Rpicam camera timeout using CSI-to-HDMI adapter with Raspberry Pi 5 and Camera Module 3
Hi everyone, hoping someone here can help me figure this out. I recently got the CSI-to-HDMI Adapter Set for RPi cameras (the pack of 2) and I’m trying to get it working with my setup.
Hardware:
  • Raspberry Pi 5
  • Raspberry Pi Camera Module 3
  • CSI-to-HDMI adapter set (both ends connected)
  • 1.5 meter HDMI cable running between the two adapter boards
When I try to use rpicam, I get this error:
error dequeue timer of 100000.00us has expired!. camera frontend has timed out and I can't use camera.
The weird thing is, if I ditch the adapter set and connect the camera directly to the Pi using a normal CSI ribbon cable, everything works perfectly. So the camera itself is fine, and the Pi is fine — the issue seems to be somewhere in the adapter + HDMI cable path.
Has anyone run into this timeout error with these adapters? Is there something I’m missing in the setup, or could the HDMI cable be causing problems?
Thanks for the detailed report. That timeout error is usually a sign that the CSI signal isn’t making it through cleanly. Since the camera works fine with a direct CSI cable, you’ve already narrowed it down to the adapter set path — good troubleshooting there.
Can you confirm the exact length of the HDMI cable you’re using between the two adapter boards? Also, do you know the cable spec (e.g., standard HDMI, high-speed, etc.)? HDMI cables aren’t all equal when it comes to carrying the CSI differential signals over these adapters.
The HDMI cable is 1.5 meters long. As for specs, honestly I’m not entirely sure — it’s just a regular HDMI cable I had lying around. Nothing fancy, probably whatever came with an old monitor or something. Could that really be the culprit?
It absolutely could be. The CSI-to-HDMI adapter boards repurpose the HDMI cable’s twisted pairs to carry the camera’s MIPI CSI signals, and not all HDMI cables are built the same internally. Poor shielding, high attenuation, or inconsistent impedance on the differential pairs can degrade the signal enough that the Pi’s CSI receiver can’t maintain a stable link — which is exactly what that dequeue timeout suggests.
1.5 meters isn’t crazy long, but if the cable itself is marginal or damaged, it’d cause exactly this.
Could you try swapping in a different HDMI cable — ideally one that’s known to be good quality or at least a shorter one — and test again? That’ll help us rule out (or confirm) a bad cable before digging deeper.
