Libcamera & IMX519 FAQ
This post is used to explain some common problems with IMX519 and libcamera.
Question 1:
I get an error similar to the following when installing the kernel driver:
Hardware Revision: b03111
Kernel Version: 5.4.83-v7l+
Solution:
Need to install the latest Raspberry Pi system, and do not execute rpi-update
https://downloads.raspberrypi.org/raspios_full_armhf/images/raspios_full_armhf-2021-11-08/
https://downloads.raspberrypi.org/raspios_full_armhf/images/raspios_full_armhf-2022-01-28/
Question 2:
I get the following error when running libcamera:
[0:01:46.295273858] [631] INFO Camera camera.cpp:1028 configuring streams: (0) 4656x3496-YUV420 (1) 4656x3496-SRGGB10_CSI2P
[0:01:46.296042453] [632] INFO RPI raspberrypi.cpp:751 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 4656x3496-SRGGB10_1X10 - Selected unicam format: 4656x3496-pRAA
 [0:01:46.351230171] [632] ERROR V4L2 v4l2_videodevice.cpp:1179 /dev/video0[12:cap]: Unable to request 1 buffers: Cannot allocate memory
ERROR: *** failed to allocate capture buffers ***
Solution:
Modify /boot/config.txt to add dtoverlay=vc4-kms-v3d,cma-<size>
1e2e4414-8f29-43f0-a603-382072320c40
Example:
333938a4-1166-47fe-b9a0-c7102bf2bd2c
Note: It is recommended to set to cma-128 or cma-96 on devices with smaller memory such as Pi Zero / Zero 2 W
Question 3:
I got an error similar to the following when I ran libcamera:
terminate called after throwing an instance of \'std::runtime_error\'
what(): failed to import fd 21
Aborted
Solution:
For Raspbian Buster users, please also:
  1. Open /boot/config.txt
  2. Add the following line under [all]:
    dtoverlay=vc4-fkms-v3d
  3. Save and reboot
For Raspbian Bullseye users running on Pi Zero ~ Pi 3:,
  1. Open a terminal
  2. Run sudo raspi-config
  3. Navigate to Advanced Options
  4. Enable Glamor graphic acceleration
  5. Reboot your Pi
For more details, please refer to the official forum guide on how to configure the camera module >>
Question 4:
I cannot install the corresponding package using a third-party system.
Solution:
About Octoprint:
Currently Octoprint’s mjpg-streamer plugin does not support libcamera, if you want to use a camera with a focus motor, you can try 5mp v1 camera, 8mp v2 camera, we are also trying to solve this problem (need to develop mjpg-streamer libcamera plugin), but Currently not supported.
Update:
A mjpg-streamer that works with libcamera:
Update2:
We have successfully run libcamera & imx519 on OctoPi Nightly build, please refer to:
Question 5:
How to use two camera ports on the CM4
Solution:
You need to install the latest Raspberry Pi system (after 2022/01/28), and do not execute rpi-update
Refer to this documentation to install drivers and applications:
After installing the system and drivers, add the following information to /boot/config.txt:
[cm4]
dtoverlay=imx519
dtoverlay=imx519,cam0
Note 1: For pivariety series, please modify imx519 to arducam.
Note 2: Need to reboot after modifying /boot/config.txt
Usage:
List all cameras:
Specify camera:
libcamera-still -t 0 --camera 0
libcamera-still -t 0 --camera 1
A post was split to a new topic: Quad-HAT outputs the wrong image
Question 6: Which driver should I install?
The 16MP Quad-Camera Kit(B0388), 15-Meter Cable Extension Kit (U6248) and Arducam Mini 16MP IMX519(B0389, B0391) require the “low speed” version of the driver:
chmod +x install_pivariety_pkgs.s
./install_pivariety_pkgs.sh -p imx519_kernel_driver_low_speed
In fact, if you are not sure which driver to install, please install imx519_kernel_driver_low_speed, the only difference between the “low speed” version of the driver and the normal version is that the maximum resolution frame rate of the “low speed” version is 1-2 frames slower than the normal version.
Question 7: Open I2C bus error
Some systems do not have i2c enabled by default, and you will encounter the following errors when running libcamera-apps:
Solution:
sudo raspi-config
     --> Interface Options
          --> I2C
Question 8: An interesting project: Plug-and-play Raspberry Pi USB webcam
Project Introduction:
https://www.raspberrypi.com/tutorials/plug-and-play-raspberry-pi-usb-webcam/
More suggested reference:
can anyone help me with this?
[0:37:15.192624998] [2887] INFO Camera camera_manager.cpp:313 libcamera v0.3.0+65-6ddd79b5
[0:37:15.200499537] [2888] INFO RPI pisp.cpp:695 libpisp version v1.0.6 b567f0455680 17-06-2024 (10:20:00)
[0:37:15.227481658] [2888] INFO RPI pisp.cpp:1154 Registered camera /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a to CFE device /dev/media0 and ISP device /dev/media2 using PiSP variant BCM2712_C0
Made X/EGL preview window
Mode selection for 2328:1748:12:P
SRGGB10_CSI2P,1280x720/0 - Score: 5319.24
SRGGB10_CSI2P,1920x1080/0 - Score: 3319.24
SRGGB10_CSI2P,2328x1748/0 - Score: 1000
SRGGB10_CSI2P,3840x2160/0 - Score: 1648.24
SRGGB10_CSI2P,4656x3496/0 - Score: 2019
Stream configuration adjusted
[0:37:15.588092347] [2887] INFO Camera camera.cpp:1183 configuring streams: (0) 2328x1748-YUV420 (1) 2328x1748-RGGB_PISP_COMP1
[0:37:15.588254526] [2888] INFO RPI pisp.cpp:1450 Sensor: /base/axi/pcie@120000/rp1/i2c@80000/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected CFE format: 2328x1748-PC1R
[0:37:15.598192210] [2893] WARN IPARPI ipa_base.cpp:732 Could not set AF_MODE - no AF algorithm
[0:37:15.598338779] [2893] WARN IPARPI ipa_base.cpp:1114 Could not set AF_SPEED - no focus algorithm
[0:37:15.598361445] [2893] WARN IPARPI ipa_base.cpp:1096 Could not set AF_RANGE - no focus algorithm
Hi
What’s the camera you are using? Besides, could you post the output of the command below?
dpkg -l | grep libcamera
Will not using the low speed version of the driver cause the cameras to not be detected? That is my current issue.
