One of the cameras output is blurred
[ 0.428579] DTS File Name: /var/jenkins_home/workspace/ier_nx_kernel_l4t-32.6.1-arducam/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t19x/jakku/kernel-dts/tegra194-p3668-all-p3509-0000.dts
What are the alternatives for the nano testing and what could be the problem. I have used other arducam camera with my jetson NX that works just fine for me. The problem happened when I was trying this module for the first time. I sit a physical problem with the camera module itself or other.
At the moment I am not sure what the problem is,
It may be the hardware is damaged, or it may be a firmware issue,
So I want you to test the single channel. If all channels have no problems, it means that there is a firmware problem. If there are also problems with the single channel, then there may be a hardware problem.
I have to mention that even when the cameras are covered, the channel of the third camera is perturbed with noise. I have tried changing the camera cables and still same problem.
