I had a similar problem
64MP Hawkeye
Raspberry pi 5 4GB
fresh RPI OS bookworm Debian 1:6.6.20-1+rpt1 (2024-03-07) aarch64
install according all to Quick Start - Arducam Wiki
Step 1. Download the bash scripts
Step 2. Install libcamera
Step 3. Install libcamera-apps
Step 4. Modify .Config file
sudo nano /boot/firmware/config.txt
#Find the line: [all], add the following item under it:
dtoverlay=arducam-64mp
#Save and reboot.
Problem:
libcamera-hello
error
[0:00:31.428693980] [1981] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+246-9fb4698e-dirty (2024-02-27T06:28:07+00:00)
[0:00:31.436967017] [1984] INFO RPI pisp.cpp:662 libpisp version v1.0.4 6e3a53d137f4 14-02-2024 (14:00:12)
[0:00:31.437900166] [1984] WARN CameraSensorProperties camera_sensor_properties.cpp:274 No static properties available for 'arducam_64mp'
[0:00:31.437911128] [1984] WARN CameraSensorProperties camera_sensor_properties.cpp:276 Please consider updating the camera sensor properties database
[0:00:31.443711277] [1984] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam_64mp.json' not found for IPA module 'rpi/pisp'
[0:00:31.459629721] [1984] ERROR RPI pipeline_base.cpp:825 Failed to load a suitable IPA library
[0:00:31.459704277] [1984] ERROR RPI pisp.cpp:890 Failed to register camera arducam_64mp 4-001a: -22
Solution is to manually install package that left after installation:
sudo dpkg -i libcamera-ipa_0.2.0+rpt20240227-1_arm64.deb
Result:
libcamera-hello
works:
[0:16:30.002114126] [2233] INFO Camera camera_manager.cpp:284 libcamera v0.1.0+246-9fb4698e-dirty (2024-02-27T06:28:07+00:00)
[0:16:30.010200866] [2236] INFO RPI pisp.cpp:662 libpisp version v1.0.4 6e3a53d137f4 14-02-2024 (14:00:12)
[0:16:30.011122099] [2236] WARN CameraSensorProperties camera_sensor_properties.cpp:274 No static properties available for 'arducam_64mp'
[0:16:30.011132766] [2236] WARN CameraSensorProperties camera_sensor_properties.cpp:276 Please consider updating the camera sensor properties database
[0:16:30.038240263] [2236] INFO RPI pisp.cpp:1122 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a to CFE device /dev/media1 and ISP device /dev/media0 using PiSP variant BCM2712_C0
Made X/EGL preview window
Mode selection for 4096:3074:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 11507
SRGGB10_CSI2P,1920x1080/0 - Score: 9506.99
SRGGB10_CSI2P,2312x1736/0 - Score: 7246.01
SRGGB10_CSI2P,3840x2160/0 - Score: 3506.99
SRGGB10_CSI2P,4624x3472/0 - Score: 1233.51
SRGGB10_CSI2P,8000x6000/0 - Score: 2707.83
SRGGB10_CSI2P,9152x6944/0 - Score: 3274.98
Stream configuration adjusted
[0:16:30.425931073] [2233] INFO Camera camera.cpp:1183 configuring streams: (0) 4096x3074-YUV420 (1) 4624x3472-RGGB16_PISP_COMP1
[0:16:30.426047799] [2236] INFO RPI pisp.cpp:1406 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/arducam_64mp@1a - Selected sensor format: 4624x3472-SRGGB10_1X10 - Selected CFE format: 4624x3472-PC1R
