64MP QuadCamera - No cameras available!
Ok once that change was made I can run libcamera-still --list-cameras
[0:01:43.442248424] [1349]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:01:43.448321782] [1350]  WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:01:43.448367745] [1350]  WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:01:43.448709614] [1350] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:01:43.470713641] [1350]  WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:01:43.471267622] [1350] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:01:43.471510880] [1350]  INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media3 and ISP device /dev/media1
Available cameras
0 : arducam_64mp [9248x6944] (/base/soc/i2c0mux/i2c@1/arducam_64mp@1a)
    Modes: 'SRGGB10_CSI2P' : 1280x720 1920x1080 2312x1736 3840x2160 4624x3472 9152x6944
I was also able to use the command and receive an image
libcamera-still -t 5000 --viewfinder-width 2312 --viewfinder-height 1736 -o 64mp.jpg
@702enigma
I’m glad this can help you, if you have any questions later, you can open a new topic to ask.
Apologies for necroing this post but I’m also having the same issues as OP, I’m doing this on a CM4 and have installed the drivers as stated in the tutorial in post #5.
I’ve also verified that my boot config is the on as suggested in post #20.
Is there any logs or something I can provide to troubleshoot this?
@AkiraKurai
cat /proc/cpuinfo
cat /etc/os-release
cat /boot/config.txt
ls /dev/video*
dpkg -l | grep libcamera
dmesg
processor       : 0
BogoMIPS        : 108.00
Features        : fp asimd evtstrm crc32 cpuid
CPU implementer : 0x41
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 1
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 2
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
processor       : 3
BogoMIPS        : 108.00
CPU architecture: 8
CPU variant     : 0x0
CPU part        : 0xd08
CPU revision    : 3
Hardware        : BCM2835
Revision        : d03140
Serial          : 100000009b906bd0
Model           : Raspberry Pi Compute Module 4 Rev 1.0
PRETTY_NAME="Debian GNU/Linux 11 (bullseye)"
NAME="Debian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=debian
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
#dtoverlay=dwc2,dr_mode=host
gpu_mem=128
[pi4]
dtoverlay=vc4-fkms-v3d
arm_boost=1
#dtoverlay=vc4-fkms-v3d,cma-512
/dev/video10  /dev/video11  /dev/video12  /dev/video13  /dev/video14  /dev/video15  /dev/video16  /dev/video18  /dev/video20  /dev/video21  /dev/video22  /dev/video23  /dev/video31
ii  libcamera-apps                       0.0.4                            arm64        libcamera-apps
ii  libcamera-dev                        0.0.3                            arm64        libcamera
Apologies for the double post, the last message wouldn’t fit.
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[    0.000000] Linux version 5.15.32-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022
[    0.000000] random: fast init done
[    0.000000] Machine model: Raspberry Pi Compute Module 4 Rev 1.0
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000003fffffff]
[    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x0000000037ffffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x00000000fbffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x00000001ffffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[    0.000000] percpu: Embedded 28 pages/cpu s77144 r8192 d29352 u114688
[    0.000000] pcpu-alloc: s77144 r8192 d29352 u114688 alloc=28*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Detected PIPT I-cache on CPU0
[    0.000000] CPU features: detected: Spectre-v2
[    0.000000] CPU features: detected: Spectre-v4
[    0.000000] CPU features: detected: Spectre-BHB
[    0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 2015744
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1  smsc95xx.macaddr=E4:5F:01:4F:AF:5B vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=fcf8750c-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000034000000-0x0000000038000000] (64MB)
[    0.000000] Memory: 7617416K/8192000K available (11456K kernel code, 1962K rwdata, 4144K rodata, 3776K init, 964K bss, 246904K reserved, 327680K cma-reserved)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 37889 entries in 149 pages
[    0.000000] ftrace: allocated 149 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000]  Rude variant of Tasks RCU enabled.
[    0.000000]  Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] Root IRQ handler: gic_handle_irq
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x510/0x6f8 with crng_init=1
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000250] Console: colour dummy device 80x25
[    0.000304] printk: console [tty1] enabled
[    0.000376] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[    0.000401] pid_max: default: 32768 minimum: 301
[    0.000527] LSM: Security Framework initializing
[    0.000770] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.000887] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.002127] cgroup: Disabling memory control group subsystem
[    0.004632] rcu: Hierarchical SRCU implementation.
[    0.005742] EFI services will not be available.
[    0.006281] smp: Bringing up secondary CPUs ...
[    0.007320] Detected PIPT I-cache on CPU1
[    0.007399] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[    0.008634] Detected PIPT I-cache on CPU2
[    0.008684] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[    0.009816] Detected PIPT I-cache on CPU3
[    0.009865] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[    0.010015] smp: Brought up 1 node, 4 CPUs
[    0.010036] SMP: Total of 4 processors activated.
[    0.010048] CPU features: detected: 32-bit EL0 Support
[    0.010057] CPU features: detected: 32-bit EL1 Support
[    0.010070] CPU features: detected: CRC32 instructions
[    0.041296] CPU: All CPU(s) started at EL2
[    0.041370] alternatives: patching kernel code
[    0.043494] devtmpfs: initialized
[    0.054403] Enabled cp15_barrier support
[    0.054445] Enabled setend support
[    0.054650] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.054683] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.065397] pinctrl core: initialized pinctrl subsystem
[    0.066207] DMI not present or invalid.
[    0.066691] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.070415] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[    0.070714] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.071608] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.071703] audit: initializing netlink subsys (disabled)
[    0.071993] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[    0.072526] thermal_sys: Registered thermal governor 'step_wise'
[    0.072747] cpuidle: using governor menu
[    0.073090] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.073277] ASID allocator initialised with 65536 entries
[    0.073435] Serial: AMBA PL011 UART driver
[    0.083535] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.100308] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-03-24T13:20:19, variant start_x
[    0.104326] raspberrypi-firmware soc:firmware: Firmware hash is e5a963efa66a1974127860b42e913d2374139ff5
[    0.156238] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.160418] vgaarb: loaded
[    0.160926] SCSI subsystem initialized
[    0.161162] usbcore: registered new interface driver usbfs
[    0.161216] usbcore: registered new interface driver hub
[    0.161284] usbcore: registered new device driver usb
[    0.161601] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.162084] pps_core: LinuxPPS API ver. 1 registered
[    0.162097] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.162129] PTP clock support registered
[    0.163586] clocksource: Switched to clocksource arch_sys_counter
[    0.244061] VFS: Disk quotas dquot_6.6.0
[    0.244169] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.244337] FS-Cache: Loaded
[    0.244573] CacheFiles: Loaded
[    0.255283] NET: Registered PF_INET protocol family
[    0.256286] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.262289] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[    0.262391] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[    0.262868] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.263933] TCP: Hash tables configured (established 65536 bind 65536)
[    0.264251] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.264396] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[    0.264801] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.265836] RPC: Registered named UNIX socket transport module.
[    0.265855] RPC: Registered udp transport module.
[    0.265866] RPC: Registered tcp transport module.
[    0.265876] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.265897] PCI: CLS 0 bytes, default 64
[    0.268565] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[    0.268927] kvm [1]: IPA Size Limit: 44 bits
[    0.270092] kvm [1]: vgic interrupt IRQ9
[    0.270352] kvm [1]: Hyp mode initialized successfully
[    1.177200] Initialise system trusted keyrings
[    1.177566] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[    1.184212] zbud: loaded
[    1.186076] FS-Cache: Netfs 'nfs' registered for caching
[    1.186741] NFS: Registering the id_resolver key type
[    1.186779] Key type id_resolver registered
[    1.186790] Key type id_legacy registered
[    1.186894] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.186907] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.188114] Key type asymmetric registered
[    1.188130] Asymmetric key parser 'x509' registered
[    1.188210] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.188466] io scheduler mq-deadline registered
[    1.188481] io scheduler kyber registered
[    1.196962] gpio-507 (ant1): hogged as output/high
[    1.198391] gpio-511 (ant2): hogged as output/low
[    1.199744] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.199781] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.199867] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.199949] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x01ffffffff -> 0x0400000000
[    1.519614] brcm-pcie fd500000.pcie: link down
[    1.527157] iproc-rng200 fe104000.rng: hwrng registered
[    1.527677] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.529010] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.529430] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    1.540583] brd: module loaded
[    1.550171] loop: module loaded
[    1.550914] Loading iSCSI transport class v2.0-870.
[    1.555870] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.615739] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.616870] usbcore: registered new interface driver r8152
[    1.616935] usbcore: registered new interface driver lan78xx
[    1.617011] usbcore: registered new interface driver smsc95xx
[    1.642913] xhci-hcd fe9c0000.xhci: xHCI Host Controller
[    1.642957] xhci-hcd fe9c0000.xhci: new USB bus registered, assigned bus number 1
[    1.643292] xhci-hcd fe9c0000.xhci: hcc params 0x0220fe65 hci version 0x110 quirks 0x0000000000010010
[    1.643396] xhci-hcd fe9c0000.xhci: irq 43, io mem 0xfe9c0000
[    1.644044] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.644066] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.644082] usb usb1: Product: xHCI Host Controller
[    1.644096] usb usb1: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[    1.644109] usb usb1: SerialNumber: fe9c0000.xhci
[    1.644795] hub 1-0:1.0: USB hub found
[    1.644862] hub 1-0:1.0: 1 port detected
[    1.645350] xhci-hcd fe9c0000.xhci: xHCI Host Controller
[    1.645372] xhci-hcd fe9c0000.xhci: new USB bus registered, assigned bus number 2
[    1.645396] xhci-hcd fe9c0000.xhci: Host supports USB 3.0 SuperSpeed
[    1.645549] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.645835] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.645855] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.645870] usb usb2: Product: xHCI Host Controller
[    1.645883] usb usb2: Manufacturer: Linux 5.15.32-v8+ xhci-hcd
[    1.645896] usb usb2: SerialNumber: fe9c0000.xhci
[    1.646523] hub 2-0:1.0: USB hub found
[    1.646586] hub 2-0:1.0: config failed, hub doesn't have any ports! (err -19)
[    1.647111] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.647400] dwc_otg: FIQ enabled
[    1.647411] dwc_otg: NAK holdoff enabled
[    1.647421] dwc_otg: FIQ split-transaction FSM enabled
[    1.647434] Module dwc_common_port init
[    1.648027] usbcore: registered new interface driver uas
[    1.648122] usbcore: registered new interface driver usb-storage
[    1.648366] mousedev: PS/2 mouse device common for all mice
[    1.653095] sdhci: Secure Digital Host Controller Interface driver
[    1.653113] sdhci: Copyright(c) Pierre Ossman
[    1.653663] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.657052] ledtrig-cpu: registered to indicate activity on CPUs
[    1.657641] hid: raw HID events driver (C) Jiri Kosina
[    1.657793] usbcore: registered new interface driver usbhid
[    1.657806] usbhid: USB HID core driver
[    1.658131] ashmem: initialized
[    1.666591] Initializing XFRM netlink socket
[    1.666640] NET: Registered PF_PACKET protocol family
[    1.666764] Key type dns_resolver registered
[    1.668169] registered taskstats version 1
[    1.668202] Loading compiled-in X.509 certificates
[    1.668867] Key type ._fscrypt registered
[    1.668881] Key type .fscrypt registered
[    1.668891] Key type fscrypt-provisioning registered
[    1.680376] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.680663] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.680803] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 17, base_baud = 0) is a PL011 rev2
[    1.689778] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.690250] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.691414] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.691434] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.721365] of_cfs_init
[    1.721496] of_cfs_init: OK
[    1.760225] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.760554] Waiting for root device PARTUUID=fcf8750c-02...
[    1.808556] mmc1: new high speed SDIO card at address 0001
[    1.828970] mmc0: new DDR MMC card at address 0001
[    1.829973] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[    1.833021]  mmcblk0: p1 p2
[    1.833574] mmcblk0: mmc0:0001 BJTD4R 29.1 GiB
[    1.834140] mmcblk0boot0: mmc0:0001 BJTD4R 4.00 MiB
[    1.836777] mmcblk0boot1: mmc0:0001 BJTD4R 4.00 MiB
[    1.839051] mmcblk0rpmb: mmc0:0001 BJTD4R 4.00 MiB, chardev (242:0)
[    1.844791] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[    1.844816] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[    1.899637] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.047927] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    2.047975] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.054700] EXT4-fs (mmcblk0p2): recovery complete
[    2.055860] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    2.055952] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    2.056494] devtmpfs: mounted
[    2.065135] Freeing unused kernel memory: 3776K
[    2.065377] Run /sbin/init as init process
[    2.065389]   with arguments:
[    2.065397]     /sbin/init
[    2.065407]     splash
[    2.065417]   with environment:
[    2.065425]     HOME=/
[    2.065435]     TERM=linux
[    2.093803] hub 1-1:1.0: USB hub found
[    2.093917] hub 1-1:1.0: 4 ports detected
[    2.304885] systemd[1]: System time before build time, advancing clock.
[    2.374216] NET: Registered PF_INET6 protocol family
[    2.376131] Segment Routing with IPv6
[    2.376173] In-situ OAM (IOAM) with IPv6
[    2.416016] systemd[1]: systemd 247.3-7 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    2.416964] systemd[1]: Detected architecture arm64.
[    2.420723] systemd[1]: Set hostname to <raspberrypi>.
[    2.923618] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    3.117558] systemd[1]: Queued start job for default target Multi-User System.
[    3.119642] random: systemd: uninitialized urandom read (16 bytes read)
[    3.121959] systemd[1]: Created slice system-getty.slice.
[    3.122314] random: systemd: uninitialized urandom read (16 bytes read)
[    3.123322] systemd[1]: Created slice system-modprobe.slice.
[    3.123427] random: systemd: uninitialized urandom read (16 bytes read)
[    3.124448] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.125300] systemd[1]: Created slice User and Session Slice.
[    3.125844] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.126908] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.127377] systemd[1]: Reached target Slices.
[    3.127549] systemd[1]: Reached target Swap.
[    3.128576] systemd[1]: Listening on Syslog Socket.
[    3.129310] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.129714] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.130890] systemd[1]: Listening on Journal Audit Socket.
[    3.131746] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.132704] systemd[1]: Listening on Journal Socket.
[    3.134474] systemd[1]: Listening on udev Control Socket.
[    3.135297] systemd[1]: Listening on udev Kernel Socket.
[    3.136318] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    3.140356] systemd[1]: Mounting POSIX Message Queue File System...
[    3.144767] systemd[1]: Mounting RPC Pipe File System...
[    3.150197] systemd[1]: Mounting Kernel Debug File System...
[    3.155654] systemd[1]: Mounting Kernel Trace File System...
[    3.156216] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    3.162126] systemd[1]: Starting Restore / save the current clock...
[    3.169157] systemd[1]: Starting Set the console keyboard layout...
[    3.175029] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.180918] systemd[1]: Starting Load Kernel Module configfs...
[    3.186740] systemd[1]: Starting Load Kernel Module drm...
[    3.192724] systemd[1]: Starting Load Kernel Module fuse...
[    3.195646] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.204934] systemd[1]: Starting File System Check on Root Device...
[    3.214385] systemd[1]: Starting Journal Service...
[    3.221063] fuse: init (API version 7.34)
[    3.223191] systemd[1]: Starting Load Kernel Modules...
[    3.228950] systemd[1]: Starting Coldplug All udev Devices...
[    3.256207] systemd[1]: Mounted POSIX Message Queue File System.
[    3.257089] systemd[1]: Mounted RPC Pipe File System.
[    3.257917] systemd[1]: Mounted Kernel Debug File System.
[    3.258751] systemd[1]: Mounted Kernel Trace File System.
[    3.262735] systemd[1]: Finished Restore / save the current clock.
[    3.267249] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.269748] systemd[1]: [email protected]: Succeeded.
[    3.271431] systemd[1]: Finished Load Kernel Module configfs.
[    3.274050] systemd[1]: [email protected]: Succeeded.
[    3.276345] systemd[1]: Finished Load Kernel Module fuse.
[    3.285449] systemd[1]: Mounting FUSE Control File System...
[    3.291174] systemd[1]: Mounting Kernel Configuration File System...
[    3.299019] i2c_dev: i2c /dev entries driver
[    3.301669] systemd[1]: Started File System Check Daemon to report status.
[    3.345789] systemd[1]: [email protected]: Succeeded.
[    3.352528] systemd[1]: Finished Load Kernel Module drm.
[    3.359338] systemd[1]: Finished Load Kernel Modules.
[    3.363445] systemd[1]: Mounted FUSE Control File System.
[    3.367898] systemd[1]: Mounted Kernel Configuration File System.
[    3.378747] systemd[1]: Starting Apply Kernel Variables...
[    3.425991] systemd[1]: Finished File System Check on Root Device.
[    3.434034] systemd[1]: Starting Remount Root and Kernel File Systems...
[    3.465932] systemd[1]: Finished Apply Kernel Variables.
[    3.522342] systemd[1]: Started Journal Service.
[    3.566880] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[    3.625677] systemd-journald[135]: Received client request to flush runtime journal.
[    3.632431] systemd-journald[135]: File /var/log/journal/b1e9c2062c05452899316375dd645d04/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    4.560256] mc: Linux media interface: v0.10
[    4.564669] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[    4.589378] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[    4.597450] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[    4.598190] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[    4.657205] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    4.665877] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    4.675338] videodev: Linux video capture interface: v2.00
[    4.675790] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    4.675818] [vc_sm_connected_init]: start
[    4.701308] [vc_sm_connected_init]: installed successfully
[    4.738699] bcm2835_audio bcm2835_audio: there is not valid maps for state default
[    4.883643] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    4.884920] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.895024] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    4.899694] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    4.904092] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    4.932981] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    4.942000] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    4.952386] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    5.031350] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    5.104229] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[    5.104400] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[    5.115558] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    5.127862] brcmfmac: F1 signature read @0x18000000=0x15264345
[    5.161775] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    5.163065] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43455-sdio.raspberrypi,4-compute-module.bin failed with error -2
[    5.423446] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    5.424419] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    5.429715] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    5.431662] random: crng init done
[    5.431686] random: 7 urandom warning(s) missed due to ratelimiting
[    5.455649] usbcore: registered new interface driver brcmfmac
[    5.549118] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    5.558825] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    5.558896] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    5.588038] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    5.590291] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    5.590366] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    5.616124] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    5.616189] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    5.625677] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    5.626282] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    5.626317] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.626338] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.626356] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.626373] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.640564] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    5.648053] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    5.648115] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    5.661778] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    5.715840] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    5.715900] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    5.751885] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    5.757454] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    5.757504] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    5.757527] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    5.757546] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    5.757584] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    5.834410] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.660063] 8021q: 802.1Q VLAN Support v1.8
[    6.665856] uart-pl011 fe201000.serial: no DMA platform data
[    6.908197] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    7.001968] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[    7.161631] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    7.161916] bcmgenet fd580000.ethernet eth0: Link is Down
[   12.829640] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   13.570770] Bluetooth: Core ver 2.22
[   13.570939] NET: Registered PF_BLUETOOTH protocol family
[   13.570954] Bluetooth: HCI device and connection manager initialized
[   13.570984] Bluetooth: HCI socket layer initialized
[   13.571002] Bluetooth: L2CAP socket layer initialized
[   13.571035] Bluetooth: SCO socket layer initialized
[   13.580964] Bluetooth: HCI UART driver ver 2.3
[   13.581006] Bluetooth: HCI UART protocol H4 registered
[   13.581143] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   13.581509] Bluetooth: HCI UART protocol Broadcom registered
[   13.769163] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   13.769183] Bluetooth: BNEP filters: protocol multicast
[   13.769198] Bluetooth: BNEP socket layer initialized
[   13.779787] NET: Registered PF_ALG protocol family
[   33.759661] cam-dummy-reg: disabling
[11068.821538] Bluetooth: RFCOMM TTY layer initialized
[11068.821568] Bluetooth: RFCOMM socket layer initialized
[11068.821591] Bluetooth: RFCOMM ver 1.11
@AkiraKurai
Which tutorial are you following,You can follow the tutorial I wrote again. How to use arducam_64mp - #2 by Edward
I see, I was following the one from the product page, but it seems to be missing from the website right now.
After following the instructions linked and then attempting the example libcamera-still threw this error at me.
Preview window unavailable
[0:09:15.173714053] [1654]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3572-e13ccdd5
[0:09:15.180057370] [1656]  WARN CameraSensorProperties camera_sensor_properties.cpp:163 No static properties available for 'arducam_64mp'
[0:09:15.180112128] [1656]  WARN CameraSensorProperties camera_sensor_properties.cpp:165 Please consider updating the camera sensor properties database
[0:09:15.180466528] [1656] ERROR CameraSensor camera_sensor.cpp:591 'arducam_64mp 10-001a': Camera sensor does not support test pattern modes.
[0:09:15.203458715] [1656]  WARN RPI raspberrypi.cpp:1263 Mismatch between Unicam and CamHelper for embedded data usage!
[0:09:15.204172590] [1656] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:09:15.204372141] [1656]  INFO RPI raspberrypi.cpp:1386 Registered camera /base/soc/i2c0mux/i2c@1/arducam_64mp@1a to Unicam device /dev/media0 and ISP device /dev/media2
[0:09:15.205078368] [1654]  INFO Camera camera.cpp:1029 configuring streams: (0) 2312x1736-YUV420
[0:09:15.205518840] [1656]  INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 2312x1736-SBGGR10_1X10 - Selected unicam format: 2312x1736-pBAA
[0:09:20.574469672] [1654]  INFO Camera camera.cpp:1029 configuring streams: (0) 9152x6944-YUV420 (1) 9152x6944-SBGGR10_CSI2P
[0:09:20.575935255] [1656]  INFO RPI raspberrypi.cpp:764 Sensor: /base/soc/i2c0mux/i2c@1/arducam_64mp@1a - Selected sensor format: 9152x6944-SBGGR10_1X10 - Selected unicam format: 9152x6944-pBAA
[0:09:20.772183715] [1656] ERROR V4L2 v4l2_videodevice.cpp:1211 /dev/video0[14:cap]: Unable to request 1 buffers: Cannot allocate memory
ERROR: *** failed to allocate capture buffers ***
@AkiraKurai
Take a look at memory allocation
cat /proc/meminfo
MemTotal:        7948868 kB
MemFree:         7671472 kB
MemAvailable:    7747048 kB
Buffers:           19908 kB
Cached:           146560 kB
SwapCached:            0 kB
Active:            83632 kB
Inactive:         113744 kB
Active(anon):        512 kB
Inactive(anon):    31252 kB
Active(file):      83120 kB
Inactive(file):    82492 kB
Unevictable:          16 kB
Mlocked:              16 kB
SwapTotal:        102396 kB
SwapFree:         102396 kB
Dirty:               196 kB
Writeback:             0 kB
AnonPages:         30960 kB
Mapped:            44008 kB
Shmem:               848 kB
KReclaimable:      20212 kB
Slab:              43272 kB
SReclaimable:      20212 kB
SUnreclaim:        23060 kB
KernelStack:        2384 kB
PageTables:         1912 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     4076828 kB
Committed_AS:     243316 kB
VmallocTotal:   259653632 kB
VmallocUsed:        9192 kB
VmallocChunk:          0 kB
Percpu:              640 kB
CmaTotal:         327680 kB
CmaFree:          316904 kB
@AkiraKurai
Did you perform this step?
Apologies, yes, I forgot to uncomment the dtoverlay, thank you, it works now.
Hello i have the same problem : no camera available
I make a lot of try with different config pi3b, pi4 4giga, new pi4 8 giga my last one .
The system never work, i have baught the kit 4 camera 64mp with camaray hat .
I have controlled the connection, all camera and the hat seems to be ok but nothing is working . i use all procedure that i found in the forum and internet but nothing change .
Sorry for my english
~ $ cat /proc/cpuinfo
cat /etc/os-release
processor : 0
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 1
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 2
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
processor : 3
BogoMIPS : 108.00
CPU architecture: 8
CPU variant : 0x0
CPU part : 0xd08
CPU revision : 3
Hardware : BCM2835
Revision : d03115
Serial : 100000009a45bd6d
Model : Raspberry Pi 4 Model B Rev 1.5
PRETTY_NAME=ā€œDebian GNU/Linux 11 (bullseye)ā€
NAME=ā€œDebian GNU/Linuxā€
VERSION_ID=ā€œ11ā€
VERSION=ā€œ11 (bullseye)ā€
ID=debian
Raspberry Pi Documentation - Configuration
uncomment if you get no picture on HDMI for a default ā€œsafeā€ mode
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
no display
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
start_x=1
camera_auto_detect=1
max_framebuffers=2
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
dtoverlay=vc4-kms-v3d,cma-512
dtoverlay=arducam_64mp
dtparam=i2c_vc=on
dtparam=i2c_arm=on
gpu_mem=128
/dev/video10 /dev/video13 /dev/video16 /dev/video20 /dev/video23
/dev/video11 /dev/video14 /dev/video18 /dev/video21 /dev/video31
/dev/video12 /dev/video15 /dev/video19 /dev/video22
[ 0.000000] Linux version 5.15.84-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP PREEMPT Thu Jan 5 12:03:08 GMT 2023
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.5
[ 0.000000] On node 0, zone Normal: 16384 pages in unavailable ranges
[ 0.000000] percpu: Embedded 28 pages/cpu s77336 r8192 d29160 u114688
[ 0.000000] pcpu-alloc: s77336 r8192 d29160 u114688 alloc=28*4096
[ 0.000000] CPU features: detected: Spectre-v3a
[ 0.000000] CPU features: detected: ARM erratum 1742098
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:F7:BF:98 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 console=ttyS0,115200 console=tty1 root=PARTUUID=1d61b5bd-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Unknown kernel command line parameters ā€œsplashā€, will be passed to user space.
[ 0.000000] Memory: 7420676K/8192000K available (11520K kernel code, 1956K rwdata, 4136K rodata, 3776K init, 975K bss, 247036K reserved, 524288K cma-reserved)
[ 0.000000] ftrace: allocating 38065 entries in 149 pages
[ 0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 10)
[ 0.000001] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000362] Console: colour dummy device 80x25
[ 0.000426] printk: console [tty1] enabled
[ 0.000497] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000524] pid_max: default: 32768 minimum: 301
[ 0.000658] LSM: Security Framework initializing
[ 0.000957] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001089] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002427] cgroup: Disabling memory control group subsystem
[ 0.005545] rcu: Hierarchical SRCU implementation.
[ 0.006780] EFI services will not be available.
[ 0.007352] smp: Bringing up secondary CPUs …
[ 0.008602] Detected PIPT I-cache on CPU1
[ 0.008689] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.009938] Detected PIPT I-cache on CPU2
[ 0.009990] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.011208] Detected PIPT I-cache on CPU3
[ 0.011264] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.011423] smp: Brought up 1 node, 4 CPUs
[ 0.011448] SMP: Total of 4 processors activated.
[ 0.011460] CPU features: detected: 32-bit EL0 Support
[ 0.011470] CPU features: detected: 32-bit EL1 Support
[ 0.011483] CPU features: detected: CRC32 instructions
[ 0.045185] CPU: All CPU(s) started at EL2
[ 0.045267] alternatives: patching kernel code
[ 0.047174] devtmpfs: initialized
[ 0.059386] Enabled cp15_barrier support
[ 0.059431] Enabled setend support
[ 0.059461] KASLR enabled
[ 0.059673] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.059708] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.075297] pinctrl core: initialized pinctrl subsystem
[ 0.076244] DMI not present or invalid.
[ 0.076998] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.080939] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.081258] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.082191] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.082300] audit: initializing netlink subsys (disabled)
[ 0.082604] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1
[ 0.083212] thermal_sys: Registered thermal governor ā€˜step_wise’
[ 0.083447] cpuidle: using governor menu
[ 0.083837] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.084043] ASID allocator initialised with 32768 entries
[ 0.084215] Serial: AMBA PL011 UART driver
[ 0.098850] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.128466] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:47:47, variant start_x
[ 0.132480] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[ 0.186330] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.190785] vgaarb: loaded
[ 0.191247] SCSI subsystem initialized
[ 0.191466] usbcore: registered new interface driver usbfs
[ 0.191531] usbcore: registered new interface driver hub
[ 0.191600] usbcore: registered new device driver usb
[ 0.192009] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.192210] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[ 0.192519] pps_core: LinuxPPS API ver. 1 registered
[ 0.192533] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [email protected]
[ 0.192557] PTP clock support registered
[ 0.194208] clocksource: Switched to clocksource arch_sys_counter
[ 0.286827] VFS: Disk quotas dquot_6.6.0
[ 0.286944] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.287133] FS-Cache: Loaded
[ 0.287411] CacheFiles: Loaded
[ 0.288853] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[ 0.288874] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 0.289405] Console: switching to colour frame buffer device 240x67
[ 0.300994] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[ 0.311970] NET: Registered PF_INET protocol family
[ 0.312978] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.319100] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.319206] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.319239] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.319732] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.320852] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.321193] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.321357] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.321813] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.323449] RPC: Registered named UNIX socket transport module.
[ 0.323470] RPC: Registered udp transport module.
[ 0.323480] RPC: Registered tcp transport module.
[ 0.323492] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.323512] PCI: CLS 0 bytes, default 64
[ 0.326030] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 0.326425] kvm [1]: IPA Size Limit: 44 bits
[ 0.327670] kvm [1]: vgic interrupt IRQ9
[ 0.327953] kvm [1]: Hyp mode initialized successfully
[ 1.201839] Initialise system trusted keyrings
[ 1.202274] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.209521] zbud: loaded
[ 1.211475] FS-Cache: Netfs ā€˜nfs’ registered for caching
[ 1.212223] NFS: Registering the id_resolver key type
[ 1.212260] Key type id_resolver registered
[ 1.212272] Key type id_legacy registered
[ 1.212379] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.212393] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.213649] Key type asymmetric registered
[ 1.213665] Asymmetric key parser ā€˜x509’ registered
[ 1.213754] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 1.214024] io scheduler mq-deadline registered
[ 1.214039] io scheduler kyber registered
[ 1.223020] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.223070] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.223157] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff → 0x00c0000000
[ 1.223251] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff → 0x0400000000
[ 1.288309] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.288697] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.288718] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.288737] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.288828] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.289087] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.293020] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 1.293394] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.293518] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.293947] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.297956] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 1.298007] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.298030] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.298071] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.298094] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.311396] iproc-rng200 fe104000.rng: hwrng registered
[ 1.311914] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.313473] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.326819] brd: module loaded
[ 1.337054] loop: module loaded
[ 1.337969] Loading iSCSI transport class v2.0-870.
[ 1.343387] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.402368] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.403633] usbcore: registered new interface driver r8152
[ 1.403702] usbcore: registered new interface driver lan78xx
[ 1.403760] usbcore: registered new interface driver smsc95xx
[ 1.452599] pci 0000:00:00.0: enabling device (0000 → 0002)
[ 1.452784] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.452820] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.453646] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[ 1.454839] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.454863] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.454888] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.455328] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[ 1.455350] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.455367] usb usb1: Product: xHCI Host Controller
[ 1.455381] usb usb1: Manufacturer: Linux 5.15.84-v8+ xhci-hcd
[ 1.455394] usb usb1: SerialNumber: 0000:01:00.0
[ 1.456160] hub 1-0:1.0: USB hub found
[ 1.456232] hub 1-0:1.0: 1 port detected
[ 1.457218] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[ 1.457240] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.457255] usb usb2: Product: xHCI Host Controller
[ 1.457269] usb usb2: Manufacturer: Linux 5.15.84-v8+ xhci-hcd
[ 1.457282] usb usb2: SerialNumber: 0000:01:00.0
[ 1.457971] hub 2-0:1.0: USB hub found
[ 1.458069] hub 2-0:1.0: 4 ports detected
[ 1.459962] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.460316] dwc_otg: FIQ enabled
[ 1.460327] dwc_otg: NAK holdoff enabled
[ 1.460338] dwc_otg: FIQ split-transaction FSM enabled
[ 1.460351] Module dwc_common_port init
[ 1.460972] usbcore: registered new interface driver uas
[ 1.461074] usbcore: registered new interface driver usb-storage
[ 1.461303] mousedev: PS/2 mouse device common for all mice
[ 1.467433] sdhci: Secure Digital Host Controller Interface driver
[ 1.467457] sdhci: Copyright(c) Pierre Ossman
[ 1.468151] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.471939] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.472589] hid: raw HID events driver (C) Jiri Kosina
[ 1.472755] usbcore: registered new interface driver usbhid
[ 1.472770] usbhid: USB HID core driver
[ 1.473133] ashmem: initialized
[ 1.482100] NET: Registered PF_PACKET protocol family
[ 1.482297] Key type dns_resolver registered
[ 1.483699] registered taskstats version 1
[ 1.483746] Loading compiled-in X.509 certificates
[ 1.484405] Key type .fscrypt registered
[ 1.484420] Key type fscrypt-provisioning registered
[ 1.496453] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.496769] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.496948] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 19, base_baud = 0) is a PL011 rev2
[ 1.507583] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.508086] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.509308] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.509329] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.540319] of_cfs_init
[ 1.540480] of_cfs_init: OK
[ 1.573848] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.574298] Waiting for root device PARTUUID=1d61b5bd-02…
[ 1.646662] mmc1: new high speed SDIO card at address 0001
[ 1.677120] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.678177] mmcblk0: mmc0:aaaa ACLCD 29.7 GiB
[ 1.682777] mmcblk0: p1 p2
[ 1.683361] mmcblk0: mmc0:aaaa ACLCD 29.7 GiB (quirks 0x00004000)
[ 1.698262] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 1.698383] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.699216] devtmpfs: mounted
[ 1.707977] Freeing unused kernel memory: 3776K
[ 1.708217] Run /sbin/init as init process
[ 1.708229] with arguments:
[ 1.708238] /sbin/init
[ 1.708248] splash
[ 1.708258] with environment:
[ 1.708266] HOME=/
[ 1.708277] TERM=linux
[ 1.710362] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.860900] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.860940] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.860957] usb 1-1: Product: USB2.0 Hub
[ 1.863312] hub 1-1:1.0: USB hub found
[ 1.863659] hub 1-1:1.0: 4 ports detected
[ 2.065332] systemd[1]: System time before build time, advancing clock.
[ 2.158273] usb 1-1.3: new low-speed USB device number 3 using xhci_hcd
[ 2.260138] NET: Registered PF_INET6 protocol family
[ 2.262169] Segment Routing with IPv6
[ 2.262255] In-situ OAM (IOAM) with IPv6
[ 2.267096] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c050, bcdDevice=27.20
[ 2.267130] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.267156] usb 1-1.3: Product: USB-PS/2 Optical Mouse
[ 2.267171] usb 1-1.3: Manufacturer: Logitech
[ 2.278141] input: Logitech USB-PS/2 Optical Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C050.0001/input/input0
[ 2.278760] hid-generic 0003:046D:C050.0001: input,hidraw0: USB HID v1.10 Mouse [Logitech USB-PS/2 Optical Mouse] on usb-0000:01:00.0-1.3/input0
[ 2.341683] systemd[1]: systemd 247.3-7+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 2.342860] systemd[1]: Detected architecture arm64.
[ 2.347516] systemd[1]: Set hostname to .
[ 2.358278] usb 1-1.4: new low-speed USB device number 4 using xhci_hcd
[ 2.472938] usb 1-1.4: New USB device found, idVendor=413c, idProduct=2107, bcdDevice= 1.04
[ 2.472987] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.473005] usb 1-1.4: Product: Dell USB Entry Keyboard
[ 2.473021] usb 1-1.4: Manufacturer: DELL
[ 2.484321] input: DELL Dell USB Entry Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/0003:413C:2107.0002/input/input1
[ 2.543325] hid-generic 0003:413C:2107.0002: input,hidraw1: USB HID v1.11 Keyboard [DELL Dell USB Entry Keyboard] on usb-0000:01:00.0-1.4/input0
[ 2.956116] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd’s process lifecycle management for the service. Please update your service to use a safer KillMode=, such as ā€˜mixed’ or ā€˜control-group’. Support for KillMode=none is deprecated and will eventually be removed.
[ 3.103823] systemd[1]: Queued start job for default target Graphical Interface.
[ 3.110739] systemd[1]: Created slice system-getty.slice.
[ 3.112099] systemd[1]: Created slice system-modprobe.slice.
[ 3.113090] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.113918] systemd[1]: Created slice User and Session Slice.
[ 3.114559] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.115724] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.116182] systemd[1]: Reached target Slices.
[ 3.116312] systemd[1]: Reached target Swap.
[ 3.117319] systemd[1]: Listening on Syslog Socket.
[ 3.118081] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 3.118556] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 3.119793] systemd[1]: Listening on Journal Audit Socket.
[ 3.120604] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.121572] systemd[1]: Listening on Journal Socket.
[ 3.129207] systemd[1]: Listening on udev Control Socket.
[ 3.130156] systemd[1]: Listening on udev Kernel Socket.
[ 3.131370] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.135747] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.140635] systemd[1]: Mounting RPC Pipe File System…
[ 3.146307] systemd[1]: Mounting Kernel Debug File System…
[ 3.152074] systemd[1]: Mounting Kernel Trace File System…
[ 3.152628] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[ 3.160832] systemd[1]: Starting Restore / save the current clock…
[ 3.166798] systemd[1]: Starting Set the console keyboard layout…
[ 3.172629] systemd[1]: Starting Create list of static device nodes for the current kernel…
[ 3.184111] systemd[1]: Starting Load Kernel Module configfs…
[ 3.190479] systemd[1]: Starting Load Kernel Module drm…
[ 3.197211] systemd[1]: Starting Load Kernel Module fuse…
[ 3.201056] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[ 3.208042] systemd[1]: Starting File System Check on Root Device…
[ 3.218937] systemd[1]: Starting Journal Service…
[ 3.228487] systemd[1]: Starting Load Kernel Modules…
[ 3.234568] systemd[1]: Starting Coldplug All udev Devices…
[ 3.281443] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.295050] systemd[1]: Mounted RPC Pipe File System.
[ 3.296556] systemd[1]: Mounted Kernel Debug File System.
[ 3.297642] systemd[1]: Mounted Kernel Trace File System.
[ 3.302349] fuse: init (API version 7.34)
[ 3.305848] systemd[1]: Finished Restore / save the current clock.
[ 3.309590] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.312332] systemd[1]: [email protected]: Succeeded.
[ 3.314276] systemd[1]: Finished Load Kernel Module configfs.
[ 3.316917] systemd[1]: [email protected]: Succeeded.
[ 3.318902] systemd[1]: Finished Load Kernel Module fuse.
[ 3.319846] i2c_dev: i2c /dev entries driver
[ 3.327710] systemd[1]: Mounting FUSE Control File System…
[ 3.333689] systemd[1]: Mounting Kernel Configuration File System…
[ 3.340633] systemd[1]: Started File System Check Daemon to report status.
[ 3.345304] systemd[1]: Finished Load Kernel Modules.
[ 3.356513] systemd[1]: Starting Apply Kernel Variables…
[ 3.385205] systemd[1]: Mounted FUSE Control File System.
[ 3.389658] systemd[1]: Mounted Kernel Configuration File System.
[ 3.447778] systemd[1]: Finished Apply Kernel Variables.
[ 3.461221] systemd[1]: Finished File System Check on Root Device.
[ 3.465330] systemd[1]: [email protected]: Succeeded.
[ 3.467700] systemd[1]: Finished Load Kernel Module drm.
[ 3.475613] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 3.636456] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[ 3.648441] systemd[1]: Finished Remount Root and Kernel File Systems.
[ 3.653938] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[ 3.654716] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
[ 3.659496] systemd[1]: Starting Load/Save Random Seed…
[ 3.664740] systemd[1]: Starting Create System Users…
[ 3.666010] systemd[1]: Started Journal Service.
[ 3.734393] systemd-journald[135]: Received client request to flush runtime journal.
[ 3.750538] systemd-journald[135]: File /var/log/journal/b725bed85906490c82960e09f61334e1/system.journal corrupted or uncleanly shut down, renaming and replacing.
[ 5.751510] mc: Linux media interface: v0.10
[ 5.865915] videodev: Linux video capture interface: v2.00
[ 5.938281] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.967640] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 5.967685] [vc_sm_connected_init]: start
[ 5.983041] [vc_sm_connected_init]: installed successfully
[ 6.083266] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.207527] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 6.221196] i2c i2c-22: Added multiplexed i2c bus 0
[ 6.227911] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[ 6.228671] i2c i2c-22: Added multiplexed i2c bus 10
[ 6.261081] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.269370] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.280385] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.296779] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.299382] brcmstb-i2c fef04500.i2c: @97500hz registered in polling mode
[ 6.305381] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.332337] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.339389] rpivid feb10000.codec: Device registered as /dev/video19
[ 6.339699] brcmstb-i2c fef09500.i2c: @97500hz registered in polling mode
[ 6.403740] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 6.475554] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 6.476089] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 6.476163] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 6.476444] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 6.481880] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 6.483867] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 6.483925] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.483950] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.483969] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.484003] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.503022] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 6.503105] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 6.529147] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[ 6.546108] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 6.546179] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 6.560434] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 6.560509] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 6.562118] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[ 6.566348] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[ 6.566420] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[ 6.570603] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[ 6.611359] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[ 6.611419] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 6.611446] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 6.611471] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 6.611508] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 6.672162] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 7.010496] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[ 7.010530] fb0: switching to vc4 from simple
[ 7.016755] Console: switching to colour dummy device 80x25
[ 7.027004] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 7.074868] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[ 7.098352] Registered IR keymap rc-cec
[ 7.110780] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[ 7.196749] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input2
[ 7.287231] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.314034] Registered IR keymap rc-cec
[ 7.319484] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[ 7.322486] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 7.376500] cfg80211: Loaded X.509 cert ā€˜sforshee: 00b28ddf47aef9cea7’
[ 7.408020] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input3
[ 7.412868] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[ 7.806569] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 7.814752] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
[ 7.815300] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[ 7.815756] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.816124] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.816459] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.816765] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.817096] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 7.828817] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 7.843072] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 8.116366] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 8.123982] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov 1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[ 8.139022] usbcore: registered new interface driver brcmfmac
[ 8.152918] Console: switching to colour frame buffer device 240x67
[ 8.152992] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[ 8.428325] dw9807_vcm: loading out-of-tree module taints kernel.
[ 9.253300] 8021q: 802.1Q VLAN Support v1.8
[ 9.379770] uart-pl011 fe201000.serial: no DMA platform data
[ 9.485636] Adding 102396k swap on /var/swap. Priority:-2 extents:1 across:102396k SSFS
[ 9.803899] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 9.854279] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 9.854318] dw9807 10-000c: I2C write CTL fail ret = -110
[ 10.225160] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 10.226985] bcmgenet fd580000.ethernet eth0: Link is Down
[ 10.878233] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 10.878254] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 11.902219] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 11.902240] dw9807 10-000c: I2C write STATUS address fail ret = -110
[ 11.902249] dw9807 10-000c: dw9807_standby I2C failure: -110
[ 12.930213] i2c-bcm2835 fe205000.i2c: i2c transfer timed out
[ 12.930233] dw9807 10-000c: I2C write CTL fail ret = -110
[ 12.930846] arducam_64mp: probe of 10-001a failed with error -5
[ 15.281884] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 17.743921] Bluetooth: Core ver 2.22
[ 17.744041] NET: Registered PF_BLUETOOTH protocol family
[ 17.744049] Bluetooth: HCI device and connection manager initialized
[ 17.744066] Bluetooth: HCI socket layer initialized
[ 17.744075] Bluetooth: L2CAP socket layer initialized
[ 17.744091] Bluetooth: SCO socket layer initialized
[ 17.757682] Bluetooth: HCI UART driver ver 2.3
[ 17.757707] Bluetooth: HCI UART protocol H4 registered
[ 17.757792] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 17.758002] Bluetooth: HCI UART protocol Broadcom registered
[ 18.044705] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 18.044726] Bluetooth: BNEP filters: protocol multicast
[ 18.044769] Bluetooth: BNEP socket layer initialized
[ 18.063200] NET: Registered PF_ALG protocol family
[ 18.175599] Bluetooth: RFCOMM TTY layer initialized
[ 18.175687] Bluetooth: RFCOMM socket layer initialized
[ 18.175703] Bluetooth: RFCOMM ver 1.11
[ 31.710224] cam-dummy-reg: disabling
[ 38.812048] v3d fec00000.v3d: MMU error from client L2T (0) at 0x8941000, pte invalid
@will842
It looks like the camera is not connected properly, can you show me the connection diagram?
You can also try another flexible cable
@Edward
I have run into the same no cameras available issue, I’m not sure what’s going on, please do help me
  1. Where did you get the camera module
    I ordered it from amazon
  2. Model Number of the product
    B0399
  3. Hardware / platform:
    Fresh install of 32 bit bullseye of latest update released 2023, did not chose to update after fresh install
  4. Instructions I have followed :
    How to use arducam_64mp & arducam_64mp FAQ
  5. Problems I am having :
raspberrypi@raspberrypi:~ $ libcamera-still --list-cameras
No cameras available!
6 ) Demesg posted below
  1. Troubleshooting attempts :
    I have clean installed and followed the FAQ and then this thread
  2. What help do I need :
    To get the camera recognized and working
Other details :
cpuinfo
processor	: 0
model name	: ARMv7 Processor rev 3 (v7l)
BogoMIPS	: 126.00
Features	: half thumb fastmult vfp edsp neon vfpv3 tls vfpv4 idiva idivt vfpd32 lpae evtstrm crc32
CPU implementer	: 0x41
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 1
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 2
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
processor	: 3
BogoMIPS	: 126.00
CPU architecture: 7
CPU variant	: 0x0
CPU part	: 0xd08
CPU revision	: 3
Hardware	: BCM2711
Revision	: b03115
Serial		: 1000000083fc83d2
meminfo
MemTotal:        1916908 kB
MemFree:          754976 kB
MemAvailable:     909316 kB
Buffers:            8492 kB
Cached:           437476 kB
SwapCached:            0 kB
Active:           169352 kB
Inactive:         691044 kB
Active(anon):       2376 kB
Inactive(anon):   640568 kB
Active(file):     166976 kB
Inactive(file):    50476 kB
Unevictable:      177620 kB
Mlocked:              16 kB
HighTotal:       1232896 kB
HighFree:         184112 kB
LowTotal:         684012 kB
LowFree:          570864 kB
SwapFree:         101372 kB
Dirty:                72 kB
Writeback:             0 kB
AnonPages:        591936 kB
Mapped:           215224 kB
Shmem:            228516 kB
KReclaimable:      20104 kB
Slab:              45588 kB
SReclaimable:      20104 kB
SUnreclaim:        25484 kB
KernelStack:        3016 kB
PageTables:        16348 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:     1060848 kB
Committed_AS:    3442580 kB
VmallocTotal:     245760 kB
VmallocUsed:        6256 kB
VmallocChunk:          0 kB
Percpu:              448 kB
CmaTotal:         524288 kB
CmaFree:          474972 kB
OS
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
ls /dev/video
raspberrypi@raspberrypi:~ $ ls /dev/video*
dpkg -l | grep libcamera
raspberrypi@raspberrypi:~ $ dpkg -l | grep libcamera
ii  libcamera-apps                       0~git20230309+4def288-1          armhf        libcamera-apps
ii  libcamera-dev:armhf                  0~git20230321+74d023d8-1         armhf        complex camera support library (development files)
ii  libcamera-tools                      0~git20230124+9b860a66-1         armhf        complex camera support library (tools)
ii  libcamera0:armhf                     0~git20230321+74d023d8-1         armhf        complex camera support library
ii  python3-libcamera                    0~git20230302+923f5d70-1         armhf        complex camera support library (Python 3 bindings)
cat /boot/config.txt
raspberrypi@raspberrypi:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
display_auto_detect=1
# Enable DRM VC4 V3D driver
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
libcamera-still -t 1000 -n
raspberrypi@raspberrypi:~ $ libcamera-still -t 1000 -n
[0:30:04.264838067] [1880]  INFO Camera camera_manager.cpp:299 libcamera v0.0.0+4225-74d023d8
I will post dmesg on the next post as I have hit the word limit.
Thanks !
dmesg
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.15.84-v7l+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1613 SMP Thu Jan 5 12:01:26 GMT 2023
[    0.000000] CPU: ARMv7 Processor [410fd083] revision 3 (ARMv7), cr=30c5383d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: Raspberry Pi 4 Model B Rev 1.5
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000000000-0x000000002fffffff]
[    0.000000]   Normal   empty
[    0.000000]   HighMem  [mem 0x0000000030000000-0x000000007fffffff]
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000000000-0x000000003b3fffff]
[    0.000000]   node   0: [mem 0x0000000040000000-0x000000007fffffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000007fffffff]
[    0.000000] percpu: Embedded 16 pages/cpu s35788 r8192 d21556 u65536
[    0.000000] pcpu-alloc: s35788 r8192 d21556 u65536 alloc=16*4096
[    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 503104
[    0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=E4:5F:01:BE:FC:F5 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  console=ttyS0,115200 console=tty1 root=PARTUUID=a3ae6617-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[    0.000000] Unknown kernel command line parameters "splash", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] software IO TLB: mapped [mem 0x0000000009a00000-0x000000000da00000] (64MB)
[    0.000000] Memory: 1390572K/2019328K available (10240K kernel code, 1386K rwdata, 3308K rodata, 2048K init, 591K bss, 104468K reserved, 524288K cma-reserved, 1232896K highmem)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.000000] ftrace: allocating 35518 entries in 105 pages
[    0.000000] ftrace: allocated 105 pages with 4 groups
[    0.000000] trace event string verifier disabled
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7ef00100, parent irq: 25)
[    0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[    0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[    0.000018] Switching to timer-based delay loop, resolution 18ns
[    0.000395] Console: colour dummy device 80x30
[    0.000460] printk: console [tty1] enabled
[    0.000527] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=540000)
[    0.000557] pid_max: default: 32768 minimum: 301
[    0.000702] LSM: Security Framework initializing
[    0.000911] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.000942] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[    0.002538] cgroup: Disabling memory control group subsystem
[    0.002790] CPU: Testing write buffer coherency: ok
[    0.002849] CPU0: Spectre BHB: enabling loop workaround for all CPUs
[    0.003318] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.004841] Setting up static identity map for 0x200000 - 0x20003c
[    0.005041] rcu: Hierarchical SRCU implementation.
[    0.006058] smp: Bringing up secondary CPUs ...
[    0.007270] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.008624] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.009938] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.010100] smp: Brought up 1 node, 4 CPUs
[    0.010123] SMP: Total of 4 processors activated (432.00 BogoMIPS).
[    0.010143] CPU: All CPU(s) started in HYP mode.
[    0.010156] CPU: Virtualization extensions available.
[    0.010964] devtmpfs: initialized
[    0.026904] VFP support v0.3: implementor 41 architecture 3 part 40 variant 8 rev 0
[    0.027131] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.027167] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.044071] pinctrl core: initialized pinctrl subsystem
[    0.045388] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.050104] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[    0.050943] audit: initializing netlink subsys (disabled)
[    0.051208] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[    0.051878] thermal_sys: Registered thermal governor 'step_wise'
[    0.052711] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.052731] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.053165] Serial: AMBA PL011 UART driver
[    0.068711] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[    0.110104] raspberrypi-firmware soc:firmware: Attached to firmware from 2023-01-05T10:46:54, variant start
[    0.120119] raspberrypi-firmware soc:firmware: Firmware hash is 8ba17717fbcedd4c3b6d4bce7e50c7af4155cba9
[    0.181427] Kprobes globally optimized
[    0.187574] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[    0.192310] vgaarb: loaded
[    0.192798] SCSI subsystem initialized
[    0.193048] usbcore: registered new interface driver usbfs
[    0.193122] usbcore: registered new interface driver hub
[    0.193196] usbcore: registered new device driver usb
[    0.193625] usb_phy_generic phy: supply vcc not found, using dummy regulator
[    0.193813] usb_phy_generic phy: dummy supplies not allowed for exclusive requests
[    0.194151] pps_core: LinuxPPS API ver. 1 registered
[    0.194167] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[    0.194195] PTP clock support registered
[    0.195958] clocksource: Switched to clocksource arch_sys_counter
[    0.276727] VFS: Disk quotas dquot_6.6.0
[    0.276840] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    0.277033] FS-Cache: Loaded
[    0.277249] CacheFiles: Loaded
[    0.278433] simple-framebuffer 3e402000.framebuffer: framebuffer at 0x3e402000, 0x7f8000 bytes
[    0.278458] simple-framebuffer 3e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[    0.278996] Console: switching to colour frame buffer device 240x67
[    0.289756] simple-framebuffer 3e402000.framebuffer: fb0: simplefb registered!
[    0.299569] NET: Registered PF_INET protocol family
[    0.299834] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    0.301480] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.301516] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[    0.301541] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[    0.301606] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[    0.301680] TCP: Hash tables configured (established 8192 bind 8192)
[    0.301850] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.301889] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[    0.302157] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.306888] RPC: Registered named UNIX socket transport module.
[    0.306905] RPC: Registered udp transport module.
[    0.306919] RPC: Registered tcp transport module.
[    0.306933] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.306956] PCI: CLS 0 bytes, default 64
[    1.327644] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[    1.351164] Initialise system trusted keyrings
[    1.351478] workingset: timestamp_bits=14 max_order=19 bucket_order=5
[    1.360435] zbud: loaded
[    1.362466] FS-Cache: Netfs 'nfs' registered for caching
[    1.363363] NFS: Registering the id_resolver key type
[    1.363408] Key type id_resolver registered
[    1.363423] Key type id_legacy registered
[    1.363558] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.363575] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.364692] Key type asymmetric registered
[    1.364709] Asymmetric key parser 'x509' registered
[    1.364945] bounce: pool size: 64 pages
[    1.365009] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    1.365239] io scheduler mq-deadline registered
[    1.365256] io scheduler kyber registered
[    1.374559] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[    1.374602] brcm-pcie fd500000.pcie:   No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[    1.374699] brcm-pcie fd500000.pcie:      MEM 0x0600000000..0x063fffffff -> 0x00c0000000
[    1.374793] brcm-pcie fd500000.pcie:   IB MEM 0x0000000000..0x007fffffff -> 0x0400000000
[    1.458059] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[    1.458462] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[    1.458485] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.458507] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[    1.458602] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[    1.458855] pci 0000:00:00.0: PME# supported from D0 D3hot
[    1.462682] PCI: bus0: Fast back to back transfers disabled
[    1.462707] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    1.463083] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[    1.463213] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[    1.463647] pci 0000:01:00.0: PME# supported from D0 D3hot
[    1.467452] PCI: bus1: Fast back to back transfers disabled
[    1.467473] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[    1.467517] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[    1.467543] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[    1.467630] pci 0000:00:00.0: PCI bridge to [bus 01]
[    1.467656] pci 0000:00:00.0:   bridge window [mem 0x600000000-0x6000fffff]
[    1.468087] pcieport 0000:00:00.0: enabling device (0140 -> 0142)
[    1.468328] pcieport 0000:00:00.0: PME: Signaling with IRQ 79
[    1.482846] iproc-rng200 fe104000.rng: hwrng registered
[    1.483238] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[    1.484910] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[    1.498193] brd: module loaded
[    1.508932] loop: module loaded
[    1.509830] Loading iSCSI transport class v2.0-870.
[    1.515272] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[    1.616123] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[    1.617378] usbcore: registered new interface driver r8152
[    1.617469] usbcore: registered new interface driver lan78xx
[    1.617533] usbcore: registered new interface driver smsc95xx
[    1.669406] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.669447] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[    1.675054] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0001e40000000890
[    1.676161] xhci_hcd 0000:01:00.0: xHCI Host Controller
[    1.676188] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[    1.676214] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[    1.676606] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    1.676630] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.676649] usb usb1: Product: xHCI Host Controller
[    1.676666] usb usb1: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[    1.676682] usb usb1: SerialNumber: 0000:01:00.0
[    1.677453] hub 1-0:1.0: USB hub found
[    1.677526] hub 1-0:1.0: 1 port detected
[    1.678567] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    1.678590] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.678608] usb usb2: Product: xHCI Host Controller
[    1.678625] usb usb2: Manufacturer: Linux 5.15.84-v7l+ xhci-hcd
[    1.678642] usb usb2: SerialNumber: 0000:01:00.0
[    1.679370] hub 2-0:1.0: USB hub found
[    1.679468] hub 2-0:1.0: 4 ports detected
[    1.681455] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[    1.681838] dwc_otg: FIQ enabled
[    1.681852] dwc_otg: NAK holdoff enabled
[    1.681865] dwc_otg: FIQ split-transaction FSM enabled
[    1.681882] Module dwc_common_port init
[    1.682380] usbcore: registered new interface driver uas
[    1.682488] usbcore: registered new interface driver usb-storage
[    1.682723] mousedev: PS/2 mouse device common for all mice
[    1.688790] sdhci: Secure Digital Host Controller Interface driver
[    1.688809] sdhci: Copyright(c) Pierre Ossman
[    1.689580] sdhci-pltfm: SDHCI platform and OF driver helper
[    1.693519] ledtrig-cpu: registered to indicate activity on CPUs
[    1.693865] hid: raw HID events driver (C) Jiri Kosina
[    1.694060] usbcore: registered new interface driver usbhid
[    1.694076] usbhid: USB HID core driver
[    1.700751] Initializing XFRM netlink socket
[    1.700797] NET: Registered PF_PACKET protocol family
[    1.700916] Key type dns_resolver registered
[    1.701413] Registering SWP/SWPB emulation handler
[    1.702265] registered taskstats version 1
[    1.702297] Loading compiled-in X.509 certificates
[    1.703132] Key type .fscrypt registered
[    1.703149] Key type fscrypt-provisioning registered
[    1.715849] uart-pl011 fe201000.serial: there is not valid maps for state default
[    1.716215] uart-pl011 fe201000.serial: cts_event_workaround enabled
[    1.716351] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 34, base_baud = 0) is a PL011 rev2
[    1.725794] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[    1.726373] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[    1.727692] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[    1.727714] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[    1.756948] of_cfs_init
[    1.757209] of_cfs_init: OK
[    1.792706] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[    1.793122] Waiting for root device PARTUUID=a3ae6617-02...
[    1.844494] mmc1: new high speed SDIO card at address 0001
[    1.892638] mmc0: new ultra high speed DDR50 SDHC card at address 5048
[    1.893649] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[    1.897437]  mmcblk0: p1 p2
[    1.898014] mmcblk0: mmc0:5048 SD32G 29.7 GiB (quirks 0x00004000)
[    1.919975] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[    1.920067] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[    1.921004] devtmpfs: mounted
[    1.933139] Freeing unused kernel image (initmem) memory: 2048K
[    1.946298] Run /sbin/init as init process
[    1.946316]   with arguments:
[    1.946329]     /sbin/init
[    1.946342]     splash
[    1.946355]   with environment:
[    1.946367]     HOME=/
[    1.946380]     TERM=linux
[    1.966000] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    2.148770] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[    2.148805] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    2.148826] usb 1-1: Product: USB2.0 Hub
[    2.151657] hub 1-1:1.0: USB hub found
[    2.151944] hub 1-1:1.0: 4 ports detected
[    2.256620] systemd[1]: System time before build time, advancing clock.
[    2.460153] NET: Registered PF_INET6 protocol family
[    2.462004] Segment Routing with IPv6
[    2.462050] In-situ OAM (IOAM) with IPv6
[    2.485999] usb 1-1.1: new low-speed USB device number 3 using xhci_hcd
[    2.542824] systemd[1]: systemd 247.3-7+rpi1+deb11u1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[    2.543718] systemd[1]: Detected architecture arm.
[    2.549497] systemd[1]: Set hostname to <raspberrypi>.
[    2.626642] usb 1-1.1: New USB device found, idVendor=1a2c, idProduct=2124, bcdDevice= 1.10
[    2.626683] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    2.626716] usb 1-1.1: Product: USB Keyboard
[    2.626734] usb 1-1.1: Manufacturer: SEM
[    2.639313] input: SEM USB Keyboard as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.0/0003:1A2C:2124.0001/input/input0
[    2.706993] hid-generic 0003:1A2C:2124.0001: input,hidraw0: USB HID v1.10 Keyboard [SEM USB Keyboard] on usb-0000:01:00.0-1.1/input0
[    2.714913] input: SEM USB Keyboard Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1A2C:2124.0002/input/input1
[    2.786937] input: SEM USB Keyboard System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.1/1-1.1:1.1/0003:1A2C:2124.0002/input/input2
[    2.787325] hid-generic 0003:1A2C:2124.0002: input,hidraw1: USB HID v1.10 Device [SEM USB Keyboard] on usb-0000:01:00.0-1.1/input1
[    2.896015] usb 1-1.3: new full-speed USB device number 4 using xhci_hcd
[    3.044549] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52b, bcdDevice=24.07
[    3.044584] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    3.044605] usb 1-1.3: Product: USB Receiver
[    3.044622] usb 1-1.3: Manufacturer: Logitech
[    3.057054] input: Logitech USB Receiver as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C52B.0003/input/input3
[    3.127108] hid-generic 0003:046D:C52B.0003: input,hidraw2: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input0
[    3.135866] input: Logitech USB Receiver Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input4
[    3.136491] input: Logitech USB Receiver Consumer Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input5
[    3.206364] input: Logitech USB Receiver System Control as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52B.0004/input/input6
[    3.206862] hid-generic 0003:046D:C52B.0004: input,hiddev96,hidraw3: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input1
[    3.214301] hid-generic 0003:046D:C52B.0005: hiddev97,hidraw4: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[    3.264603] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
[    3.454616] systemd[1]: Queued start job for default target Graphical Interface.
[    3.460470] systemd[1]: Created slice system-getty.slice.
[    3.461829] systemd[1]: Created slice system-modprobe.slice.
[    3.462847] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[    3.463713] systemd[1]: Created slice User and Session Slice.
[    3.464236] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[    3.465419] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[    3.466619] systemd[1]: Reached target Slices.
[    3.466837] systemd[1]: Reached target Swap.
[    3.470474] systemd[1]: Listening on Syslog Socket.
[    3.471292] systemd[1]: Listening on fsck to fsckd communication Socket.
[    3.471711] systemd[1]: Listening on initctl Compatibility Named Pipe.
[    3.472976] systemd[1]: Listening on Journal Audit Socket.
[    3.473792] systemd[1]: Listening on Journal Socket (/dev/log).
[    3.474787] systemd[1]: Listening on Journal Socket.
[    3.479975] systemd[1]: Listening on udev Control Socket.
[    3.480891] systemd[1]: Listening on udev Kernel Socket.
[    3.481860] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[    3.487493] systemd[1]: Mounting POSIX Message Queue File System...
[    3.493705] systemd[1]: Mounting RPC Pipe File System...
[    3.501042] systemd[1]: Mounting Kernel Debug File System...
[    3.508568] systemd[1]: Mounting Kernel Trace File System...
[    3.509321] systemd[1]: Condition check resulted in Kernel Module supporting RPCSEC_GSS being skipped.
[    3.520438] systemd[1]: Starting Restore / save the current clock...
[    3.527965] systemd[1]: Starting Set the console keyboard layout...
[    3.537469] systemd[1]: Starting Create list of static device nodes for the current kernel...
[    3.546557] systemd[1]: Starting Load Kernel Module configfs...
[    3.555099] systemd[1]: Starting Load Kernel Module drm...
[    3.567198] systemd[1]: Starting Load Kernel Module fuse...
[    3.570922] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[    3.578178] systemd[1]: Starting File System Check on Root Device...
[    3.606181] systemd[1]: Starting Journal Service...
[    3.637786] systemd[1]: Starting Load Kernel Modules...
[    3.651847] systemd[1]: Starting Coldplug All udev Devices...
[    3.671877] fuse: init (API version 7.34)
[    3.682235] systemd[1]: Mounted POSIX Message Queue File System.
[    3.683244] systemd[1]: Mounted RPC Pipe File System.
[    3.684159] systemd[1]: Mounted Kernel Debug File System.
[    3.685056] systemd[1]: Mounted Kernel Trace File System.
[    3.690365] systemd[1]: Finished Restore / save the current clock.
[    3.693608] systemd[1]: Finished Create list of static device nodes for the current kernel.
[    3.695884] systemd[1]: [email protected]: Succeeded.
[    3.699417] systemd[1]: Finished Load Kernel Module configfs.
[    3.703166] systemd[1]: [email protected]: Succeeded.
[    3.704636] systemd[1]: Finished Load Kernel Module fuse.
[    3.713324] systemd[1]: Mounting FUSE Control File System...
[    3.720720] systemd[1]: Mounting Kernel Configuration File System...
[    3.739471] systemd[1]: Started File System Check Daemon to report status.
[    3.767210] i2c_dev: i2c /dev entries driver
[    3.771289] systemd[1]: Mounted FUSE Control File System.
[    3.772083] systemd[1]: Mounted Kernel Configuration File System.
[    3.774589] systemd[1]: Finished Load Kernel Modules.
[    3.791984] systemd[1]: Starting Apply Kernel Variables...
[    3.851937] systemd[1]: [email protected]: Succeeded.
[    3.854869] systemd[1]: Finished Load Kernel Module drm.
[    3.886886] systemd[1]: Finished Apply Kernel Variables.
[    3.891366] systemd[1]: Finished File System Check on Root Device.
[    3.907208] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.050150] systemd[1]: Started Journal Service.
[    4.110711] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null). Quota mode: none.
[    4.185609] systemd-journald[142]: Received client request to flush runtime journal.
[    4.195585] systemd-journald[142]: File /var/log/journal/b0200ab30387418f9d911ba3d44c153b/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    5.428056] mc: Linux media interface: v0.10
[    5.630350] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[    5.736609] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[    5.738980] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[    5.739016] [vc_sm_connected_init]: start
[    5.766455] bcm2835_audio bcm2835_audio: card created with 8 channels
[    5.826195] [vc_sm_connected_init]: installed successfully
[    5.965139] videodev: Linux video capture interface: v2.00
[    6.225706] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.253195] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[    6.263007] brcmstb-i2c fef04500.i2c:  @97500hz registered in polling mode
[    6.264823] brcmstb-i2c fef09500.i2c:  @97500hz registered in polling mode
[    6.299768] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[    6.302307] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[    6.337549] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[    6.376446] rpivid feb10000.codec: Device registered as /dev/video19
[    6.380885] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[    6.380946] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[    6.420859] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[    6.420919] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[    6.443508] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[    6.443566] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[    6.455198] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[    6.455265] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[    6.463825] bcm2835-codec bcm2835-codec: Device registered as /dev/video31
[    6.463891] bcm2835-codec bcm2835-codec: Loaded V4L2 encode_image
[    6.475670] i2c i2c-22: Added multiplexed i2c bus 0
[    6.479571] i2c 10-001a: Fixing up cyclic dependency with fe801000.csi
[    6.479979] i2c i2c-22: Added multiplexed i2c bus 10
[    6.527091] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[    6.626131] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[    6.626946] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[    6.627476] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[    6.627829] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[    6.627862] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.627887] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.627910] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.627932] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.698946] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    6.719658] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video20
[    6.722560] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video21
[    6.746083] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video22
[    6.746661] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video23
[    6.746695] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[    6.746729] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[    6.746753] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[    6.746775] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[    6.747233] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[    6.758241] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    6.780583] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
[    7.122884] brcmfmac: F1 signature read @0x18000000=0x15264345
[    7.138165] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.197431] usbcore: registered new interface driver brcmfmac
[    7.459881] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[    7.466271] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Nov  1 2021 00:37:25 version 7.45.241 (1a2f2fa CY) FWID 01-703fd60
[    7.663286] uart-pl011 fe201000.serial: no DMA platform data
[    7.728204] checking generic (3e402000 7f8000) vs hw (0 ffffffffffffffff)
[    7.728238] fb0: switching to vc4 from simple
[    7.745514] Console: switching to colour dummy device 80x30
[    7.745890] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[    7.790948] vc4-drm gpu: bound fe400000.hvs (ops vc4_hvs_ops [vc4])
[    7.811524] Registered IR keymap rc-cec
[    7.814571] 8021q: 802.1Q VLAN Support v1.8
[    7.834939] rc rc0: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0
[    7.835681] input: vc4 as /devices/platform/soc/fef00700.hdmi/rc/rc0/input8
[    7.921311] logitech-djreceiver 0003:046D:C52B.0005: hiddev96,hidraw2: USB HID v1.11 Device [Logitech USB Receiver] on usb-0000:01:00.0-1.3/input2
[    7.984071] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[    7.985570] bcmgenet fd580000.ethernet eth0: Link is Down
[    8.026521] vc4-drm gpu: bound fef00700.hdmi (ops vc4_hdmi_ops [vc4])
[    8.081818] input: Logitech Wireless Device PID:4055 Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0005/0003:046D:4055.0006/input/input10
[    8.082430] hid-generic 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Device PID:4055] on usb-0000:01:00.0-1.3/input2:1
[    8.119318] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:102396k SSFS
[    8.150545] Registered IR keymap rc-cec
[    8.150758] rc rc1: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1
[    8.151027] input: vc4 as /devices/platform/soc/fef05700.hdmi/rc/rc1/input9
[    8.726618] vc4-drm gpu: bound fef05700.hdmi (ops vc4_hdmi_ops [vc4])
continued
[    8.727184] vc4-drm gpu: bound fe004000.txp (ops vc4_txp_ops [vc4])
[    8.728586] vc4-drm gpu: bound fe206000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.730424] vc4-drm gpu: bound fe207000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.731347] vc4-drm gpu: bound fe20a000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.731969] vc4-drm gpu: bound fe216000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.732452] vc4-drm gpu: bound fec12000.pixelvalve (ops vc4_crtc_ops [vc4])
[    8.982763] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[    9.261784] Console: switching to colour frame buffer device 240x67
[    9.261888] vc4-drm gpu: [drm] fb0: vc4drmfb frame buffer device
[   10.093208] arducam_64mp: loading out-of-tree module taints kernel.
[   10.106398] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[   10.114932] arducam_64mp: probe of 10-001a failed with error -5
[   10.213550] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[   10.257976] input: Logitech Wireless Mouse as /devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3:1.2/0003:046D:C52B.0005/0003:046D:4055.0006/input/input14
[   10.258275] logitech-hidpp-device 0003:046D:4055.0006: input,hidraw3: USB HID v1.11 Mouse [Logitech Wireless Mouse] on usb-0000:01:00.0-1.3/input2:1
[   15.375134] Bluetooth: Core ver 2.22
[   15.375213] NET: Registered PF_BLUETOOTH protocol family
[   15.375220] Bluetooth: HCI device and connection manager initialized
[   15.375237] Bluetooth: HCI socket layer initialized
[   15.375248] Bluetooth: L2CAP socket layer initialized
[   15.375264] Bluetooth: SCO socket layer initialized
[   15.422127] Bluetooth: HCI UART driver ver 2.3
[   15.422142] Bluetooth: HCI UART protocol H4 registered
[   15.422205] Bluetooth: HCI UART protocol Three-wire (H5) registered
[   15.422357] Bluetooth: HCI UART protocol Broadcom registered
[   15.625264] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[   15.775728] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   15.775743] Bluetooth: BNEP filters: protocol multicast
[   15.775756] Bluetooth: BNEP socket layer initialized
[   15.796318] NET: Registered PF_ALG protocol family
[   15.832549] cryptd: max_cpu_qlen set to 1000
[   15.954818] Bluetooth: RFCOMM TTY layer initialized
[   15.954851] Bluetooth: RFCOMM socket layer initialized
[   15.954883] Bluetooth: RFCOMM ver 1.11
[   17.201567] ICMPv6: process `dhcpcd' is using deprecated sysctl (syscall) net.ipv6.neigh.wlan0.retrans_time - use net.ipv6.neigh.wlan0.retrans_time_ms instead
[   25.276246] logitech-hidpp-device 0003:046D:4055.0006: HID++ 4.5 device connected.
[   31.836026] cam-dummy-reg: disabling
[  737.948310] ieee80211 phy0: brcmf_run_escan: error (-52)
[  737.948331] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[  917.951027] ieee80211 phy0: brcmf_run_escan: error (-52)
[  917.951040] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[ 1097.954295] ieee80211 phy0: brcmf_run_escan: error (-52)
[ 1097.954308] ieee80211 phy0: brcmf_cfg80211_scan: scan error (-52)
[ 1739.199034] v3d fec00000.v3d: MMU error from client CLE (4) at 0xcb61000, pte invalid
pls change it to ā€œdtoverlay=arducam-64mpā€
then reboot and try it again.
Please show me the hardware connection diagram at the same time.
