Hey, i recently got my Kickstarter Arducam Cameras (quad synchronized and a single one).
i got the singular camera working rather fast and everything went smooth, but i have Problems with the quad camera hat.
this picture took 3 minutes, i connected everything together and checked all the ribbon cables. what am i doing wrong?
[0:00:50.874265475] [1126] INFO Camera camera_manager.cpp:293 libcamera v0.0.0+3416-179ef58c
[0:00:50.892722960] [1127] WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'imx519'
[0:00:50.892776916] [1127] WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:00:50.892805505] [1127] ERROR CameraSensor camera_sensor.cpp:551 'imx519 10-001a': Camera sensor does not support test pattern modes.
[0:00:50.911187739] [1127] WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[0:00:50.911914165] [1127] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:00:50.912153042] [1127] INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media0 and ISP device /dev/media2
[0:00:50.912870005] [1126] INFO Camera camera.cpp:1028 configuring streams: (0) 2328x1748-YUV420
[0:00:50.913187946] [1127] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:00:50.942235313] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Saturation = 1.000000
[0:00:50.942339855] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Contrast = 1.000000
[0:00:50.942370907] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Brightness = 0.000000
[0:00:50.942399884] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AwbMode = 0
[0:00:50.942428677] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Sharpness = 0.000000
[0:00:50.942457210] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: ExposureValue = 0.000000
[0:00:50.942507241] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AeExposureMode = 0
[0:00:50.942534682] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: FrameDurationLimits = [ 33333, 33333 ]
[0:00:50.942569529] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AeMeteringMode = 0
[0:00:50.942595267] [1132] INFO IPARPI raspberrypi.cpp:666 Request ctrl: NoiseReductionMode = 0
[0:01:46.853115490] [1126] INFO Camera camera.cpp:1028 configuring streams: (0) 4656x3496-YUV420 (1) 4656x3496-SRGGB10_CSI2P
[0:01:46.853751247] [1127] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 4656x3496-SRGGB10_1X10 - Selected unicam format: 4656x3496-pRAA
[0:01:46.983169281] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Saturation = 1.000000
[0:01:46.983266873] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Contrast = 1.000000
[0:01:46.983297669] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Brightness = 0.000000
[0:01:46.983326558] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AwbMode = 0
[0:01:46.983354743] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: Sharpness = 0.000000
[0:01:46.983382540] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: ExposureValue = 0.000000
[0:01:46.983411780] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AeExposureMode = 0
[0:01:46.983439021] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: FrameDurationLimits = [ 100, 1000000000 ]
[0:01:46.983471447] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: AeMeteringMode = 0
[0:01:46.983497576] [1508] INFO IPARPI raspberrypi.cpp:666 Request ctrl: NoiseReductionMode = 0
Still capture image received
real 3m13,345s
user 0m0,676s
sys 0m0,381s
