Wow! a lot of info in here, I see there is an error in the imx519 chip detection near the end of the output:
pi@raspberrypi:~ $ dmesg
[ 0.000000] Linux version 5.10.92-v7+ (dom@buildbot) (arm-linux-gnueabihf-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1514 SMP Mon Jan 17 17:36:39 GMT 2022
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi Zero 2 W Rev 1.0
[ 0.000000] Reserved memory: created CMA memory pool at 0x0bc00000, size 256 MiB
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Normal empty
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x000000001bffffff]
[ 0.000000] On node 0 totalpages: 114688
[ 0.000000] DMA zone: 1008 pages used for memmap
[ 0.000000] DMA zone: 114688 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 20 pages/cpu s50828 r8192 d22900 u81920
[ 0.000000] pcpu-alloc: s50828 r8192 d22900 u81920 alloc=20*4096
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 113680
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 video=HDMI-A-1:1920x1080M@60 smsc95xx.macaddr=B8:27:EB:AD:FB:47 vc_mem.mem_base=0x1ec00000 vc_mem.mem_size=0x20000000 console=ttyS0,115200 console=tty1 root=PARTUUID=825d44bc-02 rootfstype=ext4 fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 174692K/458752K available (10240K kernel code, 1312K rwdata, 2952K rodata, 1024K init, 862K bss, 21916K reserved, 262144K cma-reserved)
[ 0.000000] ftrace: allocating 32087 entries in 95 pages
[ 0.000000] ftrace: allocated 95 pages with 6 groups
[ 0.000000] random: get_random_bytes called from start_kernel+0x3ac/0x580 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000021] Switching to timer-based delay loop, resolution 52ns
[ 0.000318] Console: colour dummy device 80x30
[ 0.000390] printk: console [tty1] enabled
[ 0.000441] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000470] pid_max: default: 32768 minimum: 301
[ 0.000660] LSM: Security Framework initializing
[ 0.000899] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000920] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.002370] cgroup: Disabling memory control group subsystem
[ 0.002652] CPU: Testing write buffer coherency: ok
[ 0.003149] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004364] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004550] rcu: Hierarchical SRCU implementation.
[ 0.005469] smp: Bringing up secondary CPUs ...
[ 0.006650] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007948] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009138] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009294] smp: Brought up 1 node, 4 CPUs
[ 0.009317] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009329] CPU: All CPU(s) started in HYP mode.
[ 0.009340] CPU: Virtualization extensions available.
[ 0.010283] devtmpfs: initialized
[ 0.028654] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.028899] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.028929] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.039931] pinctrl core: initialized pinctrl subsystem
[ 0.041287] NET: Registered protocol family 16
[ 0.045835] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.051726] audit: initializing netlink subsys (disabled)
[ 0.052039] audit: type=2000 audit(0.050:1): state=initialized audit_enabled=0 res=1
[ 0.052650] thermal_sys: Registered thermal governor 'step_wise'
[ 0.053814] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.053830] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.054169] Serial: AMBA PL011 UART driver
[ 0.081287] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.100194] raspberrypi-firmware soc:firmware: Attached to firmware from 2022-01-20T13:58:22, variant start
[ 0.110202] raspberrypi-firmware soc:firmware: Firmware hash is bd88f66f8952d34e4e0613a85c7a6d3da49e13e2
[ 0.154757] Kprobes globally optimized
[ 0.160040] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.162508] SCSI subsystem initialized
[ 0.162782] usbcore: registered new interface driver usbfs
[ 0.162850] usbcore: registered new interface driver hub
[ 0.162926] usbcore: registered new device driver usb
[ 0.165085] clocksource: Switched to clocksource arch_sys_counter
[ 1.886894] VFS: Disk quotas dquot_6.6.0
[ 1.887017] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.887237] FS-Cache: Loaded
[ 1.887508] CacheFiles: Loaded
[ 1.888595] simple-framebuffer 1e402000.framebuffer: framebuffer at 0x1e402000, 0x7f8000 bytes, mapped to 0x(ptrval)
[ 1.888615] simple-framebuffer 1e402000.framebuffer: format=a8r8g8b8, mode=1920x1080x32, linelength=7680
[ 1.889225] Console: switching to colour frame buffer device 240x67
[ 1.924212] simple-framebuffer 1e402000.framebuffer: fb0: simplefb registered!
[ 1.934144] NET: Registered protocol family 2
[ 1.934381] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.936199] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.936265] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 1.936350] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 1.936454] TCP: Hash tables configured (established 4096 bind 4096)
[ 1.936628] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.936671] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 1.936941] NET: Registered protocol family 1
[ 1.937800] RPC: Registered named UNIX socket transport module.
[ 1.937814] RPC: Registered udp transport module.
[ 1.937826] RPC: Registered tcp transport module.
[ 1.937839] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.939848] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.943915] Initialise system trusted keyrings
[ 1.944203] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 1.953962] zbud: loaded
[ 1.956215] FS-Cache: Netfs 'nfs' registered for caching
[ 1.957121] NFS: Registering the id_resolver key type
[ 1.957178] Key type id_resolver registered
[ 1.957191] Key type id_legacy registered
[ 1.957367] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.957384] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.958609] Key type asymmetric registered
[ 1.958624] Asymmetric key parser 'x509' registered
[ 1.958682] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.958699] io scheduler mq-deadline registered
[ 1.958712] io scheduler kyber registered
[ 1.968616] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.969221] vc-mem: phys_addr:0x00000000 mem_base=0x1ec00000 mem_size:0x20000000(512 MiB)
[ 1.970506] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.982854] brd: module loaded
[ 1.995590] loop: module loaded
[ 1.997526] Loading iSCSI transport class v2.0-870.
[ 1.999159] libphy: Fixed MDIO Bus: probed
[ 1.999467] usbcore: registered new interface driver lan78xx
[ 1.999567] usbcore: registered new interface driver smsc95xx
[ 1.999593] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.727883] Core Release: 2.80a
[ 2.727902] Setting default values for core params
[ 2.727935] Finished setting default values for core params
[ 2.928291] Using Buffer DMA mode
[ 2.928305] Periodic Transfer Interrupt Enhancement - disabled
[ 2.928316] Multiprocessor Interrupt Enhancement - disabled
[ 2.928332] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.928349] Dedicated Tx FIFOs mode
[ 2.929397] WARN::dwc_otg_hcd_init:1074: FIQ DMA bounce buffers: virt = 8bd04000 dma = 0xcbd04000 len=9024
[ 2.929432] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 2.929447] dwc_otg: Microframe scheduler enabled
[ 2.929521] WARN::hcd_init_fiq:457: FIQ on core 1
[ 2.929536] WARN::hcd_init_fiq:458: FIQ ASM at 807cc05c length 36
[ 2.929555] WARN::hcd_init_fiq:497: MPHI regs_base at 9c810000
[ 2.929580] dwc_otg 3f980000.usb: DWC OTG Controller
[ 2.929620] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 2.929672] dwc_otg 3f980000.usb: irq 89, io mem 0x00000000
[ 2.929729] Init: Port Power? op_state=1
[ 2.929741] Init: Power Port (0)
[ 2.930105] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 2.930122] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.930138] usb usb1: Product: DWC OTG Controller
[ 2.930153] usb usb1: Manufacturer: Linux 5.10.92-v7+ dwc_otg_hcd
[ 2.930168] usb usb1: SerialNumber: 3f980000.usb
[ 2.930959] hub 1-0:1.0: USB hub found
[ 2.931025] hub 1-0:1.0: 1 port detected
[ 2.932433] dwc_otg: FIQ enabled
[ 2.932446] dwc_otg: NAK holdoff enabled
[ 2.932459] dwc_otg: FIQ split-transaction FSM enabled
[ 2.932479] Module dwc_common_port init
[ 2.932828] usbcore: registered new interface driver usb-storage
[ 2.933060] mousedev: PS/2 mouse device common for all mice
[ 2.934468] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 2.937237] sdhci: Secure Digital Host Controller Interface driver
[ 2.937251] sdhci: Copyright(c) Pierre Ossman
[ 2.937974] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 2.938699] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 2.938982] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.940041] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.940368] hid: raw HID events driver (C) Jiri Kosina
[ 2.940538] usbcore: registered new interface driver usbhid
[ 2.940550] usbhid: USB HID core driver
[ 2.946388] Initializing XFRM netlink socket
[ 2.946438] NET: Registered protocol family 17
[ 2.946608] Key type dns_resolver registered
[ 2.947374] Registering SWP/SWPB emulation handler
[ 2.947546] registered taskstats version 1
[ 2.947579] Loading compiled-in X.509 certificates
[ 2.948453] Key type ._fscrypt registered
[ 2.948469] Key type .fscrypt registered
[ 2.948482] Key type fscrypt-provisioning registered
[ 2.960889] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.961018] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 114, base_baud = 0) is a PL011 rev2
[ 2.963469] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.965331] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.965349] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.992354] sdhost: log_buf @ (ptrval) (cbd03000)
[ 3.030447] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 3.032150] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.033831] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.036835] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 3.038512] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 3.041037] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 3.044189] of_cfs_init
[ 3.044495] of_cfs_init: OK
[ 3.046018] Waiting for root device PARTUUID=825d44bc-02...
[ 3.062155] Indeed it is in host mode hprt0 = 00021501
[ 3.188787] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.192539] mmc0: new high speed SDHC card at address aaaa
[ 3.193551] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 3.197142] mmcblk0: p1 p2
[ 3.221956] mmc1: new high speed SDIO card at address 0001
[ 3.240155] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 3.240257] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 3.248527] devtmpfs: mounted
[ 3.256361] Freeing unused kernel memory: 1024K
[ 3.265151] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.265627] Run /sbin/init as init process
[ 3.265639] with arguments:
[ 3.265650] /sbin/init
[ 3.265662] splash
[ 3.265673] with environment:
[ 3.265686] HOME=/
[ 3.265697] TERM=linux
[ 3.266072] Indeed it is in host mode hprt0 = 00001101
[ 3.518052] usb 1-1: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=92.26
[ 3.518079] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.518097] usb 1-1: Product: USB2.0 Hub
[ 3.518112] usb 1-1: Manufacturer: GenesysLogic
[ 3.519068] hub 1-1:1.0: USB hub found
[ 3.519380] hub 1-1:1.0: 4 ports detected
[ 3.810980] systemd[1]: System time before build time, advancing clock.
[ 3.855187] usb 1-1.3: new full-speed USB device number 3 using dwc_otg
[ 3.967408] NET: Registered protocol family 10
[ 3.969015] Segment Routing with IPv6
[ 3.993976] usb 1-1.3: New USB device found, idVendor=046d, idProduct=c52f, bcdDevice=30.00
[ 3.994004] usb 1-1.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 3.994022] usb 1-1.3: Product: USB Receiver
[ 3.994037] usb 1-1.3: Manufacturer: Logitech
[ 4.004106] input: Logitech USB Receiver as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.0/0003:046D:C52F.0001/input/input0
[ 4.004750] hid-generic 0003:046D:C52F.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-3f980000.usb-1.3/input0
[ 4.011735] input: Logitech USB Receiver Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.3/1-1.3:1.1/0003:046D:C52F.0002/input/input1
[ 4.065428] systemd[1]: systemd 247.3-6+rpi1 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +ZSTD +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=unified)
[ 4.066633] systemd[1]: Detected architecture arm.
[ 4.072294] systemd[1]: Set hostname to <raspberrypi>.
[ 4.075963] hid-generic 0003:046D:C52F.0002: input,hiddev96,hidraw1: USB HID v1.11 Device [Logitech USB Receiver] on usb-3f980000.usb-1.3/input1
[ 4.185248] usb 1-1.4: new high-speed USB device number 4 using dwc_otg
[ 4.331607] usb 1-1.4: New USB device found, idVendor=413c, idProduct=1010, bcdDevice=32.98
[ 4.331636] usb 1-1.4: New USB device strings: Mfr=0, Product=11, SerialNumber=0
[ 4.331654] usb 1-1.4: Product: USB 2.0 Hub [MTT]
[ 4.332778] hub 1-1.4:1.0: USB hub found
[ 4.334470] hub 1-1.4:1.0: 4 ports detected
[ 4.655217] usb 1-1.4.4: new low-speed USB device number 5 using dwc_otg
[ 4.845502] usb 1-1.4.4: New USB device found, idVendor=413c, idProduct=2110, bcdDevice= 0.06
[ 4.845531] usb 1-1.4.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 4.845548] usb 1-1.4.4: Product: Dell Wired Multimedia Keyboard
[ 4.845563] usb 1-1.4.4: Manufacturer: Dell
[ 4.873472] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.0/0003:413C:2110.0003/input/input4
[ 4.936026] hid-generic 0003:413C:2110.0003: input,hidraw2: USB HID v1.10 Keyboard [Dell Dell Wired Multimedia Keyboard] on usb-3f980000.usb-1.4.4/input0
[ 4.981187] input: Dell Dell Wired Multimedia Keyboard Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.1/0003:413C:2110.0004/input/input5
[ 4.981794] input: Dell Dell Wired Multimedia Keyboard System Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.1/0003:413C:2110.0004/input/input6
[ 5.045752] input: Dell Dell Wired Multimedia Keyboard Consumer Control as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4.4/1-1.4.4:1.1/0003:413C:2110.0004/input/input7
[ 5.046264] hid-generic 0003:413C:2110.0004: input,hiddev97,hidraw3: USB HID v1.10 Mouse [Dell Dell Wired Multimedia Keyboard] on usb-3f980000.usb-1.4.4/input1
[ 5.076080] systemd[1]: /lib/systemd/system/plymouth-start.service:16: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
