I have just downloaded and compiled the github repository as per your instructions and I still get the results below. Is the hardware faulty?
pi@raspberrypi:~/MIPI_Camera/RPI $ ./arducamstill -t 0 -m 1 -awb 1 -ae 1 <---This failed to load an image and just hung!
Open camera...
Found sensor imx219 at address 10
mode: 0, width: 800, height: 600, pixelformat: pRAA, desc: (null)
mode: 1, width: 1280, height: 720, pixelformat: pRAA, desc: (null)
mode: 2, width: 1600, height: 1200, pixelformat: pRAA, desc: (null)
mode: 3, width: 1920, height: 1080, pixelformat: pBAA, desc: (null)
mode: 4, width: 2592, height: 1944, pixelformat: pRAA, desc: (null)
mode: 5, width: 3264, height: 1848, pixelformat: pRAA, desc: (null)
mode: 6, width: 3264, height: 2464, pixelformat: pRAA, desc: (null)
mode: 7, width: 1600, height: 600, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
mode: 8, width: 2560, height: 720, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
mode: 9, width: 3840, height: 1080, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
mode: 10, width: 5184, height: 1944, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
mode: 11, width: 6528, height: 1848, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
mode: 12, width: 6528, height: 2464, pixelformat: pRAA, desc: Used for Arducam synchronized stereo camera HAT
index: 0, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 1000
Can't open the file
Failed to set focus, the camera may not support this control.
Start preview...
Current mode: 1, width: 1280, height: 720, pixelformat: pRAA, desc: (null)
Open camera…
index: 0, CID: 0x00980911, desc: V4L2_CID_EXPOSURE, min: 0, max: 65535, default: 1606, current: 876
Can’t open the file
Start preview…
Current mode: 0, width: 800, height: 600, pixelformat: pRAA, desc: (null)
[Framerate]: 21 pfs, [Exposure]: 2493, [Focus]: 0000,[Rgain]: 0100, [Bgain]: 0100
pi@raspberrypi:~/MIPI_Camera/RPI/stereo_depth_demo $ python 1_test.py
Open camera…
Please enter the mode number:12
Current mode: 12,resolution: 6528x2464
^CTraceback (most recent call last):
File “1_test.py”, line 83, in <module>
frame = get_frame(camera)
File “1_test.py”, line 48, in get_frame
image = cv2.cvtColor(image, cv2.COLOR_YUV2BGR_I420)
KeyboardInterrupt
pi@raspberrypi:~/MIPI_Camera/RPI/stereo_depth_demo $ python 2_chess_cycle.py
Open camera…
Can’t open the file
Current mode: 2,resolution: 1600x1200
Used camera resolution: 1600 x 1200
Scaled image resolution: 1280 x 480
Starting photo sequence
File “2_chess_cycle.py”, line 88, in <module>
File “2_chess_cycle.py”, line 44, in get_frame
image = frame.as_array.reshape(int(height * 1.5), width)
File “/home/pi/MIPI_Camera/RPI/stereo_depth_demo/arducam_mipicamera.py”, line 266, in as_array
return np.ctypeslib.as_array(self.buffer_ptr[0].data, shape=(self.length,))
ValueError: NULL pointer access
