arducam.com -
EK030 -
108MP Evaluation Kit
Jetson Xavier NX -
Setup instructions for ArduCAM_USB_Camera_Shield_Cpp_Demo git repo. -
When running Arducam_Opencv_Demo on a Jetson Xavier NX, I’m spontaneously getting “USB_CAMERA_DATA_LEN_ERROR” errors and after which, I’m getting corrupted images from the camera. -
I’ve tried different USB cords.
Lowering the frame rate of the camera does seem to help, but still I’m often getting corrupted images.
If I comment out the portion of the code that processes the image (the convertImage function and portion that displays it in an OpenCV window), I no longer get the USB_CAMERA_DATA_LEN_ERROR error. To see if the issue was having a delay in the read image loop, I tried to move the portion of the code the processes the image onto another thread, but I still got the USB_CAMERA_DATA_LEN_ERROR and corrupted images.
Note, that the demo program runs completely fine on a windows machine. Also, the demo program runs fine when receiving 4000x3000 images from the camera, just not 12000x9000 images.
- What help do you need?
How can I guarantee I will not get corrupted images from the 108MP camera (while also being able to process the image and at a reasonable frame rate) on the Jetson Xavier NX?
What are possible causes for this problem?
Why would processing the image cause the USB_CAMERA_DATA_LEN_ERROR to show up?
I understand the processing the image takes some CPU resources, but since its not done on the same thread as the capture loop, I wouldn’t think that would be an issue.
