Ordered directly from arducam.com -
SKU: B0402
64MP Autofocus Quad-Camera Kit for Raspberry Pi
Camarray HAT UC-512 Rev.D1
64 MP autofocus camera modules -
Raspberry Pi Model 3B+
Fresh install of Raspberry Pi OS (32-bit) Released 2022-04-04
Did not choose to update raspberry pi OS on setup after fresh installation
Camarray HAT installed with MIPI TX port connected to Raspberry Pi’s camera port and all four 64MP cameras connected to MIPI RX0, RX1, RX2, RX3 -
https://www.arducam.com/downloads/64mp-autofocus-quad-camera-kit.pdf
Followed Pi 0-3 user instructions including enabling Glamor and GL (Full KMS) -
aeronaut@raspberrypi:~ $ libcamera-still --list-cameras
[0:44:27.755075051] [2537] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
No cameras available!
aeronaut@raspberrypi:~ $ dmesg
[ 0.000000] Linux version 5.15.32-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP Thu Mar 31 19:38:48 BST 2022
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] percpu: Embedded 16 pages/cpu s35660 r8192 d21684 u65536
[ 0.000000] pcpu-alloc: s35660 r8192 d21684 u65536 alloc=16*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 227360
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=e8061e80-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[ 0.000000] Memory: 629344K/917504K available (10240K kernel code, 1341K rwdata, 3060K rodata, 1024K init, 568K bss, 26016K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 33185 entries in 98 pages
[ 0.000000] ftrace: allocated 98 pages with 3 groups
[ 0.000000] random: get_random_bytes called from start_kernel+0x538/0x71c with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000001] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000360] Console: colour dummy device 80x30
[ 0.000436] printk: console [tty1] enabled
[ 0.000503] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000535] pid_max: default: 32768 minimum: 301
[ 0.000700] LSM: Security Framework initializing
[ 0.000890] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.000920] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002521] cgroup: Disabling memory control group subsystem
[ 0.002810] CPU: Testing write buffer coherency: ok
[ 0.003408] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004661] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004851] rcu: Hierarchical SRCU implementation.
[ 0.005810] smp: Bringing up secondary CPUs ...
[ 0.007009] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.008324] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009523] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009672] smp: Brought up 1 node, 4 CPUs
[ 0.009696] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009715] CPU: All CPU(s) started in HYP mode.
[ 0.009726] CPU: Virtualization extensions available.
[ 0.010777] devtmpfs: initialized
[ 0.029822] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.030174] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.030211] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.042618] pinctrl core: initialized pinctrl subsystem
[ 0.044048] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.048905] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.054761] audit: initializing netlink subsys (disabled)
[ 0.055064] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.055721] thermal_sys: Registered thermal governor 'step_wise'
[ 0.056846] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.056867] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.057158] Serial: AMBA PL011 UART driver
[ 0.067328] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.100160] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:20:54, variant start
[ 0.110175] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[ 0.159087] Kprobes globally optimized
[ 0.164241] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.166582] SCSI subsystem initialized
[ 0.166868] usbcore: registered new interface driver usbfs
[ 0.166950] usbcore: registered new interface driver hub
[ 0.167024] usbcore: registered new device driver usb
[ 0.167405] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.167868] pps_core: LinuxPPS API ver. 1 registered
[ 0.167883] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[ 0.167914] PTP clock support registered
[ 0.170675] clocksource: Switched to clocksource arch_sys_counter
[ 0.241073] VFS: Disk quotas dquot_6.6.0
[ 0.241206] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.241423] FS-Cache: Loaded
[ 0.241745] CacheFiles: Loaded
[ 0.242778] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 0.242801] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.243417] Console: switching to colour frame buffer device 240x67
[ 0.278408] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 0.289483] NET: Registered PF_INET protocol family
[ 0.289796] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.291526] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.291579] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.291711] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.291909] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.292103] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.292166] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.292489] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.301267] RPC: Registered named UNIX socket transport module.
[ 0.301286] RPC: Registered udp transport module.
[ 0.301299] RPC: Registered tcp transport module.
[ 0.301311] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.908687] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.912878] Initialise system trusted keyrings
[ 1.913202] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.923402] zbud: loaded
[ 1.925661] FS-Cache: Netfs 'nfs' registered for caching
[ 1.926676] NFS: Registering the id_resolver key type
[ 1.926738] Key type id_resolver registered
[ 1.926752] Key type id_legacy registered
[ 1.926907] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.926923] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.928224] Key type asymmetric registered
[ 1.928240] Asymmetric key parser 'x509' registered
[ 1.928341] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.928359] io scheduler mq-deadline registered
[ 1.928373] io scheduler kyber registered
[ 1.939832] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.940562] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.941912] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.954606] brd: module loaded
[ 1.965073] loop: module loaded
[ 1.965866] Loading iSCSI transport class v2.0-870.
[ 1.967919] usbcore: registered new interface driver lan78xx
[ 1.967995] usbcore: registered new interface driver smsc95xx
[ 1.968023] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.696318] Core Release: 2.80a
[ 2.696342] Setting default values for core params
[ 2.696374] Finished setting default values for core params
[ 2.896743] Using Buffer DMA mode
[ 2.896756] Periodic Transfer Interrupt Enhancement - disabled
[ 2.896770] Multiprocessor Interrupt Enhancement - disabled
[ 2.896784] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.896834] Dedicated Tx FIFOs mode
[ 2.898401] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9ed04000 dma = 0xded04000 len=9024
[ 2.898448] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.898468] dwc_otg: Microframe scheduler enabled
[ 2.898598] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.898616] WARN::hcd_init_fiq:458: FIQ ASM at 807f3124 length 36
[ 2.898638] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[ 2.898662] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.898704] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.898758] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.898822] Init: Port Power? op_state=1
[ 2.898834] Init: Power Port (0)
[ 2.899217] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 2.899241] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.899261] usb usb1: Product: DWC OTG Controller
[ 2.899277] usb usb1: Manufacturer: Linux 5.15.32-v7+ dwc_otg_hcd
[ 2.899293] usb usb1: SerialNumber: 3f980000.usb
[ 2.900100] hub 1-0:1.0: USB hub found
[ 2.900168] hub 1-0:1.0: 1 port detected
[ 2.901184] dwc_otg: FIQ enabled
[ 2.901199] dwc_otg: NAK holdoff enabled
[ 2.901212] dwc_otg: FIQ split-transaction FSM enabled
[ 2.901230] Module dwc_common_port init
[ 2.901622] usbcore: registered new interface driver usb-storage
[ 2.901873] mousedev: PS/2 mouse device common for all mice
[ 2.905636] sdhci: Secure Digital Host Controller Interface driver
[ 2.905655] sdhci: Copyright(c) Pierre Ossman
[ 2.906185] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.908980] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.909333] hid: raw HID events driver (C) Jiri Kosina
[ 2.909500] usbcore: registered new interface driver usbhid
[ 2.909516] usbhid: USB HID core driver
[ 2.915467] Initializing XFRM netlink socket
[ 2.915520] NET: Registered PF_PACKET protocol family
[ 2.915688] Key type dns_resolver registered
[ 2.916444] Registering SWP/SWPB emulation handler
[ 2.917243] registered taskstats version 1
[ 2.917277] Loading compiled-in X.509 certificates
[ 2.918187] Key type ._fscrypt registered
[ 2.918203] Key type .fscrypt registered
[ 2.918215] Key type fscrypt-provisioning registered
[ 2.930769] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.930958] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 2.933801] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.934248] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.936037] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.936059] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.964267] sdhost: log_buf @ (ptrval) (ded03000)
[ 3.014468] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.030430] Indeed it is in host mode hprt0 = 00021501
[ 3.037421] of_cfs_init
[ 3.037689] of_cfs_init: OK
[ 3.039048] Waiting for root device PARTUUID=e8061e80-02...
[ 3.092993] mmc1: new high speed SDIO card at address 0001
[ 3.104503] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.109028] mmc0: new high speed SDHC card at address aaaa
[ 3.109919] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 3.114719] mmcblk0: p1 p2
[ 3.115415] mmcblk0: mmc0:aaaa SC32G 29.7 GiB
[ 3.134163] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.134286] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.135186] devtmpfs: mounted
[ 3.143881] Freeing unused kernel image (initmem) memory: 1024K
[ 3.160763] Run /sbin/init as init process
[ 3.160779] with arguments:
[ 3.160791] /sbin/init
[ 3.160803] splash
[ 3.160814] with environment:
[ 3.160825] HOME=/
[ 3.160837] TERM=linux
[ 3.240315] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.240578] Indeed it is in host mode hprt0 = 00001101
[ 3.480763] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.480807] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.481749] hub 1-1:1.0: USB hub found
[ 3.481875] hub 1-1:1.0: 4 ports detected
[ 3.653817] systemd[1]: System time before build time, advancing clock.
[ 3.800407] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.819665] NET: Registered PF_INET6 protocol family
[ 3.821425] Segment Routing with IPv6
[ 3.821477] In-situ OAM (IOAM) with IPv6
[ 3.926693] systemd[1]: systemd 247.3-7+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 3.927869] systemd[1]: Detected architecture arm.
[ 3.930361] systemd[1]: Set hostname to <raspberrypi>.
[ 3.930761] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.930790] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.931687] hub 1-1.1:1.0: USB hub found
[ 3.931825] hub 1-1.1:1.0: 3 ports detected
[ 4.030376] usb 1-1.3: new low-speed USB device number 4 using dwc_otg
[ 4.183993] usb 1-1.3: New USB device found, idVendor=413c, idProduct=2003, bcdDevice= 3.06
[ 4.184072] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.184112] usb 1-1.3: Product: Dell USB Keyboard
[ 4.184146] usb 1-1.3: Manufacturer: Dell
[ 4.201086] input: Dell Dell USB Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:413C:2003.0001/input/input0
[ 4.260324] usb 1-1.1.2: new low-speed USB device number 5 using dwc_otg
[ 4.271180] hid-generic 0003:413C:2003.0001: input,hidraw0: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-3f980000.usb-1.3/input0
[ 4.405430] usb 1-1.1.2: New USB device found, idVendor=046d, idProduct=c404, bcdDevice= 2.20
[ 4.405479] usb 1-1.1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.405500] usb 1-1.1.2: Product: Trackball
[ 4.405516] usb 1-1.1.2: Manufacturer: Logitech
[ 4.424888] input: Logitech Trackball as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:046D:C404.0002/input/input1
[ 4.425490] hid-generic 0003:046D:C404.0002: input,hidraw1: USB HID v1.10 Mouse [Logitech Trackball] on usb-3f980000.usb-1.1.2/input0
[ 4.720330] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
[ 4.850932] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[ 4.850979] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 4.885440] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[ 5.116670] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[ 5.140871] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[ 5.227693] systemd[1]: Queued start job for default target Graphical Interface.
[ 5.230291] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.237783] systemd[1]: Created slice system-getty.slice.
[ 5.238328] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.239726] systemd[1]: Created slice system-modprobe.slice.
[ 5.239921] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.241452] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 5.242529] systemd[1]: Created slice User and Session Slice.
[ 5.243204] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 5.244635] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.245715] systemd[1]: Reached target Slices.
[ 5.246071] systemd[1]: Reached target Swap.
[ 5.247590] systemd[1]: Listening on Syslog Socket.
[ 5.248454] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 5.248971] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 5.250662] systemd[1]: Listening on Journal Audit Socket.
[ 5.251594] systemd[1]: Listening on Journal Socket (/dev/log).
[ 5.252721] systemd[1]: Listening on Journal Socket.
[ 5.264478] systemd[1]: Listening on udev Control Socket.
[ 5.265606] systemd[1]: Listening on udev Kernel Socket.
[ 5.267026] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 5.272808] systemd[1]: Mounting POSIX Message Queue File System...
[ 5.279164] systemd[1]: Mounting RPC Pipe File System...
[ 5.286641] systemd[1]: Mounting Kernel Debug File System...
[ 5.294091] systemd[1]: Mounting Kernel Trace File System...
[ 5.294775] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 5.306922] systemd[1]: Starting Restore / save the current clock...
[ 5.316816] systemd[1]: Starting Set the console keyboard layout...
[ 5.324609] systemd[1]: Starting Create list of static device nodes for the current kernel...
[ 5.333710] systemd[1]: Starting Load Kernel Module configfs...
[ 5.342378] systemd[1]: Starting Load Kernel Module drm...
[ 5.350350] systemd[1]: Starting Load Kernel Module fuse...
[ 5.371358] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 5.378330] systemd[1]: Starting File System Check on Root Device...
[ 5.392750] systemd[1]: Starting Journal Service...
[ 5.413037] systemd[1]: Starting Load Kernel Modules...
[ 5.421802] systemd[1]: Starting Coldplug All udev Devices...
[ 5.443914] systemd[1]: Mounted POSIX Message Queue File System.
[ 5.445215] systemd[1]: Mounted RPC Pipe File System.
[ 5.446147] systemd[1]: Mounted Kernel Debug File System.
[ 5.447051] systemd[1]: Mounted Kernel Trace File System.
[ 5.449771] systemd[1]: Finished Restore / save the current clock.
[ 5.466667] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 5.469504] systemd[1]: [email protected]: Succeeded.
[ 5.471382] systemd[1]: Finished Load Kernel Module configfs.
[ 5.497022] systemd[1]: Mounting Kernel Configuration File System...
[ 5.515232] fuse: init (API version 7.34)
[ 5.525410] systemd[1]: Started File System Check Daemon to report status.
[ 5.530921] systemd[1]: [email protected]: Succeeded.
[ 5.536756] systemd[1]: Finished Load Kernel Module drm.
[ 5.566418] i2c_dev: i2c /dev entries driver
[ 5.576240] systemd[1]: [email protected]: Succeeded.
[ 5.578379] systemd[1]: Finished Load Kernel Module fuse.
[ 5.581763] systemd[1]: Finished Load Kernel Modules.
[ 5.583039] systemd[1]: Mounted Kernel Configuration File System.
[ 5.590660] systemd[1]: Mounting FUSE Control File System...
[ 5.612821] systemd[1]: Starting Apply Kernel Variables...
[ 5.637415] systemd[1]: Mounted FUSE Control File System.
[ 5.747294] systemd[1]: Finished Apply Kernel Variables.
[ 5.798399] systemd[1]: Started Journal Service.
[ 6.000879] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 6.098314] systemd-journald[127]: Received client request to flush runtime journal.
[ 6.115969] systemd-journald[127]: File /var/log/journal/4a2d905062564ed3a1fdfc05a7025f2f/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 7.970150] mc: Linux media interface: v0.10
[ 7.993304] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.996574] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.996622] [vc_sm_connected_init]: start
[ 8.034107] [vc_sm_connected_init]: installed successfully
[ 8.052936] videodev: Linux video capture interface: v2.00
[ 8.107992] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.112254] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.113541] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.115144] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.130360] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.136504] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 8.136788] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 8.137333] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 8.137773] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 8.138198] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 8.138246] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.138284] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.138325] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.138356] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.154217] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 8.154759] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 8.155205] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 8.155583] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 8.155620] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 8.155649] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 8.155673] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 8.155710] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 8.155951] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 8.200769] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.219236] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 8.306777] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 8.306876] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 8.313800] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 8.313877] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 8.320766] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 8.320837] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 8.340409] random: crng init done
[ 8.340449] random: 7 urandom warning(s) missed due to ratelimiting
[ 8.343150] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 8.343237] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 8.368155] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 8.368354] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 8.709566] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.857472] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 8.894052] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 8.964270] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.978230] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.983117] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,3-model-b-plus.bin failed with error -2
[ 8.983836] usbcore: registered new interface driver brcmfmac
[ 9.194268] checking generic (3e402000 7f8000) vs hw (0 ffffffff)
[ 9.194311] fb0: switching to vc4 from simple
[ 9.195205] Console: switching to colour dummy device 80x30
[ 9.218224] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 9.230520] Registered IR keymap rc-cec
[ 9.231030] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 9.234427] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input2
[ 9.295392] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.295550] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 9.366577] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 11.177161] vc4-drm soc:gpu: bound 3f400000.hvs (ops vc4_hvs_ops [vc4])
[ 11.188724] Registered IR keymap rc-cec
[ 11.189147] rc rc0: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0
[ 11.189550] input: vc4 as /devices/platform/soc/3f902000.hdmi/rc/rc0/input3
[ 11.195861] vc4-drm soc:gpu: bound 3f902000.hdmi (ops vc4_hdmi_ops [vc4])
[ 11.196437] vc4-drm soc:gpu: bound 3f004000.txp (ops vc4_txp_ops [vc4])
[ 11.196888] vc4-drm soc:gpu: bound 3f206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.197358] vc4-drm soc:gpu: bound 3f207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.197782] vc4-drm soc:gpu: bound 3f807000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 11.198138] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[ 11.265563] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[ 11.331187] uart-pl011 3f201000.serial: no DMA platform data
[ 11.377142] Console: switching to colour frame buffer device 240x67
[ 11.377219] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[ 11.486889] Adding 102396k swap on /var/swap. Priority:-2 extents:26 across:3393580k SSFS
[ 11.683750] 8021q: 802.1Q VLAN Support v1.8
[ 12.312893] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 12.864862] 8021q: adding VLAN 0 to HW filter on device eth0
[ 18.594652] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.918266] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 19.986299] Bluetooth: Core ver 2.22
[ 19.986476] NET: Registered PF_BLUETOOTH protocol family
[ 19.986489] Bluetooth: HCI device and connection manager initialized
[ 19.988019] Bluetooth: HCI socket layer initialized
[ 19.988049] Bluetooth: L2CAP socket layer initialized
[ 19.988093] Bluetooth: SCO socket layer initialized
[ 20.027761] Bluetooth: HCI UART driver ver 2.3
[ 20.027805] Bluetooth: HCI UART protocol H4 registered
[ 20.027928] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 20.028245] Bluetooth: HCI UART protocol Broadcom registered
[ 20.459834] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 20.459863] Bluetooth: BNEP filters: protocol multicast
[ 20.459884] Bluetooth: BNEP socket layer initialized
[ 20.484863] NET: Registered PF_ALG protocol family
[ 20.546773] cryptd: max_cpu_qlen set to 1000
[ 20.883467] Bluetooth: RFCOMM TTY layer initialized
[ 20.883523] Bluetooth: RFCOMM socket layer initialized
[ 20.883559] Bluetooth: RFCOMM ver 1.11
[ 33.120395] cam-dummy-reg: disabling
I tried following the remainder of the instructions (Driver Installation section) after the instruction to list all cameras, but found the same result: no cameras available -
I need help getting the cameras to be found by libcamera-still
