RobotShop -
OV9281 1MP Global Shutter Camera for Raspberry Pi -
Raspberry Pi 3 -
Setting up the camera for use (was succesful):
OV9281 1MP Global Shutter Camera for Raspberry Pi - Arducam -
I need to set the exposure time to a certain level (preferably short) and keep it there. I tried observing the camera stream in a window with a simple Python-OpenCV script and then in the command line enteringv4l2-ctl -c exposure = xxx, but the values have no influence on the image. Also, values entered below 427 just make the image go black.
Adding things likecam.set(cv2.CAP_PROP_EXPOSURE, xx)to the Python script
also has no influence, when I read out those parameters it always returns -1.0. -
see point 5 -
I need to set the exposure time to a fixed value and keep it there, the shorter the better. Ideally, I get a rough idea to which exposure time in µs or ms the set value corresponds, but that is secondary.
So, after playing around some more, I found out that I had to activate Legacy Camera interface because my Raspberry Pi OS doesn’t show it anymore in the preference settings in the GUI. Although I could also receive and save camera images before, now the exposure settings work flawlessly.
What would still be good to know, what is the actual resulting exposure time? I can set with v4l2-ctl -c exposure = xxx values between 4 and 885, but I have no idea what that is in milliseconds. Is there any way to calculate this?
