OG02B10 2MP Color Global Shutter external trigger with Raspberry
    Uctronics.com
    Raspberry PI 4b/ Raspbian GNU/Linux 11 (bullseye)
    Installed with:
$ wget -O install_pivariety_pkgs.sh https://github.com/ArduCAM/Arducam-Pivariety-V4L2-Driver/releases/download/install_script/install_pivariety_pkgs.sh
$ chmod +x install_pivariety_pkgs.sh
$ ./install_pivariety_pkgs.sh -p libcamera_dev
$ ./install_pivariety_pkgs.sh -p libcamera_apps
$ ./install_pivariety_pkgs.sh -p kernel_driver
  1. Problems you were having?
    Cannot operate the trigger:
    [email protected]:~$ v4l2-ctl -c trigger_mode=1
    unknown control ‘trigger_mode’
  2. The dmesg log from your hardware?
    [email protected]:~ $ dmesg | grep arducam
    [ 9.167122] arducam: loading out-of-tree module taints kernel.
    [ 9.190199] arducam-pivariety 10-000c: firmware version: 0x10002
    [ 9.919818] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
  3. Troubleshooting attempts you’ve made?
    Looked for a solution through google but could not find something helpful.
  4. What help do you need?
    Instructions on how to make the trigger work.
It looks like something is missing:
[email protected]:~/Downloads $ libcamera-still --list-cameras
[0:51:23.295550058] [5578]  INFO Camera camera_manager.cpp:293 libcamera v0.0.0
[0:51:23.315855966] [5579]  WARN CameraSensorProperties camera_sensor_properties.cpp:141 No static properties available for 'arducam-pivariety'
[0:51:23.315905577] [5579]  WARN CameraSensorProperties camera_sensor_properties.cpp:143 Please consider updating the camera sensor properties database
[0:51:23.315936484] [5579] ERROR CameraSensor camera_sensor.cpp:551 'arducam-pivariety 10-000c': Camera sensor does not support test pattern modes.
[0:51:23.325727071] [5579] ERROR IPAProxy ipa_proxy.cpp:149 Configuration file 'arducam-pivariety.json' not found for IPA module 'raspberrypi'
[0:51:23.705722204] [5579]  WARN RPI raspberrypi.cpp:1233 Mismatch between Unicam and CamHelper for embedded data usage!
[0:51:23.706153590] [5579] ERROR DelayedControls delayed_controls.cpp:87 Delay request for control id 0x009a090a but control is not exposed by device /dev/v4l-subdev0
[0:51:23.706304292] [5579]  INFO RPI raspberrypi.cpp:1356 Registered camera /base/soc/i2c0mux/[email protected]/[email protected] to Unicam device /dev/media3 and ISP device /dev/media0
Available cameras
0 : arducam-pivariety [1600x1300] (/base/soc/i2c0mux/[email protected]/[email protected])
    Modes: 'SBGGR10_CSI2P' : 1280x720 1600x1080 1600x1300
'SBGGR8' : 1280x720 1600x1080 1600x1300
Additional info:
[email protected]:~ $ uname -a
Linux raspberrypi 5.10.103-v7l+ #1530 SMP Tue Mar 8 13:05:01 GMT 2022 armv7l GNU/Linux
[email protected]:~ $ cat /etc/os-release
NAME="Raspbian GNU/Linux"
VERSION_ID="11"
VERSION="11 (bullseye)"
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
[email protected]:~ $ cat /proc/meminfo
MemTotal:         943788 kB
MemFree:          149796 kB
MemAvailable:     595272 kB
Buffers:           34844 kB
Cached:           506228 kB
SwapCached:            0 kB
Active:           101400 kB
Inactive:         572936 kB
Active(anon):        832 kB
Inactive(anon):   189288 kB
Active(file):     100568 kB
Inactive(file):   383648 kB
Unevictable:       45156 kB
Mlocked:              16 kB
HighTotal:        184320 kB
HighFree:           1140 kB
LowTotal:         759468 kB
LowFree:          148656 kB
SwapTotal:        102396 kB
SwapFree:         102396 kB
Dirty:                 0 kB
Writeback:             0 kB
AnonPages:        178452 kB
Mapped:           179344 kB
Shmem:             62388 kB
KReclaimable:      21000 kB
Slab:              39680 kB
SReclaimable:      21000 kB
SUnreclaim:        18680 kB
KernelStack:        1984 kB
PageTables:         5728 kB
NFS_Unstable:          0 kB
Bounce:                0 kB
WritebackTmp:          0 kB
CommitLimit:      574288 kB
Committed_AS:    1213764 kB
VmallocTotal:     245760 kB
VmallocUsed:        5136 kB
VmallocChunk:          0 kB
Percpu:              528 kB
CmaTotal:         262144 kB
CmaFree:           73116 kB
[email protected]:~ $ cat /boot/config.txt
# http://rpf.io/configtxt
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
frambuffer_width=1600
framebuffer_height=1024
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
camera_auto_detect=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
enable_uart=1
# disable bluetooth
dtoverlay=disable-bt
dtoverlay=arducam
[email protected]:~ $ v4l2-ctl -c trigger_mode=1
unknown control 'trigger_mode'
[    9.029464] arducam: loading out-of-tree module taints kernel.
[    9.041030] arducam-pivariety 10-000c: firmware version: 0x10002
[    9.661950] arducam-pivariety 10-000c: Consider updating driver arducam-pivariety to match on endpoints
Thank you very much for your information,
please try:
v4l2-ctl -l -d /dev/v4l-subdev0
v4l2-ctl -d /dev/v4l-subdev0 -c trigger_mode=1
For more information please refer to:
