Thats great news. There are some people discussing this over in raspi forum also: Autofocus in Libcamera (for Arducam 16MP camera) - Raspberry Pi Forums Would really be apreciated.
Okay.
We had a lot of shortcomings before, but we have been improving. User feedback is especially important.
I will update the thread below with any updates.
Yes, those are the tutorials I’ve been following.
I’ve also tried grabbing the latest build:
2023-03-22_2023-02-21-octopi-bullseye-armhf-lite-1.1.0.zip
I’ll give your custom build a shot, but believe I’ve tried in the past.
Hi i got same problem in arducam.
my camera : B0264
my system : raspberry pi 4B 64bit
my os : raspberry pi OS bullseye 6.1.23-v8 kernel
when i do “sudo ./install_pivariety_pkgs.sh -d”
the system show me like below.
I did apt-update and apt-upgrade.
at 6.x ,you dont need use scrpt install camera drive.
just edit the config
sudo vi /boot/config.txt
add dtoverlay=arducam-pivariety in the last line.
then reboot and try again.
By the way, the libcamera stiil need to install
sudo ./install_pivariety_pkgs.sh -p libcamera
sudo ./install_pivariety_pkgs.sh -p libcamera_apps
Thanks for let me know!
but i still cant get any image TT
the error massage shows like below
camera just shows some ‘buzz’ images…
There doesn’t seem to be any authoritative documentation for the 64mp camera installation. I bumped into this by chance after spending an hour googling for information on how to install this camera.
Fresh raspbian bullseye install on a RPI 4B+ 4G (update/upgrade/etc.)
>uname -a
Linux raspberrypi 6.1.21-v8+ #1642 SMP PREEMPT Mon Apr 3 17:24:16 BST 2023 aarch64 GNU/Linux
>cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
>tail /boot/config.txt
[pi4]
arm_boost=1
dtparam=i2c_vc=on
dtparam=i2c_arm=on
When I run sudo ./install_pivariety_pkgs.sh -p libcamera above, this warning comes up:
Get:1 /home/gus/Downloads/libcamera0_0.git20230321+74d023d8-1_arm64.deb libcamera0 arm64 0~git20230321+74d023d8-1 [681 kB]
(Reading database ... 101502 files and directories currently installed.)
Preparing to unpack .../libcamera0_0.git20230321+74d023d8-1_arm64.deb ...
Unpacking libcamera0:arm64 (0~git20230321+74d023d8-1) over (0~git20230321+74d023d8-1) ...
Setting up libcamera0:arm64 (0~git20230321+74d023d8-1) ...
Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u5) ...
W: Repository is broken: libcamera0:arm64 (= 0~git20230321+74d023d8-1) has no Size information
--2023-05-02 18:46:26-- https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/libcamera-v0.0.5/libcamera-dev_0.git20230321+74d023d8-1_arm64.deb
Still no camera:
>libcamera-jpeg --list-cameras
No cameras available!
You can refer to our documentation, we have made some distinctions for the kernel version.
https://docs.arducam.com/Raspberry-Pi-Camera/Native-camera/Quick-Start-Guide/#arducam-pi-hawk-eye-64mp-cameras
For 6.1.19 onwards, you only need to change the configuration file for the camera driver.
Ha! That did it. I had gone through so many iterations I had lost track of what is what. There is simply way too much bad information on the web, which must make your job insane.
I had that at some point in my config file. I think it was added by install_pivariety_pkgs.sh when using -d in one of the zillion times I tried something. It added it to the end of the file (under [all]) but it was commented off. I did uncomment it but it didn’t make any difference. I now realized that the added line was dtoverlay=arducam_64mp (underscore) instead of dtoverlay=arducam-64mp.
I just replaced the _ with an - and it is finally working!
Thank you!
Hey, I need some help cause I’m currently struggling with the “Quick Start Guide for Arducam CamArray HAT Kit”.
I’m trying to use a B0264 and B0331 products on a RPI 4B. However, for both of them, I get a freezed black screen while using the commands libcamera-hello libcamera-still etc.
Here is the process I followed:
- flash the latest stable image from Raspberry Pi Imager on a 32Gb SDcard
- run “update” “upgrade” etc
- add “dtoverlay=arducam-pivariety” to the config file
- install libcamera from the github repository
Some more info about my situation, and demo of the issue…
Thanks !
Can you take a picture of the hardware connection?
@Edward
Of course there you go:
The system wasn’t under voltage while taking the pictures, but the red LED on the PCB turns well on.
I have tested the connections with an ohmmeter and everything looks ok.
By the way, a single camera like the B0392 (with « camera_auto_detect=0 » and « dtoverlay=imx219 ») works fine, so the issue seems to be coming from the array configuration.
May I ask when you purchased the camera? The firmware appears to be outdated.
Hello, I’m trying to install the arducam 64mp camera on my Raspberry Pi Zero. I’m struggling to understand which is the right procedure. This far this I’ve followed this guide:
up to Step 4: Modify Config file.
I tried to modify the file adding “dtoverlay=imx519” at the end, I tried alternatively to add “dtoverlay=arducam-64mp” and “dtoverlay=arducam-pivariety” as @Edward suggested to other users before.
I’m still getting a *** no camera available *** message whenever I try to use the camera with libcamera-hello
Any suggestions?
Hi @Edward,
I didn’t buy the cameras myself, but they were purchased about a year ago. Do you think the firmwares can already be obsolete ?
If that may be the problem, can I update it easily from my desktop ?
(I found the update package you wrote for the IMX298 and IMX230 but what about the others ?)
Ok so I tried to update the firmware of the B0264 with the imx230_lanes2_firmware_armv7l file that you provide in the “What’s new” section.
It worked (Firmware update successful written in green) and it seems like I have the 0x10001 version instead of 0x0003 now. However, I still get a black screen and an error with libcamera-hello:
Thanks, much clearer now. Sorry for the dumb question ![]()
These updates do not apply to your two cameras.
Please burn the correct firmware into it first.
ov2311_firmware.tar.gz (28.0 KB)
