Problems you were having. raspistill command doesn’t detect camera
The dmesg log from your hardware.
Troubleshooting attempts you’ve made. tried 3 different cameras and ribbons and raspberry pi. Updated the gpu in boot/config.txt file.
The camera doesn’t seem to work. It always just gives the following:
pi@raspberrypi:~ $ raspistill -o test.jpg
mmal: Cannot read camera info, keeping the defaults for OV5647
mmal: mmal_vc_component_create: failed to create component ‘vc.ril.camera’ (1:ENOMEM)
mmal: mmal_component_create_core: could not create component ‘vc.ril.camera’ (1)
mmal: Failed to create camera component
mmal: Camera is not detected. Please check carefully the camera module is installed correctly
Can you provide some wiring diagrams?
Especially the wiring at the connector position.
Please also provide the picture on the back of the product.
In addition, please provide a screenshot of running
vcgencmd get_camera.
Hi Kai
Just one more question. Just wondering if this is supposed to go into night mode automatically?
I’ve been trying with and without the lights on and it isn’t picking up any image without the light on…
From this page I thought it would go into night mode automatically: Pi Camera Modules with Switchable IR-cut Filter - Arducam
Is there any further setup that I need to follow to make this work?
If you don’t want to use photoresistor control, 12MP IMX477 also supports software control,
But currently it only supports control via GPIO. You can refer to the picture below:
Hello im having somewhat similar issues to benji in that my camera does not connect im posting images of connections and command outputs. im using a IMX 477 B0270 paired with a pi 3A+ running console version Linux raspberrypi 6.1.61-v7+
mmal: mmal_vc_component_enable: failed to enable component: ENOSPC
mmal: camera component couldn’t be enabled
mmal: Failed to run camera app. Please check for firmware updates
libcamera-hello
Preview window unavailable
[0:02:41.815224056] [1504] INFO Camera camera_manager.cpp:297 libcamera v0.0.5+83-bde9b04f
The camera in the config is enabled, even checked the file.
Also checked the voltages on the FSTBOBE, SIOD, SIOC,GPO, XVS to GND and it seems that the camera is functional.
vcgencmd get_camera
supported=1 detected=1, libcamera interfaces=0
updated libcamera and did a sudo apt upgrade and all that.
I ran out of things to try really would be greatfull for your help
