For the simulation config, it works fine and shows the image with stripes.
I also tried with the USBTest.exe on Windows 11, it also shows USB transfer timeout error on the left side.
Since I bought the shield and the camera separately, I do notice that the mark number of my OG02B10 is not the same as shown in the official guide of the bundle
The official bundle seems to use UC-621 Rev.C but mine is UC-788 Rev.B, is it a problem?
Described above
How would you like us to help you?
Any suggestions what could cause this error?
And actually, the problem I met is different from the one in the link.
I said when I use the config /sim/sim_1920x1080.cfg, I can see this image of strips:
I think this means the connection between the computer and the USB shield is good, but the connection between the USB shield and the camera has some problems, right?
I did some more testing. According to this post, I tried to Read/Write the register (Write 0x55 to register 0x3012 and read), and I successfully get the same value, just like this.
I also tried to connect the camera to a raspberry PI, and it works with the libcamera-still to view & capture image. So I guess there’s some problem between the communication of the shield and the camera?
I tried to use the USBtest on windows to Read/Write the register (Write 0x55 to register 0x3012 and read), and I successfully get the same value, just like this video: arducam reg read - YouTube; but when I press the play button, there would be red text shows in the left like this:
[04:30:05]USB camera init success!
[04:30:28]USB transfer timeout error
[04:30:26]USB transfer timeout error
