Having issues setting exposure value using v4l2-ctl on OV9281-B0225 Rev. B (1MP OV9281 Mono Global Shutter MIPI Camera Module with M12 Mount lens for Raspberry Pi - Arducam) with Pi Zero 2W and RasPi OS lite over SSH.
When exposure is changed using “v4l2-ctl --set-ctrl exposure=[VALUE]” no change in image brightness is noted. Further, when the value is set less than 430 (range should be 4-885) the image is blank. Tests have been performed with legacy camera mode on and off (see Set exposure of OV9281 camera) with no difference.
Uctronics - Model number of the product(s).
OV9281-B0225 - What hardware/platform were you working on?
RPI Zero 2W - Instructions you have followed. (link/manual/etc.)
Wiki install instructions on Arducam website (OV9281 1MP Global Shutter Camera for Raspberry Pi - Arducam ) - Problems you were having.
Exposure setting in v4l2 driver does not have an effect, and produces black image for values less than 430. - The dmesg log from your hardware.
Best way to attach? - Troubleshooting attempts you’ve made.
Testing various values, setting legacy camera mode on and off. - What help do you need?
Need assistance configuring exposure setting so it can be set correctly. Thanks!
