As the title says, trying to get this camera working with my setup: Arducam Motorized Focus Pi Camera, Autofocus for Raspberry Pi Camera Module, Motorized Lens, Software Precise Manual Focus, OV5647 5MP 1080P
I had this camera working on the same Pi when it was flashed with OctoPi running OCtoPrint, so I know the camera is not faulty.
I followed this guide: Motorized Focus Camera - Arducam
And then tried this: /docs/cameras-for-raspberry-pi/native-raspberry-pi-cameras/how-to-use-arducam-motorized-focus-camera-with-octopi-to-monitor-3d-printers/
And then this: /docs/cameras-for-raspberry-pi/native-raspberry-pi-cameras/5mp-ov5647-motorized-focus-camera-modules/
I even attempted to manually compile the driver with a patch I found on the Pivarity giuthub.
Can anyone steer me in the right direction?
Here are some log outputs if they help:
pi@fluiddpi:~ $ raspistill -t 0
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component \'vc.ril.camera\' (1:ENOMEM)
mmal: mmal_component_create_core: could not create component \'vc.ril.camera\' (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
pi@fluiddpi:~ $ libcamera-still -t 5000 -o test.jpg
libcamera-still: error while loading shared libraries: libcamera.so.0: cannot open shared object file: No such file or directory
pi@fluiddpi:~ $ dmesg | grep arducam
[ 10.444640] arducam: loading out-of-tree module taints kernel.
[ 10.466937] arducam-pivariety 10-000c: probe failed
pi@fluiddpi:~ $ vcgencmd get_camera
supported=1 detected=0
Linux fluiddpi 5.10.103-v7+ #1530 SMP Tue Mar 8 13:02:44 GMT 2022 armv7l GNU/Linux
NAME=“Raspbian GNU/Linux”
VERSION_ID=“11”
VERSION=“11 (bullseye)”
VERSION_CODENAME=bullseye
ID=raspbian
ID_LIKE=debian
HOME_URL=""
SUPPORT_URL=""
BUG_REPORT_URL=""
MemTotal: 762660 kB
MemFree: 315160 kB
MemAvailable: 607280 kB
Buffers: 55524 kB
Cached: 270152 kB
SwapCached: 0 kB
Active: 158224 kB
Inactive: 225600 kB
Active(anon): 460 kB
Inactive(anon): 58344 kB
Active(file): 157764 kB
Inactive(file): 167256 kB
Unevictable: 16 kB
Mlocked: 16 kB
SwapTotal: 102396 kB
SwapFree: 102396 kB
Dirty: 28 kB
Writeback: 0 kB
AnonPages: 58164 kB
Mapped: 62652 kB
Shmem: 656 kB
KReclaimable: 24312 kB
Slab: 40784 kB
SReclaimable: 24312 kB
SUnreclaim: 16472 kB
KernelStack: 1248 kB
PageTables: 1960 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
CommitLimit: 483724 kB
Committed_AS: 389280 kB
VmallocTotal: 1294336 kB
VmallocUsed: 12460 kB
VmallocChunk: 0 kB
Percpu: 528 kB
CmaTotal: 65536 kB
CmaFree: 63556 kB
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
start_x=1
display_auto_detect=1
# Enable DRM VC4 V3D driver
#dtoverlay=vc4-kms-v3d
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
#dtoverlay=vc4-fkms-v3d
[pi4]
arm_boost=1
# enable raspicam
start_x=1
gpu_mem=256
dtoverlay=arducam
dtparam=i2c_vc=on
VERSION_ID=“11”
ID=raspbian
ID_LIKE=debian
MemTotal: 762660 kB
MemFree: 315160 kB
Buffers: 55524 kB
Cached: 270152 kB
SwapCached: 0 kB
Active: 158224 kB
Inactive: 225600 kB
Unevictable: 16 kB
Mlocked: 16 kB
SwapFree: 102396 kB
Dirty: 28 kB
Writeback: 0 kB
AnonPages: 58164 kB
Mapped: 62652 kB
Shmem: 656 kB
Slab: 40784 kB
PageTables: 1960 kB
NFS_Unstable: 0 kB
Bounce: 0 kB
WritebackTmp: 0 kB
VmallocChunk: 0 kB
Percpu: 528 kB
CmaTotal: 65536 kB
CmaFree: 63556 kB
#hdmi_safe=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#sdtv_mode=2
#arm_freq=800
dtparam=i2c_arm=on
#dtparam=i2s=on
dtparam=spi=on
dtparam=audio=on
start_x=1
max_framebuffers=2
disable_overscan=1
[cm4]
otg_mode=1
[pi4]
arm_boost=1
# enable raspicam
start_x=1
gpu_mem=256
dtoverlay=arducam
dtparam=i2c_vc=on
It looks like you have enabled the legacy camera stack, please comment out dtoverlay=arducam in /boot/config.txt, 5MP is officially supported, no need to install arducam driver.
