errors when compiling mjpeg streamer with libcamera input plugin
6.527869] imx519 10-001a: Device found is imx519
[ 6.529050] imx519 10-001a: Consider updating driver imx519 to match on endpoints
Troubleshooting attempts youâve made?
Why is it showing error listed below ?
[ 55%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o
/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:71:5: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
71 | " Help for input plugin..: "INPUT_PLUGIN_NAME"\n" \
/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp: In function âint input_cmd(int, unsigned int, unsigned int, int)â:
/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:422:38: error: âAfTriggerâ is not a member of âlibcamera::controls::draftâ; did you mean âlibcamera::controls::AfTriggerâ?
422 | controls_.set(controls::draft::AfTrigger, 1);
In file included from /home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.h:21,
from /home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:31:
/usr/include/libcamera/libcamera/control_ids.h:163:31: note: âlibcamera::controls::AfTriggerâ declared here
163 | extern const Control<int32_t> AfTrigger;
make[3]: *** [plugins/input_libcamera/CMakeFiles/input_libcamera.dir/build.make:82: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o] Error 1
make[3]: Leaving directory '/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/_build'
make[2]: *** [CMakeFiles/Makefile2:475: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/all] Error 2
make[2]: Leaving directory '/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/_build'
make[1]: *** [Makefile:149: all] Error 2
make[1]: Leaving directory '/home/pi/mj/mjpg-streamer/mjpg-streamer-experimental/_build'
make: *** [Makefile:19: all] Error 2
pi@voron2:~/mj/mjpg-streamer/mjpg-streamer-experimental $
@yang, If I implement the suggested change, it solves that error, however I encountered a new error:
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:71:5: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
[ 62%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp: In member function âint LibCamera::startCapture()â:
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:118:38: error: âconst class libcamera::FileDescriptorâ has no member named âgetâ
plane.fd.get(), 0);
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:119:41: error: âconst class libcamera::FileDescriptorâ has no member named âgetâ
mappedBuffers_[plane.fd.get()] =
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp: In member function âbool LibCamera::readFrame(LibcameraOutData*)â:
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:208:54: error: âconst class libcamera::FileDescriptorâ has no member named âgetâ
void *data = mappedBuffers_[plane.fd.get()].first;
make[3]: *** [plugins/input_libcamera/CMakeFiles/input_libcamera.dir/build.make:76: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o] Error 1
make[3]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[2]: *** [CMakeFiles/Makefile2:384: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/all] Error 2
make[2]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[1]: *** [Makefile:130: all] Error 2
make[1]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
Hello @Edward, yes after installing the recommended octoprint version, and following this guide, I was able to get it to work! I am using a raspberry pi zero, so my camera stream kept freezing so I had to make a change recommended in this article Webcam freezing after a few seconds - Webcams - OctoPrint Community Forum and now everything works perfectly!
