Hi everyone, I’ve got a UCTRONICS B0333 (IMX462) Arducam Pivariety camera on a Raspberry Pi 4 Model B Rev 1.1 running Raspbian bullseye 6.1.21-v8+. I followed the quick start guide at Quick Start Guide - Arducam Wiki but I’ve never got it to work. It just isn’t detected. Here’s what dmesg shows when I grep for the camera:
Thanks for the dmesg output. That ‘pivariety_read: Reading register 0x103 failed’ line means the probe is failing at the I2C read stage, so before we change anything it’s best to capture a full camera bug report. Could you run the bug report tool after a reboot and share the file?
Thanks, I’ve looked at the report. Let’s try simplifying the dtoverlay. The media-controller=0 parameter can cause this kind of detection problem on these boards. Edit /boot/config.txt:
Tried that. Changed the line in /boot/config.txt from dtoverlay=arducam-pivariety,media-controller=0 to dtoverlay=arducam-pivariety and rebooted. Still not detected, same probe failure in dmesg. I’ve attached a fresh bug report after the change.
Thanks for the new report. Since the software side looks unchanged, can you post a couple of photos of the physical connection? One of the Raspberry Pi end and one of the camera module end, so we can check the cable orientation.
Thanks, that’s enough to spot it. The cable is connected the wrong way around (reversed). Please reverse/flip the wire and try again. After that, check dmesg for the arducam_pivariety probe.
