16MP Autofocus & Raspbian Buster --> **no camera available**
Hello everyone,
I have two new 16MP Autofocus modules, that I would like to get running for my magic mirror project as selfie cameras. Here is a description of my issue:
Kickstarter
Model number of the product(s).
2x modules of Arducam 16Mp Autofocus
Raspberry Pi 3B+ with Raspbian Buster (Legacy OS version from January 28th 2022, Kernel 5.10
Problems you were having.
When I try to test my autofocus camera via “libcamera-still -t 0”, I receive:
[0:00:55.171930811] [972] INFO Camera camera_manager.cpp:293 libcamera v0.0.0
ERROR: ***no cameras available ***
The dmesg log from your hardware.
Not available.
Troubleshooting attempts you’ve made.
  • Hardware: I have tried 2 autofocus cameras, to check, if one of them is damaged. I tried different cables. I tested the original raspi camera v2.1, which worked.
  • OS: I tested the autofocus cameras with Raspbian Bullseye and they worked. Unfortunately, I cannot switch to Bullseye because of my other application that I want to keep using.
  • Re-installation: I followed the libcamera guide and did 3 re-installations.
Is there a way, that I can get the 16MP autofocus cameras working under Raspbian Buster? That would be great, as this was my main intention when I bought them.
Best regards, Hendrik
Can you provide some information?
I need them to diagnose the problem.
Dear wong,
thank you for looking into it!
Here are the requested information:
1. System information
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
pi@raspberrypi:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
NAME="Raspbian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
pi@raspberrypi:~ $ cat /proc/meminfo
MemTotal:         892200 kB
MemFree:           55464 kB
MemAvailable:     318612 kB
Buffers:           27136 kB
Cached:           296976 kB
SwapCached:           96 kB
Active:           191260 kB
Inactive:         438596 kB
Active(anon):       1300 kB
Inactive(anon):   330540 kB
Active(file):     189960 kB
Inactive(file):   108056 kB
Unevictable:          80 kB
Mlocked:              80 kB
SwapTotal:        102396 kB
SwapFree:          95740 kB
Dirty:              1460 kB
Writeback:             0 kB
AnonPages:        305748 kB
Mapped:           206416 kB
Shmem:             26096 kB
KReclaimable:      20376 kB
Slab:              40372 kB
SReclaimable:      20376 kB
SUnreclaim:        19996 kB
KernelStack:        2408 kB
PageTables:         9052 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      548496 kB
Committed_AS:    1870832 kB
VmallocTotal:    1163264 kB
VmallocUsed:        5456 kB
VmallocChunk:          0 kB
Percpu:              528 kB
CmaTotal:         262144 kB
CmaFree:           26292 kB
pi@raspberrypi:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
[pi4]
# Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
start_x=1
gpu_mem=128
dtoverlay=imx519
2. System log
pi@raspberrypi:~ $ dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.10.103-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1529 SMP Tue Mar 8 12:21:37 GMT 2022
[    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[    0.000000] random: fast init done
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] Reserved memory: created CMA memory pool at 0x1ec00000, size 256 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000] On node 0 totalpages: 229376
[    0.000000]   DMA zone: 2016 pages used for memmap
[    0.000000]   DMA zone: 0 pages reserved
[    0.000000]   DMA zone: 229376 pages, LIFO batch:63
[    0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[    0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 227360
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=f556eb55-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 629032K/917504K available (10240K kernel code, 1312K rwdata, 2952K rodata, 1024K init, 862K bss, 26328K reserved, 262144K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 32081 entries in 95 pages
[    0.000000] ftrace: allocated 94 pages with 5 groups
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[    0.000021] Switching to timer-based delay loop, resolution 52ns
[    0.000321] Console: colour dummy device 80x30
[    0.000394] printk: console [tty1] enabled
[    0.000451] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[    0.000479] pid_max: default: 32768 minimum: 301
[    0.000687] LSM: Security Framework initializing
[    0.000945] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000970] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002503] cgroup: Disabling memory control group subsystem
[    0.002791] CPU: Testing write buffer coherency: ok
[    0.003327] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004620] Setting up static identity map for 0x100000 - 0x10003c
[    0.004814] rcu: Hierarchical SRCU implementation.
[    0.005749] smp: Bringing up secondary CPUs ...
[    0.006986] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008333] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.009593] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.009755] smp: Brought up 1 node, 4 CPUs
[    0.009779] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[    0.009791] CPU: All CPU(s) started in HYP mode.
[    0.009802] CPU: Virtualization extensions available.
[    0.010976] devtmpfs: initialized
[    0.029198] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[    0.029467] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.029500] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.040556] pinctrl core: initialized pinctrl subsystem
[    0.041832] NET: Registered protocol family 16
[    0.046349] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.052211] audit: initializing netlink subsys (disabled)
[    0.053142] thermal_sys: Registered thermal governor 'step_wise'
[    0.054124] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[    0.054306] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.054322] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.054636] Serial: AMBA PL011 UART driver
[    0.074975] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[    0.090164] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-12-01T15:08:00, variant start_x
[    0.100176] raspberrypi-firmware soc:firmware: Firmware hash is 71bd3109023a0c8575585ba87cbb374d2eeb038f
[    0.145001] Kprobes globally optimized
[    0.150476] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[    0.152736] SCSI subsystem initialized
[    0.153009] usbcore: registered new interface driver usbfs
[    0.153074] usbcore: registered new interface driver hub
[    0.153148] usbcore: registered new device driver usb
[    0.155310] clocksource: Switched to clocksource arch_sys_counter
[    1.875603] VFS: Disk quotas dquot_6.6.0
[    1.875731] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    1.875944] FS-Cache: Loaded
[    1.876205] CacheFiles: Loaded
[    1.877226] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes, mapped to 0x(ptrval)
[    1.877247] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    1.877854] Console: switching to colour frame buffer device 240x67
[    1.912828] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[    1.922640] NET: Registered protocol family 2
[    1.922950] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.924958] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    1.925025] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    1.925154] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    1.925413] TCP: Hash tables configured (established 8192 bind 8192)
[    1.925623] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.925684] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    1.925974] NET: Registered protocol family 1
[    1.926790] RPC: Registered named UNIX socket transport module.
[    1.926804] RPC: Registered udp transport module.
[    1.926816] RPC: Registered tcp transport module.
[    1.926828] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.928729] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.932630] Initialise system trusted keyrings
[    1.932915] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    1.942590] zbud: loaded
[    1.944785] FS-Cache: Netfs 'nfs' registered for caching
[    1.945826] NFS: Registering the id_resolver key type
[    1.945891] Key type id_resolver registered
[    1.945904] Key type id_legacy registered
[    1.946082] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.946096] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.947302] Key type asymmetric registered
[    1.947318] Asymmetric key parser 'x509' registered
[    1.947375] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[    1.947391] io scheduler mq-deadline registered
[    1.947405] io scheduler kyber registered
[    1.956844] bcm2835-rng 3f104000.rng: hwrng registered
[    1.957337] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.958188] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[    1.970448] brd: module loaded
[    1.982900] loop: module loaded
[    1.984785] Loading iSCSI transport class v2.0-870.
[    1.986779] usbcore: registered new interface driver lan78xx
[    1.986848] usbcore: registered new interface driver smsc95xx
[    1.986874] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    2.715094] Core Release: 2.80a
[    2.715110] Setting default values for core params
[    2.715144] Finished setting default values for core params
[    2.915594] Using Buffer DMA mode
[    2.915608] Periodic Transfer Interrupt Enhancement - disabled
[    2.915620] Multiprocessor Interrupt Enhancement - disabled
[    2.915634] OTG VER PARAM: 0, OTG VER FLAG: 0
[    2.915650] Dedicated Tx FIFOs mode
[    2.916699] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 9ed04000 dma = 0xded04000 len=9024
[    2.916733] FIQ FSM acceleration enabled for :
               Non-periodic Split Transactions
               Periodic Split Transactions
               High-Speed Isochronous Endpoints
               Interrupt/Control Split Transaction hack enabled
[    2.916747] dwc_otg: Microframe scheduler enabled
[    2.916820] WARN::hcd_init_fiq:457: FIQ on core 1
[    2.916836] WARN::hcd_init_fiq:458: FIQ ASM at 807cb8b8 length 36
[    2.916853] WARN::hcd_init_fiq:497: MPHI regs_base at b8810000
[    2.916877] dwc_otg 3f980000.usb: DWC OTG Controller
[    2.916918] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[    2.916969] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[    2.917025] Init: Port Power? op_state=1
[    2.917037] Init: Power Port (0)
[    2.917405] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[    2.917422] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    2.917437] usb usb1: Product: DWC OTG Controller
[    2.917452] usb usb1: Manufacturer: Linux 5.10.103-v7+ dwc_otg_hcd
[    2.917466] usb usb1: SerialNumber: 3f980000.usb
[    2.918291] hub 1-0:1.0: USB hub found
[    2.918362] hub 1-0:1.0: 1 port detected
[    2.919689] dwc_otg: FIQ enabled
[    2.919702] dwc_otg: NAK holdoff enabled
[    2.919713] dwc_otg: FIQ split-transaction FSM enabled
[    2.919732] Module dwc_common_port init
[    2.920082] usbcore: registered new interface driver usb-storage
[    2.920301] mousedev: PS/2 mouse device common for all mice
[    2.921533] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    2.924329] sdhci: Secure Digital Host Controller Interface driver
[    2.924342] sdhci: Copyright(c) Pierre Ossman
[    2.925010] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[    2.925881] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[    2.926123] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.928057] ledtrig-cpu: registered to indicate activity on CPUs
[    2.928478] hid: raw HID events driver (C) Jiri Kosina
[    2.928645] usbcore: registered new interface driver usbhid
[    2.928658] usbhid: USB HID core driver
[    2.934079] Initializing XFRM netlink socket
[    2.934127] NET: Registered protocol family 17
[    2.934294] Key type dns_resolver registered
[    2.935031] Registering SWP/SWPB emulation handler
[    2.935205] registered taskstats version 1
[    2.935238] Loading compiled-in X.509 certificates
[    2.936405] Key type ._fscrypt registered
[    2.936421] Key type .fscrypt registered
[    2.936434] Key type fscrypt-provisioning registered
[    2.948319] uart-pl011 3f201000.serial: cts_event_workaround enabled
[    2.948432] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[    2.950860] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    2.952612] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    2.952629] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[    2.979423] sdhost: log_buf @ (ptrval) (ded03000)
[    3.017941] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[    3.019622] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.021302] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[    3.024308] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[    3.029340] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[    3.032451] of_cfs_init
[    3.032759] of_cfs_init: OK
[    3.033974] Waiting for root device PARTUUID=f556eb55-02...
[    3.050406] Indeed it is in host mode hprt0 = 00021501
[    3.146349] mmc0: host does not support reading read-only switch, assuming write-enable
[    3.148206] mmc0: Problem switching card into high-speed mode!
[    3.149767] mmc0: new SDHC card at address 0001
[    3.150760] mmcblk0: mmc0:0001 SD32G 28.9 GiB
[    3.153641]  mmcblk0: p1 p2
[    3.174802] mmc1: new high speed SDIO card at address 0001
[    3.196059] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    3.196168] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    3.197424] devtmpfs: mounted
[    3.205792] Freeing unused kernel memory: 1024K
[    3.235888] Run /sbin/init as init process
[    3.235900]   with arguments:
[    3.235911]     /sbin/init
[    3.235923]     splash
[    3.235934]   with environment:
[    3.235945]     HOME=/
[    3.235955]     TERM=linux
[    3.255360] usb 1-1: new high-speed USB device number 2 using dwc_otg
[    3.255531] Indeed it is in host mode hprt0 = 00001101
[    3.495736] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.495763] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.496694] hub 1-1:1.0: USB hub found
[    3.496823] hub 1-1:1.0: 4 ports detected
[    3.815368] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    3.945778] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    3.945806] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    3.946706] hub 1-1.1:1.0: USB hub found
[    3.946853] hub 1-1.1:1.0: 3 ports detected
[    4.235823] systemd[1]: System time before build time, advancing clock.
[    4.285400] usb 1-1.1.3: new high-speed USB device number 4 using dwc_otg
[    4.435985] usb 1-1.1.3: New USB device found, idVendor=214b, idProduct=7250, bcdDevice= 1.00
[    4.436014] usb 1-1.1.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.436029] usb 1-1.1.3: Product: USB2.0 HUB
[    4.436866] hub 1-1.1.3:1.0: USB hub found
[    4.436989] hub 1-1.1.3:1.0: 4 ports detected
[    4.479054] NET: Registered protocol family 10
[    4.480627] Segment Routing with IPv6
[    4.538494] usb 1-1.3: new high-speed USB device number 5 using dwc_otg
[    4.605033] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[    4.606420] systemd[1]: Detected architecture arm.
[    4.648400] systemd[1]: Set hostname to <raspberrypi>.
[    4.666727] usb 1-1.3: New USB device found, idVendor=0781, idProduct=5591, bcdDevice= 1.00
[    4.666755] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    4.666770] usb 1-1.3: Product: Ultra USB 3.0
[    4.666785] usb 1-1.3: Manufacturer: SanDisk
[    4.666799] usb 1-1.3: SerialNumber: 4C530001190909102263
[    4.667852] usb-storage 1-1.3:1.0: USB Mass Storage device detected
[    4.669208] scsi host0: usb-storage 1-1.3:1.0
[    4.765653] usb 1-1.1.1: new high-speed USB device number 6 using dwc_otg
[    4.896266] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[    4.896295] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.995623] usb 1-1.1.3.1: new high-speed USB device number 7 using dwc_otg
[    5.131362] usb 1-1.1.3.1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    5.131391] usb 1-1.1.3.1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    5.131407] usb 1-1.1.3.1: Product: USB2.0 Hub
[    5.133370] hub 1-1.1.3.1:1.0: USB hub found
[    5.134592] hub 1-1.1.3.1:1.0: 4 ports detected
[    5.161112] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[    5.185462] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[    5.245396] usb 1-1.1.3.3: new full-speed USB device number 8 using dwc_otg
[    5.392656] usb 1-1.1.3.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.09
[    5.392683] usb 1-1.1.3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.392700] usb 1-1.1.3.3: Product: USB Receiver
[    5.392715] usb 1-1.1.3.3: Manufacturer: Logitech
[    5.403772] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.0/0003:046D:C52B.0001/input/input0
[    5.466478] hid-generic 0003:046D:C52B.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-3f980000.usb-1.1.3.3/input0
[    5.475400] usb 1-1.1.3.1.1: new low-speed USB device number 9 using dwc_otg
[    5.479781] input: Logitech USB Receiver Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:046D:C52B.0002/input/input1
[    5.480487] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:046D:C52B.0002/input/input2
[    5.545881] input: Logitech USB Receiver System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.1/0003:046D:C52B.0002/input/input3
[    5.546476] hid-generic 0003:046D:C52B.0002: input,hiddev96,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.1.3.3/input1
[    5.557571] hid-generic 0003:046D:C52B.0003: hiddev97,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.1.3.3/input2
[    5.676504] scsi 0:0:0:0: Direct-Access     SanDisk  Ultra USB 3.0    1.00 PQ: 0 ANSI: 6
[    5.678451] sd 0:0:0:0: [sda] 30031872 512-byte logical blocks: (15.4 GB/14.3 GiB)
[    5.679528] sd 0:0:0:0: [sda] Write Protect is off
[    5.679552] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
[    5.680015] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    5.703145] random: systemd: uninitialized urandom read (16 bytes read)
[    5.719427] random: systemd: uninitialized urandom read (16 bytes read)
[    5.723431] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    5.723839] random: systemd: uninitialized urandom read (16 bytes read)
[    5.724538] systemd[1]: Listening on udev Kernel Socket.
[    5.725994] systemd[1]: Listening on Journal Audit Socket.
[    5.727620] systemd[1]: Created slice system-getty.slice.
[    5.728463] systemd[1]: Listening on Journal Socket (/dev/log).
[    5.729355] systemd[1]: Listening on Journal Socket.
[    5.735778] systemd[1]: Mounting Kernel Debug File System...
[    5.746527]  sda: sda1
[    5.751430] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    5.767356] usb 1-1.1.3.1.1: New USB device found, idVendor=04d9, idProduct=0006, bcdDevice= 1.10
[    5.767401] usb 1-1.1.3.1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.767429] usb 1-1.1.3.1.1: Product: RPI Wired Keyboard 5
[    5.767446] usb 1-1.1.3.1.1: Manufacturer:
[    5.837955] input:   RPI Wired Keyboard 5 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.1/1-1.1.3.1.1/1-1.1.3.1.1:1.0/0003:04D9:0006.0004/input/input5
[    5.857725] i2c /dev entries driver
[    5.906651] hid-generic 0003:04D9:0006.0004: input,hidraw3: USB HID v1.11 Keyboard [  RPI Wired Keyboard 5] on usb-3f980000.usb-1.1.3.1.1/input0
[    5.962093] input:   RPI Wired Keyboard 5 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.1/1-1.1.3.1.1/1-1.1.3.1.1:1.1/0003:04D9:0006.0005/input/input6
[    6.026658] hid-generic 0003:04D9:0006.0005: input,hidraw4: USB HID v1.11 Device [  RPI Wired Keyboard 5] on usb-3f980000.usb-1.1.3.1.1/input1
[    6.709245] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    6.834964] systemd-journald[123]: Received request to flush runtime journal from PID 1
[    7.288442] random: crng init done
[    7.288464] random: 7 urandom warning(s) missed due to ratelimiting
[    7.622553] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    8.636752] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    8.640611] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    8.640644] [vc_sm_connected_init]: start
[    8.652059] [vc_sm_connected_init]: installed successfully
[    8.690045] mc: Linux media interface: v0.10
[    8.750851] videodev: Linux video capture interface: v2.00
[    8.801293] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    8.840351] bcm2835_audio bcm2835_audio: card created with 4 channels
[    8.843830] bcm2835_audio bcm2835_audio: card created with 4 channels
[    8.863975] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    8.863984] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    8.865792] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    8.881502] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    8.906641] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    8.921532] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    9.131549] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    9.277900] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    9.331798] usbcore: registered new interface driver uas
[    9.445547] brcmfmac: F1 signature read @0x18000000=0x15264345
[    9.460852] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.463332] usbcore: registered new interface driver brcmfmac
[    9.537357] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    9.537476] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    9.537552] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    9.538463] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    9.539257] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    9.539816] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    9.539894] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    9.539922] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    9.539945] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    9.539992] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    9.540253] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    9.565350] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    9.565479] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    9.573236] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    9.573297] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    9.588775] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    9.588833] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    9.810427] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.810608] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    9.883569] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[   10.267656] logitech-djreceiver 0003:046D:C52B.0003: hiddev96,hidraw0: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.1.3.3/input2
[   10.412813] input: Logitech Wireless Device PID:4057 Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.2/0003:046D:C52B.0003/0003:046D:4057.0006/input/input7
[   10.413841] hid-generic 0003:046D:4057.0006: input,hidraw1: USB HID v1.11 Mouse [Logitech Wireless Device PID:4057] on usb-3f980000.usb-1.1.3.3/input2:1
[   10.654954] checking generic (3e402000 7f8000) vs hw (0 ffffffff)
[   10.654980] fb0: switching to vc4drmfb from simple
[   10.656656] Console: switching to colour dummy device 80x30
[   10.658360] vc4-drm soc:gpu: bound 3f600000.firmwarekms (ops vc4_fkms_ops [vc4])
[   10.658646] vc4-drm soc:gpu: bound 3fc00000.v3d (ops vc4_v3d_ops [vc4])
[   10.660267] [drm] Initialized vc4 0.0.0 20140616 for soc:gpu on minor 0
[   10.742253] Console: switching to colour frame buffer device 240x67
[   10.742323] vc4-drm soc:gpu: [drm] fb0: vc4drmfb frame buffer device
[   11.008375] input: Logitech B330/M330/M331 as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.3/1-1.1.3.3/1-1.1.3.3:1.2/0003:046D:C52B.0003/0003:046D:4057.0006/input/input11
[   11.009039] logitech-hidpp-device 0003:046D:4057.0006: input,hidraw1: USB HID v1.11 Mouse [Logitech B330/M330/M331] on usb-3f980000.usb-1.1.3.3/input2:1
[   13.588448] uart-pl011 3f201000.serial: no DMA platform data
[   13.718980] 8021q: 802.1Q VLAN Support v1.8
[   14.646092] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[   14.680316] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   15.394955] 8021q: adding VLAN 0 to HW filter on device eth0
[   18.674183] broken atomic modeset userspace detected, disabling atomic
[   20.434315] Bluetooth: Core ver 2.22
[   20.434452] NET: Registered protocol family 31
[   20.434463] Bluetooth: HCI device and connection manager initialized
[   20.434494] Bluetooth: HCI socket layer initialized
[   20.434512] Bluetooth: L2CAP socket layer initialized
[   20.434541] Bluetooth: SCO socket layer initialized
[   20.449298] Bluetooth: HCI UART driver ver 2.3
[   20.449322] Bluetooth: HCI UART protocol H4 registered
[   20.449440] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   20.449695] Bluetooth: HCI UART protocol Broadcom registered
[   20.560421] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   21.121949] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   21.121965] Bluetooth: BNEP filters: protocol multicast
[   21.121989] Bluetooth: BNEP socket layer initialized
[   22.705236] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[   23.940836] fuse: init (API version 7.32)
[   26.693175] Bluetooth: RFCOMM TTY layer initialized
[   26.693220] Bluetooth: RFCOMM socket layer initialized
[   26.693265] Bluetooth: RFCOMM ver 1.11
[   98.688109] logitech-hidpp-device 0003:046D:4057.0006: HID++ 4.5 device connected.
3. Model number
  • See above
  • As I found the camera working under bullseye, it is not about the cable connection of the camera (see above).
4. Application log
  • See the blockquote above
Thank you, wong!
Thank you very much for your information,
We will do some testing.
I think I found the problem, buster uses a different linux source tree than bullseye,
You can try to install manually:
imx519_kernel_driver.tar.gz (55.1 KB)
tar xzvf imx519_kernel_driver.tar.gz
cd Release
./install_driver.sh
Hey wong,
thank you very much! This has fixed the problem and I can now using the camera with Raspbian Buster.
