Direct order from Arducam
B0574 -
Linux/Android
https://docs.arducam.com/UVC-Camera/USB3-UVC-Camera-Kit/Quick-Start-Guide-for-Linux/
We are not able to capture at 30fps because the option of motion JPG does not seem to be available. -
[ 42.884729] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[ 42.933902] nvidia-uvm: Loaded the UVM driver, major device number 234.
[24913.196453] perf: interrupt took too long (2517 > 2500), lowering kernel.perf_event_max_sample_rate to 79250
[36132.946964] perf: interrupt took too long (3153 > 3146), lowering kernel.perf_event_max_sample_rate to 63250
[43912.761839] /proc/cgroups lists only v1 controllers, use cgroup.controllers of root cgroup for v2 info
[45685.579785] perf: interrupt took too long (3944 > 3941), lowering kernel.perf_event_max_sample_rate to 50500
[58822.048035] perf: interrupt took too long (4940 > 4930), lowering kernel.perf_event_max_sample_rate to 40250
[133894.693720] perf: interrupt took too long (6187 > 6175), lowering kernel.perf_event_max_sample_rate to 32250
[403017.461292] usb 2-5: new SuperSpeed USB device number 2 using xhci_hcd
[403017.477706] usb 2-5: LPM exit latency is zeroed, disabling LPM.
[403017.478626] usb 2-5: New USB device found, idVendor=04b4, idProduct=0574, bcdDevice= 0.00
[403017.479040] usb 2-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[403017.479400] usb 2-5: Product: Arducam B0574 Stereo Camera
[403017.479676] usb 2-5: Manufacturer: Arducam
[403017.479890] usb 2-5: SerialNumber: Arducam_20250618_0001
[403017.581373] mc: Linux media interface: v0.10
[403017.622050] videodev: Linux video capture interface: v2.00
[403017.664331] usb 2-5: Found UVC 1.10 device Arducam B0574 Stereo Camera (04b4:0574)
[403017.667083] usbcore: registered new interface driver uvcvideo
Manual exposure with short exposure time
It was suggested that updating the firmware would help but the process stalls with the following:
Update tool gets stuck on 11% with the message:
State: Erase, total time 0:0
This was attempted with the windows tool.
- What help do you need?
Alternate method to update firmware (tool, image, etc) or a different approach to enabling MotionJPG.
