I’m getting the same errors in dmesg as before.
Here is the wiring
Just to confirm your current status, can you provide this information again?
uname -a
dmesg | grep arducam
raspberrypi@raspberrypi:~ $ uname -a
Linux raspberrypi 5.15.84-v7l+ #1613 SMP Thu Jan 5 12:01:26 GMT 2023 armv7l GNU/Linux
and
[ 10.078172] arducam_64mp: loading out-of-tree module taints kernel.
[ 10.088987] arducam_64mp 10-001a: failed to read chip id 4136, with error -5
[ 10.089821] arducam_64mp: probe of 10-001a failed with error -5
I also note this seems very similar to
In which you had responded. Did the problem for the user linked above get solved? What was the issue?
In this case it is possible that the flex cable is the problem and the camera is not being recognized.
0x0c is the address of the motor, the motor loads correctly, but the camera doesn’t read the i2c address, which is weird.
I would like to please make another try:
Unplug the flex cable all over and reinstall it once.
Please send a clearer picture of the following, I want to see the circuit.
Where are you seeing the 0x0c motor address? But yeah I’ve tried removing the cable and putting it back from both the sockets to no avail.
I hope this image is clear enough
I saw in another thread that you have more detailed information.
0x0c is mentioned in it
When I zoom in on the picture you gave, I can’t see the details.
tx, very clearly
I discussed it with my team just now, and it’s really weird.
Now there are three possibilities:
If you can’t get the test I’m appealing, you can try an exchange or return it
I’ll try these tests, I’ll head out now and get a cheapo camera and spare wire
Thank you for your efforts.
Hi. I am getting the no cameras available issue. I am using arducam 64mp camera on Raspberry Pi 3 Model B.
Can someone help me figure this out. I tried following the solutions above but they are not working.
This was the cause of the problem for me. This script modifies /boot/config.txt and I’m on Bookworm, which specifically ignores this file and uses /boot/firmware/config.txt. Too lazy/not knowledgeable enough about shell scripting to make a PR but whoever maintains that can add a special condition for bookworm.
