HI,
I am trying to use the Camaaray HAT with IMX519 in RPI 4 Bullseye but no picture is available. I bought the package together (adapter + cameras).
A window comes up like this:
and errors are:
libcamera-hello
Made X/EGL preview window
[0:05:44.452885157] [3282] INFO Camera camera_manager.cpp:299 libcamera v0.0.3+40-9b860a66
[0:05:44.493429739] [3283] INFO RPI raspberrypi.cpp:1425 Registered camera /base/soc/i2c0mux/i2c@1/imx519@1a to Unicam device /dev/media4 and ISP device /dev/media2
[0:05:44.499297079] [3282] INFO Camera camera.cpp:1028 configuring streams: (0) 2328x1748-YUV420
[0:05:44.499712080] [3283] INFO RPI raspberrypi.cpp:805 Sensor: /base/soc/i2c0mux/i2c@1/imx519@1a - Selected sensor format: 2328x1748-SRGGB10_1X10 - Selected unicam format: 2328x1748-pRAA
[0:05:45.002028494] [3283] INFO V4L2 v4l2_videodevice.cpp:1820 /dev/video0[16:cap]: Zero sequence expected for first frame (got 2)
[0:05:45.002266791] [3283] INFO V4L2 v4l2_videodevice.cpp:1820 /dev/video1[17:cap]: Zero sequence expected for first frame (got 2)
[0:05:45.003212517] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.069784840] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.136334014] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.269670123] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.336575835] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.402902101] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.502834307] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.569566390] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.636511214] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.736707884] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.802513333] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.902314168] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:45.968945565] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.035596721] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.135610038] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.202221602] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.268847554] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.335504358] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.435466786] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.535698660] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.602379446] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.669066861] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.735192811] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.835384741] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.901977471] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:46.968626071] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.101674993] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.168609817] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.268521226] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.335182753] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.401574241] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.469078863] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.602028025] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.669279721] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsingfailed
[0:05:47.735366874] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.835241284] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:47.935314898] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.002214314] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.068312875] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.135105846] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.201828484] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.268430806] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.368088029] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.501756731] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.601496529] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.668785576] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.768048205] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.868278819] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:48.934752549] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.034567735] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.101363003] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.168183493] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.267856197] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.334428168] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.468127203] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.634625323] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.700863440] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
[0:05:49.801087573] [3287] ERROR IPARPI cam_helper.cpp:217 Embedded data buffer parsing failed
Anybody could help me with this issue?
Thanks
