Errors and warnings with libcamera and 64MP Hawkeye
    Arducam pre-order
    New 64mp Hawkeye (arducam_64mp)
    Raspberry Pi 4 Model B Rev 1.2
    4Gb RAM
    Debian Bullseye 64-bit
    arducam_64mp_pi_camera_manual.pdf
    (downloaded from Arducam website)
  5. Problems you were having?
    These errors occur each time a libcamera command is issued:
    [0:37:04.875486311] [3315] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
    [0:37:04.928394494] [3316] WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for ā€˜arducam_64mp’
    [0:37:04.928448604] [3316] WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
    [0:37:04.928843894] [3316] ERROR CameraSensor camera_sensor.cpp:591 ā€˜arducam_64mp 10-001a’: Camera sensor does not support test pattern modes.
    [0:37:04.952226129] [3316] WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
    [0:37:04.952886692] [3316] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
    [0:37:04.953089855] [3316] INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media2
    Not applicable, but if you really need the entire log, I can provide it
    Reinstalled, researched to no avail
  8. What help do you need?
    Why do these errors and warnings appear?
    Should I be concerned?
    Can I fix or eliminate them?
    It seems like many other users of the new Pivariety cameras see similar errors and warnings.
@ldwellman
I’m sorry you have this problem with your device, we need some more details before we can help you.
cat /proc/cpuinfo
cat /etc/os-release
cat /boot/config.txt
ls /dev/video*
dpkg -l | grep libcamera
dmesg
Thank you, Edward, for your help. But are you implying that this is not a common problem to all users of the new 64mp Hawkeye camera? Hopefully, the info below will assist you, but I was under the impression that all new 64mp cameras (and perhaps other Pivariety cameras) were exhibiting this same behavior. I only say that because of numerous Google searches and results that others have posted.
Either way, I do truly appreciate your help!
$ cat /proc/cpuinfo
processor       : 0
BogoMIPS        : 108.00
Features        : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 1
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 2
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 3
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
Hardware        : BCM2835
Revision        : c03112
Serial          : 10000000a321b45d
Model           : Raspberry Pi 4 Model B Rev 1.2
$ cat /etc/os-release
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
$ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
#camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
#max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
max_framebuffers=2
dtoverlay=arducam_64mp
gpu_mem=128
$ ls /dev/video*
/dev/video0   /dev/video11  /dev/video14  /dev/video18  /dev/video22
/dev/video1   /dev/video12  /dev/video15  /dev/video20  /dev/video23
/dev/video10  /dev/video13  /dev/video16  /dev/video21  /dev/video31
$ dpkg -l | grep libcamera
ii  libcamera-apps                       0.0.7                            arm64        libcamera-apps
ii  libcamera-dev                        0.0.7                            arm64        libcamera
Regarding ā€œdmesgā€ output, I cannot append it here. I tried, but it has over 500 lines, and then when I tried to complete this post, your forum software said I had exceeded the post size limit of 32000 characters. I can try adding it as a separate post later, or if you can tell me what specific info you are wanting to see in the dmesg log, I can extract that portion.
My ā€˜dmesg’ output is 509 lines with 36287 characters, so I can’t post the entire thing (there’s a 32000 character posting limit).
Give me something to grep for, and I will try to provide you what you need.
@ldwellman
That’s enough information, I found your config file a bit odd, I’ll test it at work and give you a reply.
Before that, you can try to open the line ,reboot and try.
Thank you. For clarification, my camera DOES work, even without that autodetect enabled in the config.txt file. I just always get the originally posted errors every single time I issue any libcamera command. I commented out that line myself, trying to debug this. It did the same thing with or without that autodect line.
For example:
$ libcamera-still --list-cameras
[0:03:09.258171526] [1099]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:03:09.272355158] [1100]  WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:03:09.272435819] [1100]  WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:03:09.273040038] [1100] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:03:09.321538440] [1100]  WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:03:09.322578610] [1100] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:03:09.322925809] [1100]  INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media2
Available cameras
0 : arducam_64mp [9248x6944] (/base/soc/i2c0mux/i2c@1/arducam_64mp@1a)
    Modes: 'SRGGB10_CSI2P' : 1280x720 1920x1080 2312x1736 3840x2160 4624x3472 9152x6944
@ldwellman
This error does not affect your use, you can completely ignore him.This information is more of a warning, and a small amount of error is useless. It’s a normal state to have these things on our devices as well.
Thank you, Edward. I’m willing to ignore these warnings and errors, but I do hope the Arducam engineers and device driver programmers have at least considered them. Some of them sound fixable and suggest incompatibilities between libcamera and the Pivariety 64mp.
@ldwellman
This is a good suggestion.We are working with raspberrypi, these problems will have solutions and reasonable explanations in the future. I hope you will continue to pay attention to our development.
Hi Edward,
I have the same issue. I’m trying to run the script available at ā€œPicamera2 - Arducam Wikiā€. But I get the same error.
/myScripts $ python3 autoFocus.py
[0:18:13.085368599] [8424]  INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4226-8689dd6b
[0:18:13.106267245] [8426]  WARN CameraSensorProperties camera_sensor_properties.cpp:243 No static properties available for 'arducam_64mp'
[0:18:13.106333411] [8426]  WARN CameraSensorProperties camera_sensor_properties.cpp:245 Please consider updating the camera sensor properties database
[0:18:13.121651934] [8426]  WARN RPI raspberrypi.cpp:1366 Mismatch between Unicam and CamHelper for embedded data usage!
[0:18:13.122699985] [8426]  INFO RPI raspberrypi.cpp:1485 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
libEGL warning: DRI3: failed to query the version
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.py", line 36, in createpreview
    qpicamera2 = parent.make_picamera2_widget(cam, width=parent.width, height=parent.height,
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/qt_previews.py", line 141, in make_picamera2_widget
    return QGlPicamera2(picam2, width=self.width, height=self.height, transform=self.transform, preview_window=self)
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 98, in __init__
    self.egl = EglState()
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 28, in __init__
    self.choose_config()
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/q_gl_picamera2.py", line 46, in choose_config
    check_egl_extensions(self.display, ["EGL_EXT_image_dma_buf_import"])
  File "/usr/local/lib/python3.9/dist-packages/picamera2/previews/gl_helpers.py", line 71, in check_egl_extensions
    raise Exception(ext + " missing")
Exception: EGL_EXT_image_dma_buf_import missing
Aborted
@Shaheem
It seems that there are some problems with the display, you can try the example of saving images.
Hello Edward,
I’ve got a similar problem I think:
    Arducam pre-order
    Raspberry Pi 4 Model B Rev 1.5
    8Gb RAM
    Debian Bullseye 11.5 32fre-bit
    [0:01:25.960401002] [1266] INFO Camera camera_manager.cpp:297 libcamera v0.0.0+4367-ad9428b4
    [0:01:25.979681231] [1268] WARN CameraSensorProperties camera_sensor_properties.cpp:261 No static properties available for ā€˜arducam_64mp’
    [0:01:25.979770916] [1268] WARN CameraSensorProperties camera_sensor_properties.cpp:263 Please consider updating the camera sensor properties database
    [0:01:26.029865324] [1268] INFO RPI vc4.cpp:444 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
    [0:01:26.029976657] [1268] INFO RPI pipeline_base.cpp:1101 Using configuration file ā€˜/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml’
    [0:01:26.031016522] [1266] INFO Camera camera.cpp:1033 configuring streams: (0) 4624x3472-YUV420
    [0:01:26.031779593] [1268] INFO RPI vc4.cpp:572 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 4624x3472-SBGGR10_1X10 - Selected unicam format: 4624x3472-pBAA
    [0:01:26.163725601] [1268] ERROR V4L2 v4l2_videodevice.cpp:1906 /dev/video1[15:cap]: Failed to start streaming: Input/output error
    Searched here but no luck
    why can’t I take a picture?
Thank you in adavance!
I got similar problem. I tried with the line commented. It stays the same. Any more follow up answers/ solutions from you?
