Raspberry Pi 5 and Arducams
Progress report:
Well I tried a bunch of tutorials ab installing desktops with my lite version of bookworm, and none of them worked, like LXDE, plasma, etc. so I just Audi purged them. Even ran a command like install ui-mods, but it upgraded my os to the full version of bookworm? Ended up “sudo purge”ing all of them. Though strangely my boot up screen says bookworm 64 bit OS now, instead of it say “lite” like it used to. Thankfully the camera commands still work with libcamera. I can like you to the vids I watched and followed if you’re curious.
Do you happen to know a desktop I can install that’ll be compatible with bookworm lite? One you know works.
Also I tried other YouTube tutorials streaming the livestream to media players like VLC, but they didn’t work. Again, I can like you to the vids I watched and followed if you’re curious.
Thankfully im learning some python and a bit of html on this little excursion, though frustrating.
If you have any sure fire tutorials I can follow on anything pi 5 related, please let me know. I yearning for an inkling of success atm. It’s a bit of a chip on my shoulder :c
FYI for dual cam on a pi5, I tested out trying to take photos simultaneously, and you can!
My code is here:
but the max resolution is
4624, 3472
above this at the next step of 8000x6000 it throws errors (im guessing cuz some buffers fill up or something)
Also note that the photos are just KINDA simultaneously, you can see they are off by about 0.28 seconds
And this lag actually gets smaller if you use a smaller resolution.
at 3840x2160 resolution it is just 0.1 seconds different
at 1920x1080 the difference is only 0.03 seconds
so cool stuff!
the max res for simultaneous capture is 7445x6000
