Cv2 opencv unable to open 64mp stream error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow’
    online
    arducam_64mp [9248x6944] (/base/soc/i2c0mux/[email protected]/[email protected])
    Linux drone 5.15.32-v8+ #1538 SMP PREEMPT Thu Mar 31 19:40:39 BST 2022 aarch64 GNU/Linux
    everything
  5. Problems you were having?
    See below, basically can’t open camera for opencv2
  8. What help do you need?
    Trying to rid myself of this error:
    import numpy as np
    import cv2
    cap = cv2.VideoCapture(0)
    ret, frame = cap.read()
    print(frame)
    cv2.imshow(‘frame’,frame)
cv2.waitKey(0)
cap.release()
cv2.destroyAllWindows()
ERRORS:
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (1824) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module v4l2src0 reported: Failed to allocate required memory.
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (914) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global …/modules/videoio/src/cap_gstreamer.cpp (501) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
None
File “/home/pi/CNN/test.py”, line 7, in
cv2.error: OpenCV(4.5.1) …/modules/highgui/src/window.cpp:376: error: (-215:Assertion failed) size.width>0 && size.height>0 in function 'imshow’
libcamera-hello --list-cameras
Open i2c bus error: No such file or directory
Available cameras
0 : arducam_64mp [9248x6944] (/base/soc/i2c0mux/[email protected]/[email protected])
Modes: ‘SRGGB10_CSI2P’ : 1280x720 [120.03 fps - (2064, 2032)/5120x2880 crop]
1920x1080 [60.04 fps - (784, 1312)/7680x4320 crop]
2312x1736 [30.00 fps - (0, 0)/9248x6944 crop]
3840x2160 [20.00 fps - (784, 1312)/7680x4320 crop]
4624x3472 [10.00 fps - (0, 0)/9248x6944 crop]
9152x6944 [2.70 fps - (0, 0)/9152x6944 crop]
@phar
Opencv takes the image from the video0 node, and libcamera takes the image from the media-controllor. Can’t get image through opencv.
you can use detect command
./install_pivariety_pkgs.sh -d
I ran the command, can you link me to an example of how to get the image? Thanks.
Also, now when I run
libcamera-hello
libEGL warning: DRI3: failed to query the version
X Error of failed request: BadRequest (invalid request code or no such operation)
Major opcode of failed request: 155 ()
Minor opcode of failed request: 1
Serial number of failed request: 16
Current serial number in output stream: 16
Can’t I get video from arudcam64 into opencv2 and then grab stills inside opencv2, not from the camera inself? No?
@phar
how to use 64mp with libcamera:
How to use arducam_64mp & arducam_64mp FAQ - Raspberry Pi Cameras - Arducam Camera Support Forum
How To Use Arducam 64MP Camera On Rapberry Pi - Arducam
You can display the obtained data with opencv, but you cannot get the data directly with opencv.
You can refer to picamera.
picamera2/examples at main · raspberrypi/picamera2 · GitHub
