Directly from ArduCam through the Kickstarter campaign “High Resolution Autofocus Camera Module for Raspberry Pi”. -
SKU B0389 -
Raspberry Pi 4B running PiOS 32-bit Buster -
Raspberry Pi libcamera Guide - Arducam -
The Mini 16MP Camera output displays some strange color artifacts as shown on the attached screenshot (the image should be mostly gray without those artifacts), and the terminal shows multiple error messages: “ERROR IPARPI cam_helper.cpp:180 Embedded data buffer parsing failed”.
[ 0.000000] Linux version 5.10.103-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:24:00 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.2
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000002fffffff]
[ 0.000000] Normal empty
[ 0.000000] HighMem [mem 0x0000000030000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000037ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000fbffffff]
[ 0.000000] On node 0 totalpages: 999424
[ 0.000000] DMA zone: 1728 pages used for memmap
[ 0.000000] DMA zone: 196608 pages, LIFO batch:63
[ 0.000000] HighMem zone: 802816 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 997696
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:3840x2160M@30,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 smsc95xx.macaddr=DC:A6:32:EC:49:A8 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=29c8cd4e-02 rootfstype=ext4 fsck.repair=yes rootwait
[ 0.000000] software IO TLB: mapped [mem 0x0000000014890000-0x0000000018890000] (64MB)
[ 0.000000] Memory: 3548356K/3997696K available (10240K kernel code, 1366K rwdata, 3196K rodata, 2048K init, 882K bss, 121660K reserved, 327680K cma-reserved, 3211264K highmem)
[ 0.000000] ftrace: allocating 34355 entries in 101 pages
[ 0.000000] ftrace: allocated 101 pages with 4 groups
[ 0.000000] random: get_random_bytes called from start_kernel+0x3c8/0x59c with crng_init=1
[ 0.000008] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483647500ns
[ 0.000035] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 0.000097] bcm2835: system timer (irq = 25)
[ 0.000769] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000791] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000813] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000830] Switching to timer-based delay loop, resolution 18ns
[ 0.001088] Console: colour dummy device 80x30
[ 0.001827] printk: console [tty1] enabled
[ 0.001894] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=540000)
[ 0.001949] pid_max: default: 32768 minimum: 301
[ 0.002129] LSM: Security Framework initializing
[ 0.002327] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002373] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.003868] cgroup: Disabling memory control group subsystem
[ 0.004116] CPU: Testing write buffer coherency: ok
[ 0.004594] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.005810] Setting up static identity map for 0x200000 - 0x20003c
[ 0.006025] rcu: Hierarchical SRCU implementation.
[ 0.006968] smp: Bringing up secondary CPUs …
[ 0.008182] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.009536] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.010854] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.011013] smp: Brought up 1 node, 4 CPUs
[ 0.011060] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[ 0.011089] CPU: All CPU(s) started in HYP mode.
[ 0.011116] CPU: Virtualization extensions available.
[ 0.011965] devtmpfs: initialized
[ 0.026412] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[ 0.026671] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.026724] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.034985] pinctrl core: initialized pinctrl subsystem
[ 0.036079] NET: Registered protocol family 16
[ 0.039885] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.040671] audit: initializing netlink subsys (disabled)
[ 0.040990] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.041558] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.042262] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.042316] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.042745] Serial: AMBA PL011 UART driver
[ 0.079804] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.090919] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:02:46, variant start_x
[ 0.100934] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[ 0.141923] Kprobes globally optimized
[ 0.147434] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.152807] vgaarb: loaded
[ 0.153280] SCSI subsystem initialized
[ 0.153522] usbcore: registered new interface driver usbfs
[ 0.153600] usbcore: registered new interface driver hub
[ 0.153701] usbcore: registered new device driver usb
[ 0.154108] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.156027] clocksource: Switched to clocksource arch_sys_counter
[ 1.101707] VFS: Disk quotas dquot_6.6.0
[ 1.101823] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.102002] FS-Cache: Loaded
[ 1.102236] CacheFiles: Loaded
[ 1.103349] simple-framebuffer 3e267000.framebuffer: framebuffer at 0x3e267000, 0x960000 bytes, mapped to 0x(ptrval)
[ 1.103394] simple-framebuffer 3e267000.framebuffer: format=a8r8g8b8, mode=1920x1280x32, linelength=7680
[ 1.115790] Console: switching to colour frame buffer device 240x80
[ 1.127437] simple-framebuffer 3e267000.framebuffer: fb0: simplefb registered!
[ 1.136437] NET: Registered protocol family 2
[ 1.136732] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.138143] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.138361] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.138502] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.138638] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.138856] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.138959] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.139249] NET: Registered protocol family 1
[ 1.140447] RPC: Registered named UNIX socket transport module.
[ 1.140527] RPC: Registered udp transport module.
[ 1.140591] RPC: Registered tcp transport module.
[ 1.140654] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.140740] PCI: CLS 0 bytes, default 64
[ 1.143823] Initialise system trusted keyrings
[ 1.144129] workingset: timestamp_bits=14 max_order=20 bucket_order=6
[ 1.152506] zbud: loaded
[ 1.154355] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.155171] NFS: Registering the id_resolver key type
[ 1.155271] Key type id_resolver registered
[ 1.155331] Key type id_legacy registered
[ 1.155498] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.155580] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.156705] Key type asymmetric registered
[ 1.156770] Asymmetric key parser ‘x509’ registered
[ 1.157011] bounce: pool size: 64 pages
[ 1.157098] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.157401] io scheduler mq-deadline registered
[ 1.157467] io scheduler kyber registered
[ 1.162074] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.162180] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.162345] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.162510] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x00bfffffff → 0x0400000000
[ 1.218132] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.218574] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.218660] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.218738] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.218921] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.219224] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.222922] PCI: bus0: Fast back to back transfers disabled
[ 1.223349] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.223539] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.224039] pci 0000:01:00.0: PME# supported from D0 D3cold
[ 1.227741] PCI: bus1: Fast back to back transfers disabled
[ 1.231103] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.234381] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.237709] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.240931] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.244535] pcieport 0000:00:00.0: enabling device (0140 → 0142)
[ 1.248079] pcieport 0000:00:00.0: PME: Signaling with IRQ 65
[ 1.260587] iproc-rng200 fe104000.rng: hwrng registered
[ 1.264115] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.268276] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.283486] brd: module loaded
[ 1.298870] loop: module loaded
[ 1.303936] Loading iSCSI transport class v2.0-870.
[ 1.312194] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.416214] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.420642] usbcore: registered new interface driver r8152
[ 1.423874] usbcore: registered new interface driver lan78xx
[ 1.427133] usbcore: registered new interface driver smsc95xx
[ 1.431873] xhci_hcd 0000:01:00.0: enabling device (0140 → 0142)
[ 1.435195] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.438433] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.444852] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.449321] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.452504] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.455665] usb usb1: Product: xHCI Host Controller
[ 1.458854] usb usb1: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.462018] usb usb1: SerialNumber: 0000:01:00.0
[ 1.465898] hub 1-0:1.0: USB hub found
[ 1.469127] hub 1-0:1.0: 1 port detected
[ 1.472874] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.475953] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.479059] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.482584] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.485653] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.488719] usb usb2: Product: xHCI Host Controller
[ 1.491730] usb usb2: Manufacturer: Linux 5.10.103-v7l+ xhci-hcd
[ 1.494731] usb usb2: SerialNumber: 0000:01:00.0
[ 1.498578] hub 2-0:1.0: USB hub found
[ 1.501606] hub 2-0:1.0: 4 ports detected
[ 1.506371] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.509677] dwc_otg: FIQ enabled
[ 1.509692] dwc_otg: NAK holdoff enabled
[ 1.509707] dwc_otg: FIQ split-transaction FSM enabled
[ 1.509725] Module dwc_common_port init
[ 1.510180] usbcore: registered new interface driver uas
[ 1.513230] usbcore: registered new interface driver usb-storage
[ 1.516389] mousedev: PS/2 mouse device common for all mice
[ 1.521162] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.527613] sdhci: Secure Digital Host Controller Interface driver
[ 1.530606] sdhci: Copyright(c) Pierre Ossman
[ 1.534333] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.538071] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.545236] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.548656] hid: raw HID events driver (C) Jiri Kosina
[ 1.551829] usbcore: registered new interface driver usbhid
[ 1.554897] usbhid: USB HID core driver
[ 1.563700] Initializing XFRM netlink socket
[ 1.566822] NET: Registered protocol family 17
[ 1.570067] Key type dns_resolver registered
[ 1.573370] Registering SWP/SWPB emulation handler
[ 1.576530] registered taskstats version 1
[ 1.579500] Loading compiled-in X.509 certificates
[ 1.583290] Key type ._fscrypt registered
[ 1.586248] Key type .fscrypt registered
[ 1.589164] Key type fscrypt-provisioning registered
[ 1.603567] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.606906] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.609894] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 36, base_baud = 0) is a PL011 rev2
[ 1.622113] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.626215] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.629222] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.660914] of_cfs_init
[ 1.664154] of_cfs_init: OK
[ 1.681606] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.686275] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.690864] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.696100] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.699604] Waiting for root device PARTUUID=29c8cd4e-02…
[ 1.700583] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.707116] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.742720] mmc0: Problem switching card into high-speed mode!
[ 1.745838] mmc0: new SDHC card at address 0001
[ 1.749630] mmcblk0: mmc0:0001 00000 7.37 GiB
[ 1.755742] mmcblk0: p1 p2
[ 1.766096] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.793263] mmc1: new high speed SDIO card at address 0001
[ 1.805225] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.808234] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.812917] devtmpfs: mounted
[ 1.825913] Freeing unused kernel memory: 2048K
[ 1.866369] Run /sbin/init as init process
[ 1.869241] with arguments:
[ 1.869256] /sbin/init
[ 1.869270] with environment:
[ 1.869284] HOME=/
[ 1.869298] TERM=linux
[ 1.948736] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.951754] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.954658] usb 1-1: Product: USB2.0 Hub
[ 1.959835] hub 1-1:1.0: USB hub found
[ 1.962992] hub 1-1:1.0: 4 ports detected
[ 3.037753] systemd[1]: System time before build time, advancing clock.
[ 3.276659] NET: Registered protocol family 10
[ 3.281043] Segment Routing with IPv6
[ 3.413966] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 3.421252] systemd[1]: Detected architecture arm.
[ 3.548395] systemd[1]: Set hostname to .
[ 4.429903] systemd[1]: /lib/systemd/system/smbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/smbd.pid → /run/samba/smbd.pid; please update the unit file accordingly.
[ 4.502118] systemd[1]: /lib/systemd/system/nmbd.service:9: PIDFile= references path below legacy directory /var/run/, updating /var/run/samba/nmbd.pid → /run/samba/nmbd.pid; please update the unit file accordingly.
[ 4.692127] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.709108] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.713515] systemd[1]: Listening on Journal Socket.
[ 4.722375] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.733332] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 4.742789] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 4.753064] systemd[1]: Mounting POSIX Message Queue File System…
[ 4.761929] systemd[1]: Reached target Swap.
[ 5.123968] i2c /dev entries driver
[ 5.818363] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 5.916235] systemd-journald[135]: Received request to flush runtime journal from PID 1
[ 6.901255] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 6.901836] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 6.902434] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 6.902948] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 7.095304] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.098020] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 7.098046] [vc_sm_connected_init]: start
[ 7.112315] [vc_sm_connected_init]: installed successfully
[ 7.130179] i2c i2c-22: Added multiplexed i2c bus 0
[ 7.133224] i2c i2c-22: Added multiplexed i2c bus 10
[ 7.187156] mc: Linux media interface: v0.10
[ 7.367169] videodev: Linux video capture interface: v2.00
[ 7.374562] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.425152] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 7.493089] bcm2835_audio bcm2835_audio: card created with 4 channels
[ 7.544186] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 7.552277] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.554575] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.630102] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.689181] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.712614] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 7.712662] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 7.735931] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 7.742525] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 7.742575] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 7.758268] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 7.761015] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 7.761477] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 7.762059] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 7.762116] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 7.762403] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 7.762430] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 7.762455] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 7.762478] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 7.762500] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 7.762737] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.806849] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 7.806912] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 7.950089] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 8.003548] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 8.004371] checking generic (3e267000 960000) vs hw (0 ffffffffffffffff)
[ 8.004399] fb0: switching to vc4drmfb from simple
[ 8.005129] Console: switching to colour dummy device 80x30
[ 8.007834] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 8.008857] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 8.201779] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 8.221612] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.223129] usbcore: registered new interface driver brcmfmac
[ 8.286849] Console: switching to colour frame buffer device 480x135
[ 8.359904] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 8.561964] imx519: loading out-of-tree module taints kernel.
[ 8.577364] imx519 10-001a: Device found is imx519
[ 8.637306] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.637457] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.651874] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 10.758024] random: crng init done
[ 10.758046] random: 7 urandom warning(s) missed due to ratelimiting
[ 10.996582] uart-pl011 fe201000.serial: no DMA platform data
[ 11.880965] 8021q: 802.1Q VLAN Support v1.8
[ 13.047173] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 13.089610] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 14.013061] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 14.013482] bcmgenet fd580000.ethernet eth0: Link is Down
[ 17.929407] Bluetooth: Core ver 2.22
[ 17.929469] NET: Registered protocol family 31
[ 17.929476] Bluetooth: HCI device and connection manager initialized
[ 17.929492] Bluetooth: HCI socket layer initialized
[ 17.929502] Bluetooth: L2CAP socket layer initialized
[ 17.929518] Bluetooth: SCO socket layer initialized
[ 18.016703] Bluetooth: HCI UART driver ver 2.3
[ 18.016714] Bluetooth: HCI UART protocol H4 registered
[ 18.016765] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 18.016916] Bluetooth: HCI UART protocol Broadcom registered
[ 18.714721] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.714736] Bluetooth: BNEP filters: protocol multicast
[ 18.714758] Bluetooth: BNEP socket layer initialized
[ 19.059895] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 19.985515] broken atomic modeset userspace detected, disabling atomic
[ 20.669841] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[ 25.240337] fuse: init (API version 7.32)
[ 29.716605] Bluetooth: RFCOMM TTY layer initialized
[ 29.716624] Bluetooth: RFCOMM socket layer initialized
[ 29.716647] Bluetooth: RFCOMM ver 1.11
[ 31.836085] imx519_vddl: disabling
[ 31.836102] imx519_vdig: disabling
[ 31.836120] imx519_vana: disabling -
None. I also got the autofocus and NOIR versions and they work fine without those artifacts or error messages. -
This Mini 16MP camera is unusable. Is there a software fix or is it defective hardware?
Check this:
What about Raspian Buster when installing the driver following instructions from: 16MP Autofocus & Raspbian Buster --> **no camera available** , is there also an “imx519_kernel_driver_low_speed” option in that case?
The latest version of Buster is no longer supported, we recommend using bullseye.
The Mini camera works fine when using PiOS BullEye and the imx519_kernel_driver_low_speed driver. Thank you.
Glad to hear it works!
