onilx
December 21, 2023, 11:00am
1
At first I attempted to use my quad array hat on an older OS. It was working but giving me a long line of the same repeating error message.
After updating and, it no longer being recognized by libcamera and starting with a fresh clean install of bullseye, it will only work once.
The second time I try to activate the quad array, it tells me it has times out and is trying to reconnect.
I found if I remove the hat from the GOPIO and then plug it back in, it will run one more time.
Any help on what I might be doing wrong.
Dion
December 22, 2023, 6:10am
2
Please attach the output of the commands below:
uname -a
cat /boot/config.txt
dpkg -l | grep libcamera
onilx
December 23, 2023, 3:03pm
3
~ $ uname -a
Linux raspberrypi 6.1.0-rpi7-rpi-v8 #1 SMP PREEMPT Debian 1:6.1.63-1+rpt1 (2023-11-24) aarch64 GNU/Linux
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
dtparam=audio=on
Additional overlays and parameters are documented
/boot/firmware/overlays/README
camera_auto_detect=1
display_auto_detect=1
Automatically load initramfs files, if found
auto_initramfs=1
Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
Don’t have the firmware create an initial video= setting in cmdline.txt.
Use the kernel’s default instead.
disable_fw_kms_setup=1
Run in 64-bit mode
arm_64bit=1
disable_overscan=1
arm_boost=1
[cm4]
otg_mode=1
dtoverlay=imx519
dtoverlay=ov64a40,link-frequency=360000000
ii libcamera-apps 1.4.1-1 all transitional package
ii libcamera-dev:arm64 0.1.0+rpt20231205-1 arm64 complex camera support library (development files)
ii libcamera-ipa:arm64 0.1.0+rpt20231205-1 arm64 complex camera support library (IPA modules)
ii libcamera-tools 0.1.0+rpt20231122-1 arm64 complex camera support library (tools)
ii libcamera0.1:arm64 0.1.0+rpt20231205-1 arm64 complex camera support library
ii pipewire-libcamera:arm64 0.3.65-3+rpt3 arm64 PipeWire libcamera plugin
ii python3-libcamera 0.1.0+rpt20231122-1 arm64 complex camera support library (Python bindings)
Dion
December 25, 2023, 9:10am
4
Thank you for your collaboration.
I also need some information.Please follow the steps below:
Reboot your device.
Execute the following command to download the bug report tool:
Set executable permissions for the tool:
Execute the tool to generate the bug report:
This will output an “arducam-bug-report.txt” file in the current directory. Please send this file to us([email protected] ) for further analysis.
onilx
December 26, 2023, 2:07pm
5
I’ve rebuilt using the Pi OS Legacy 64 bit. Now I’m back to the camera needing to be power cycled.
I managed to get a bug report out of it. I will be sending it to the email you provided.
Thanks!
Dion
December 27, 2023, 2:18am
6
Hi @onilx
I have replied you on the email and I suspect that the problem is caused by the power. You can power the HAT board with the extra Ttpe-c power to see if the powercycled is solved or not.
And then, we can dig the reason for the unclear images due to the focus driver.
Dion
February 23, 2024, 2:05am
7
Hi @onilx
It is hard to reproduce your problem.
What is the exact kernel version of this older OS?
