Kickstarter
Arducam 16MP with Autofocus. SKU: B0371
RPi 4B 8GB with OctoPrint 1.18 and OctoPi 0.18.0
$ uname -a
Linux octoprint 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux
$ lsb_release -a
No LSB modules are available.
Distributor ID: Raspbian
Description: Raspbian GNU/Linux 10 (buster)
Release: 10
Codename: buster
I’m following below guide except the step of using the nightly version of Octopi. Instead I wanted to use the latest stable version that was just recently release. Unfortunately this version is still based in Buster, not Bullseye. So there’s some misalignment between the guide and the steps I’m taking
- Problems you were having?
I’ve been following the guide I shared above and everything was going well. I even tried taking pictures with libcamera-still and it worked well. However when I reached the part of compiling mjpg-streamer I’m experiencing troubles. When I run make I get this:
[ 34%] Building C object plugins/input_raspicam/CMakeFiles/input_raspicam.dir/input_raspicam.c.o
In file included from /home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c:51:
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c: In function 'raspicamcontrol_set_saturation':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c:762:32: warning: implicit declaration of function 'mmal_port_parameter_set_rational'; did you mean 'mmal_port_parameter_set'? [-Wimplicit-function-declaration]
ret = mmal_status_to_int(mmal_port_parameter_set_rational(camera->control, MMAL_PARAMETER_SATURATION, value));
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c: In function 'raspicamcontrol_set_ISO':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c:864:30: warning: implicit declaration of function 'mmal_port_parameter_set_uint32'; did you mean 'mmal_port_parameter_set'? [-Wimplicit-function-declaration]
return mmal_status_to_int(mmal_port_parameter_set_uint32(camera->control, MMAL_PARAMETER_ISO, ISO));
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c: In function 'raspicamcontrol_set_video_stabilisation':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c:899:30: warning: implicit declaration of function 'mmal_port_parameter_set_boolean'; did you mean 'mmal_port_parameter_set'? [-Wimplicit-function-declaration]
return mmal_status_to_int(mmal_port_parameter_set_boolean(camera->control, MMAL_PARAMETER_VIDEO_STABILISATION, vstabilisation));
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c: In function 'raspicamcontrol_set_exposure_compensation':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/RaspiCamControl.c:913:30: warning: implicit declaration of function 'mmal_port_parameter_set_int32'; did you mean 'mmal_port_parameter_set'? [-Wimplicit-function-declaration]
return mmal_status_to_int(mmal_port_parameter_set_int32(camera->control, MMAL_PARAMETER_EXPOSURE_COMP , exp_comp));
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c: In function 'worker_thread':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c:885:10: warning: implicit declaration of function 'mmal_port_pool_create'; did you mean 'mmal_pool_create'? [-Wimplicit-function-declaration]
pool = mmal_port_pool_create(encoder_output, encoder_output->buffer_num, encoder_output->buffer_size);
mmal_pool_create
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c:885:8: warning: assignment to 'MMAL_POOL_T *' {aka 'struct MMAL_POOL_T *'} from 'int' makes pointer from integer without a cast [-Wint-conversion]
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_raspicam/input_raspicam.c:1057:5: warning: implicit declaration of function 'mmal_port_pool_destroy'; did you mean 'mmal_pool_destroy'? [-Wimplicit-function-declaration]
mmal_port_pool_destroy(encoder->output[0], pool);
mmal_pool_destroy
[ 37%] Linking C shared library input_raspicam.so
make[3]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
[ 37%] Built target input_raspicam
make[3]: Entering directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
[ 41%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/dynctrl.c.o
[ 44%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/input_uvc.c.o
[ 48%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/jpeg_utils.c.o
[ 51%] Building C object plugins/input_uvc/CMakeFiles/input_uvc.dir/v4l2uvc.c.o
[ 55%] Linking C shared library input_uvc.so
[ 55%] Built target input_uvc
[ 58%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/input_libcamera.cpp.o
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/input_libcamera.cpp:71:5: warning: invalid suffix on literal; C++11 requires a space between literal and string macro [-Wliteral-suffix]
" Help for input plugin..: "INPUT_PLUGIN_NAME"\n" \
[ 62%] Building CXX object plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp: In member function 'int LibCamera::startCapture()':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:118:38: error: 'const class libcamera::FileDescriptor' has no member named 'get'
plane.fd.get(), 0);
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:119:41: error: 'const class libcamera::FileDescriptor' has no member named 'get'
mappedBuffers_[plane.fd.get()] =
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp: In member function 'bool LibCamera::readFrame(LibcameraOutData*)':
/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/plugins/input_libcamera/LibCamera.cpp:208:54: error: 'const class libcamera::FileDescriptor' has no member named 'get'
void *data = mappedBuffers_[plane.fd.get()].first;
make[3]: *** [plugins/input_libcamera/CMakeFiles/input_libcamera.dir/build.make:76: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/LibCamera.cpp.o] Error 1
make[2]: *** [CMakeFiles/Makefile2:483: plugins/input_libcamera/CMakeFiles/input_libcamera.dir/all] Error 2
make[2]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make[1]: *** [Makefile:130: all] Error 2
make[1]: Leaving directory '/home/pi/mjpg-streamer-libcamera/mjpg-streamer-experimental/_build'
make: *** [Makefile:19: all] Error 2
[ 5.637784] ak7375: loading out-of-tree module taints kernel.
[ 5.669292] imx519 10-001a: Device found is imx519
[ 31.835843] imx519_vddl: disabling
[ 31.835865] imx519_vdig: disabling
[ 31.835894] imx519_vana: disabling
When trying to use libcamera-still I had some problems caused by deps missing that I could fix by installing following deps:
sudo apt-get install libepoxy0
sudo apt-get install libqt5core5a
sudo apt-get install libqt5widgets5
However with compiling mjpg-streamer I’m not having any luck
- What help do you need?
Is there anything I can do to compile the arducam mjpg-streamer. Thanks in advance!
