Pi 5 + OV9281 through CSI-to-HDMI extender: frontend timeout
I’m trying to extend a Waveshare OV9281-120 (1MP global shutter, mono, 2-lane) from a Raspberry Pi 5 using the Arducam CSI-to-HDMI extension module pair (B0091, board UC-392). The camera is detected through the extender, but no frames ever arrive.
Hardware:
  • Raspberry Pi 5 (4GB), Raspberry Pi OS, libcamera v0.7.2+rpt20260817
  • Waveshare OV9281-120
  • Arducam CSI-to-HDMI extender pair (B0091 / UC-392)
  • Pi side: 22→15 pin FFC (the Waveshare one that works when connecting the camera directly)
  • Camera side: 15→15 pin 60 mm FFC included with the Arducam kit
  • HDMI: 3 m, HDMI 1.4 High Speed, shielded (tried two different 3 m cables, same result)
config.txt:
camera_auto_detect=0
dtoverlay=ov9281,cam0
dtoverlay=ov9281,cam1
What works:
  • Camera connected directly to the Pi 5 (no extender): rpicam-still captures fine.
  • Through the extender, after a cold boot, the sensor is detected over I2C:
rpicam-hello --list-cameras
0 : ov9281 [1280x800 10-bit MONO] (/base/axi/pcie@1000120000/rp1/i2c@80000/ov9281@60)
(with nothing connected I correctly get “No cameras available!”, so this is not a stale probe)
What fails:
  • Any streaming through the extender, at any mode/framerate (e.g. 640x400 @ 30 fps):
rpicam-hello -n -t 20000 --width 640 --height 400 --framerate 30
which gives
  WARN V4L2 v4l2_videodevice.cpp:2096 /dev/video4[13:cap]: Dequeue timer of 1000000.00us has expired!
  ERROR RPI pipeline_base.cpp:1371 Camera frontend has timed out!
(repeats every ~1 s)
  • dmesg shows only:
    rp1-cfe 1f00128000.csi: Using a link rate of 800 Mbps
    (repeated on every restart) — no CRC/ECC or other CSI errors at all.
So I2C passes through the extender, but the CFE apparently never receives a single valid packet.
Similar reports:
These describe a similar problem (sensor detected, but frontend timeout through the extender). The suggested cause there seems to be HDMI cable quality, but in my case I’ve tried two different 3 m cables with exactly the same result, and there are no CRC/ECC errors at all, so I’m not sure the cable is the whole story.
Has anyone got the OV9281 (or another non-official sensor) working on a Pi 5 through the B0091 / UC-392 extender?
Or should I rather switch to a camera that this module officially supports (e.g. Raspberry Pi Camera Module V2 or V3, or one of Arducam’s own modules)?
Thanks!
Thanks for the detailed information and troubleshooting results.
Unfortunately, the B0091 / UC-392 CSI-to-HDMI extension kit is not compatible with the OV9281 sensor .
Although the camera can be detected over I2C through the extender, this does not guarantee that the MIPI CSI-2 video stream can be transmitted successfully. This explains why the camera is detected but no frames are received.
Since this is a compatibility limitation, changing the HDMI cable or adjusting the camera configuration is unlikely to resolve the issue.
We recommend switching to a camera module that is officially supported by the B0091 extension kit.
