Hello!
I bought an “Arducam Complete High Quality Camera Bundle for Jetson Nano” kit hoping it would be valid for the Xavier NX, but it looks like the drivers available in MIPI_Camera/Jetson/Jetvariety/driver at master · ArduCAM/MIPI_Camera · GitHub do not include the kernel the NX is using. I am getting this error when trying to install the driver for tegra revision 4.2:
dpkg: dependency problems prevent configuration of arducam-nvidia-l4t-kernel:
arducam-nvidia-l4t-kernel depends on nvidia-l4t-kernel (= 4.9.140-tegra-32.4.2-20200428140713); however:
Version of nvidia-l4t-kernel on system is 4.9.140-tegra-32.4.2-20200428141701.
dpkg: error processing package arducam-nvidia-l4t-kernel (–install):
dependency problems - leaving unconfigured
Is there any solution available or plans to build a driver for this kernel version? Thank you very much in advance!
I am interested in this answer. I also have an Xavier NX and I am looking for a comprehensive camera solution.
wong
July 5, 2020, 9:46pm
3
The Jetson Xavier NX driver is under development. This work will be completed soon, please be patient.
Great news I look forward to it.
lvbin
July 12, 2020, 6:03pm
5
Please be patient. We will do our best to provide solutions to customers
Thank you very much. I appreciate you are working on this.
Please let us know when you have a driver prototype. I’ll be glad to beta-test if it is helpful
Hi Everyone,
I saw that the driver was available for the Jetson Xavier NX (https://github.com/ArduCAM/MIPI_Camera/tree/master/Jetson/Jetvariety/driver ).
So I tested it with my AR1820HS and my IMX1335 !
But this is the picture I have :
I also have changed the pixelformat (pixelformat(“BA10”)), but I can’t have a correct photo. Any idea ? Is it because of the driver ?
so is accurate that you are selling a camera without functional drivers
Just to let you know : My last test was with Jetpack 4.4 release 32.4.3 (my previous post #26028 ), and the pictures were not good.
Today I tested the other driver with Jetpack 4.4 release 32.4.2 : when trying to see the cameras (v4l2-ctl --list-devices), no camera is available (I tested AR1820HS and IMX135, after reboot and checked the wire connexions).
Are there any updates to the status of a driver for Xavier NX?
Thanks,
-Joe
drh
September 15, 2020, 11:18pm
12
When do you expect the drivers for B0220 and B0221 on the XAVIER NX to be available? B0223 is already available, right?
jeslava
November 25, 2020, 9:43am
13
Any update on this?
I have problems on getting work the camera bundle with Jetson Xavier NX dev. kit.
Regards.
wong
November 25, 2020, 10:49pm
14
Hi everyone, I’m very sorry I missed this post.
Now the driver of Jetson Xavier NX can be installed through the automatic installation script:
https://github.com/ArduCAM/MIPI_Camera/releases/tag/v0.0.2
However, the automatic installation script only supports L4T32.4.3 and above.
wong
November 25, 2020, 10:51pm
15
Hi @DrH
B0220 and B0221 and can be used in L4T32.4.4 version.
B0223 can be used in all versions provided.
wong
November 25, 2020, 10:52pm
16
Hi @jeslava
Can you describe the problem you encountered in detail?
wong
November 25, 2020, 10:55pm
17
Hi @pelepicier
Sorry again for the late reply,
Can you tell me what software you use to play it?
Can you try the example program we provide?
https://github.com/ArduCAM/MIPI_Camera/tree/master/Jetson/Jetvariety/example
jeslava
November 25, 2020, 11:25pm
18
Hello Wong,
I am using B0267 and Jetson Xavier NX, here there is a description of my issue:
I am using B0267
Platform: Jetson Xavier NX
I am following this instructions: Camarray – Arducam 1MP Quadrascopic Camera Bundle Kit
The product worked on Raspberry Pi 3 and cable connections are OK.
The problem:
I am trying to use the quadrascopic camera bundle OV9281 with a Jetson Xavier NX development kit.
My sytem is R32 4.4 and my kernel is 4.9.140-tegra-32.4.4-2020102721332
I used this driver: https://github.com/ArduCAM/MIPI_Camera/releases/download/v0.0.1-nx/arducam-nvidia-l4t-kernel_4.9.140-32.4.4-20201027211332_arm64.deb
I am able to see /dev/video0 but no image is displayed.
My kernel boot log is:
[ 2.009968] arducam-csi2 9-000c: firmware version: 3
[ 2.010238] arducam-csi2 9-000c: Sensor ID: 0x0000
[ 2.041306] arducam-csi2 9-000c: sensor arducam-csi2 9-000c registered
[ 2.064791] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.064956] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.065154] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.065227] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 2.065440] arducam-csi2 10-000c: probe failed
[ 2.065648] arducam-csi2 10-000c: Failed to setup board.
Could you please provide me some instructions/advises?
wong
November 26, 2020, 4:30pm
19
Hi @jeslava
From the boot log, the driver has correctly identified the camera.
Can you run the dmesg command after running the camera and send the output to me?
Also attach photos of your hardware connection.
giskard
December 31, 2020, 12:29am
20
I’ve installed the Jetson Xavier NX driver, but the camera doesn’t seem to be detected. It doesn’t appear in /dev/video*.
I’m using, arducam-nvidia-l4t-kernel_4.9.140-32.4.4-20201026143033_arm64.deb
The camera is a B0274, and I can hear the mechanical IR filter activating when I block the photosensor.
Here’s my dmesg (similar to jeslava’s):
[ 2.134599] i2c /dev entries driver
[ 2.136763] i2c i2c-2: Added multiplexed i2c bus 9
[ 2.137327] i2c i2c-2: Added multiplexed i2c bus 10
[ 2.137337] i2c-mux-gpio cam_i2cmux: 2 port mux on 3180000.i2c adapter
[ 2.161659] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.161807] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.161940] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.161982] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 2.162372] arducam-csi2 9-000c: probe failed
[ 2.162550] arducam-csi2 9-000c: Failed to setup board.
[ 2.186297] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.186487] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.186626] tegra-i2c 3180000.i2c: no acknowledge from address 0xc
[ 2.186701] arducam-csi2: arducam_read: Reading register 0x103 failed
[ 2.186922] arducam-csi2 10-000c: probe failed
[ 2.187096] arducam-csi2 10-000c: Failed to setup board.
Any suggestions for further troubleshooting?
