (6.1.23-v8+) and get the following:
